Installation & Licensing
AutoCAD 2015 Change license type after install
1 REPLY 1
1966 Views, 1 Reply
I have installed AutoCAD, MAYA and a couple of other products via a silent install package that was created for us by a 3rd party. The problem is that they have used a single license rather than a network licence and all the clients are now unable to use the product due to the licence being invalid.
I have installed a single network license server and have tested that this works with a freshly installed copy of the installer, configured to point to the license server. My question is, is there a way to update the already installed clients to look at this license server without uninstalling the existing client and pushing out a new client? I'm thinking in terms of either a client config file, or a registry key that can be deployed that will then allow the clients to see the license server.
1 REPLY 1
TravisNave
It's hard to say.  In some instances, switching the registry or the launch icon has worked.  I worked better in older version rather than recent releases, but you can try.
http://knowledge.autodesk.com/support/3ds-max-design/troubleshooting/caas/sfdcarticles/sfdcarticles/...
and
http://upandready.typepad.com/up_and_ready/2014/04/acad-2015-how-to-change-license-type-from-standal...
Good Luck!
Autodesk Forums:
Administrator Productivity
