Installation & Licensing
AutoCAD 2015 0xc0000142 Error occured.
111 REPLIES 111
Message 1 of 112
116229 Views, 111 Replies
Hello.
I installed new autocad 2015 (subscription upgrade).
But I could not start program cause 0xc000142 error.
I tested acrobat unstall method and disable vaccine before autocad install, but it is not operate.
If someone have solution?
I use Windows 7 64bit.
I have 2 licenses and other pc is no problem to start autocad 2015 but other ones have a start problem.
111 REPLIES 111
Message 21 of 112
in reply to: david.lau
I´m having the same issues, I tried unninstalling the Acrobat 9 and reinstalling the Autocad2015 and it says the same thing error 0xc0000142..what can I do? windows 7
Message 22 of 112
david.lau
Check this out...
http://upandready.typepad.com/up_and_ready/2014/03/autocad-2015-application-error-0xc0000142-autorun...
There maybe a problem with an unsigned or unregistered dll via 3rd party.
David Lau
Message 23 of 112
TravisNave
David, I went ahead and marked your link as the solution, since it is being missed as the definitive resource to narrowing down this error.  Good job, man.
It's not always Adobe, sometimes it is nVidia, for example.  So the tool you show in your thread is the best way to determine that.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 24 of 112
nevermind...I misstep unninstalling an Adobe archive..si I unninstalled everything related with the Adobe Acrobat 9 and then re-installed the autocad2015 and it is running perfectly
Message 25 of 112
dmorse1
Travis,
Are the proper steps to uninstall the offending program, like Adobe, and also uninstall AutoCAD, or just uninstall offending program and re-launch AutoCAD?
___________________________________
Dave Morse, Sr. Technical Specialist
APPLIED SOFTWARE | Harnessing the Power to Go Further | 800.899.2784 | LiveLab Learning
Message 26 of 112
TravisNave
in reply to: dmorse1
I think you can just uninstall the offending program, ensure AutoCAD works (worst case a repair should suffice) and then reinstall the offending program.
Autodesk Forums:
Message 27 of 112
in reply to: TravisNave
Thanks I already have the autocad installed.I unninstalled the Adobe then
installed the Autocad aaaaaanndd then reinstalled the Adobe
Message 28 of 112
adrocheleau
I have the same problem except that I had acrobat 11 reader installed which i uninstalled. This did not fix the problem. I still get the same error. Should i uninstall autocad & reinstall?
Message 29 of 112
welcome  @forums.autodesk.com!
Did you follow the link shown in message 19 by David LAU?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 30 of 112
in reply to: adrocheleau
I did uninstalled the Adobe and eliminated everything realted to that.then
installed the Autocad (with no problema) and then reinstalled the
Adobe.after that it just send me an error message about some 3Dsomething
when I open the Adobe..but both programs run just fine..at least for what I
used them..without problems
Message 31 of 112
steve.west
Hi.
Had the same problem on Window 7 PC (but curiously not on my Windows 8.1 Laptop). David's solution using Autoruns software (freeware) solved the problem. Used Autoruns to locate the problem DLL file (on Applnit tab - related to Acrobat 9), renamed the first DLL file on the list and hey presto, AutoCAD now works, and I can still use Acrobat 9.
Nice one David! Been wrestling with this for almost a week now. Cheers!
Message 32 of 112
in reply to: steve.west
what name should I put that file and what name should I put that file and could climb a step by stepclimb a step by step
Message 33 of 112
steve.west
I just added an x on the end of the dll filename. You will get an error message next time you use Acrobat. Just tick the box not to show the message next time.
[cid:image002.jpg@01CF6E83.88ABDF10] Best Regards
Steve West
Design Engineer
Tel: +44 (0)1384 453966
Email: steve.west@alltherm.co.uk
designers & manufacturers of thermal processing equipment
Message 34 of 112
deb.messmer
that blog post really helped - followed the visual and changed (1) to (0) and AutoCad now opens. thx!
Message 35 of 112
steve.west
in reply to: deb.messmer
You're welcome, though I can't take credit as this was someone else's idea (see earlier post). I just drew attention to it and repeated it as it helped me in the same way.
Best Regards
Steve West
Design Engineer
Alltherm Engineering Ltd
Designers & Manufacturers of Thermal Processing Equipment
Sent from my iPhone
Message 36 of 112
smbrennan
Ok - I am also having the same issue. But, I am not receiving any direct message. The first time on after Windows startup, I get the Windows prompt "AutoCAD has stopped working" and no option but to close the program. However, this prompt comes up as the first run windows start to pop up - almost like Windows is forcing a stop too quickly.
I first found that in my Processes Tab of Task Manager - AutoCAD has completed stopped consuing more memory (Around 62K). This happens when the AcSettingSync.exe process begins to Run (Description is AutoCAD component).
I posted the problem elsewhere and was redirected to this forum. I used AutoRuns, checked the AppInit - and no line items displayed (the Status bar displaed "Ready" - so I know it was completed reading the system).
Based on other user's problems, I uninstalled Adobe Reader XI, rebooted my machine, and the same thing still happens.
I am want to avoid updating my graphics driver because the last time I did, I got the BSoD and had to roll back my driver to what I currently have on.
I would definitely not want to reformat my hard drive either - for the above reason.
What should I check next?
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
Message 37 of 112
mamussawir
in reply to: roberts123
guys just go to C:\Windows\System32 then search acaptuser64.dll this dll file just copy on your desktop then rename the file remove .dll thats all
no need to uninstall any thing just use this simple method once your autocad run one time copy this file to the directery.
Message 38 of 112
I have the save prolem.
No one seems to know what to do.
Message 39 of 112
canciocus
Tried with autoruns and not worked for me.
But i found a solution here.
Good Luck.
Message 40 of 112
Ayssnna
I instlled CAD 2015 on desktop. When I have hatch on my screen, it shows so many lines which are not in my drawings. I attached print screen from my drawings.
Administrator Productivity
