Hello.
I installed new autocad 2015 (subscription upgrade).
But I could not start program cause 0xc000142 error.
I tested acrobat unstall method and disable vaccine before autocad install, but it is not operate.
If someone have solution?
I use Windows 7 64bit.
I have 2 licenses and other pc is no problem to start autocad 2015 but other ones have a start problem.
Solved by david.lau. Go to Solution.
I was baffled by the complexity of the fixes....I'm just trying to do some dac drwaings, not become a certified Microsoft technician.
I think Autodesk would be emrassed to release a product obviously not fit for consumption with really supporting it.
I asked for a refund. AutoCad 15 sucks.
I am in total agreement concerning the need to go into operating system levels I have no experience with and I am hesitant fiddle around and possibly cause more problems. I am a user not a developer. Adobe Design Suite requires non of this level of difficulty to use. This type of software should be off the shelf ready to install and use!
I tried for 12 hours to open AutoCad, with no luck. And I tried a few times to get some support from AutoCad, with no luck. It was a Trial version of AutoCad that I had downloaded and was trying to open, for the reason that they have Trial versions - to try it out, and see if I want to buy their product. It doesn't matter to me if it's AutoCad's problem or Adobe's or mine, if after 12 frustrating hours, I still can't try their product, I'm sure not going to pay money for it.
I've since downloaded ArchiCad trial version. I had it up and running in 10 minutes.
Well, i'm having this problem as well. but in my case, I have a recently restored windows 8.1 with just a few software installed.
This is what my autoruns find:
I don't have any Acrobat/Reader installed, nor Nvidea drivers, please someone help. I also tried to reinstall C++ applications from the Autodesk folder an again, nothing.
LoadAppInt_DLLS already set to 0
PS: I'm trying with the new AutoCAD 2016 Student License.
Does not help to solve Autoruns, since Appinit nothing appears when I start Autocad 2015. The problem occurs when I use a discrete graphics cards(AMD HD8750M), but whew using the built-inIIntel HD graphics) runs and all is good. How to deal whis this?
Can confirm - the knowledge base article is rubbish and didn't work. No Adobe D/C or 9, no autoruns issues, no regedit problems. The 'solution' was to disable the discrete graphics card but that isn't a solution at all. So very very over this rubbish
Then update both drivers, the one for the Intel GC and the one for the "other GC", if both are up-to-date then try to install an older driver version.
I'm sure you have made then your suggestions of what is missing or incorrect using the "no" button besides the "Was the article helpful".
- alfred -
>> The application was unable to start correctly (0xc0000022)
That error is a different one, I guess that should be an answer to another thread or a new thread. This thread here is working out the Error-ID 0x0000142.
>> the application acad.exe runs only as an administrator
That looks like your user either has not enough permissions or within his settings files and/or registry content is blocked (maybe copied from other persons with another permission).
- alfred -
