heres is the install log
2013/10/22:21:56:50 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/22:21:56:50 Richard RT_PC Path_Length: 155
2013/10/22:21:56:50 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/22:21:56:50 Richard RT_PC Launch
2013/10/22:21:56:50 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/22:21:56:50 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI8CE5.tmp
2013/10/22:22:05:18 Richard RT_PC === Setup ended ===
2013/10/22:21:57:02 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/22:21:57:02 Richard RT_PC Path_Length: 155
2013/10/22:21:57:02 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI8CE5.tmp
2013/10/22:21:57:02 Richard RT_PC Launch
2013/10/22:22:00:51 Richard RT_PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:05:17 Richard RT_PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:05:17 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI8CE5.tmp\Setup\AcSetup.dll
2013/10/22:22:05:17 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/22:22:05:18 Richard RT_PC PageOpen LaunchDialog
2013/10/22:22:06:03 Richard RT_PC PageOpen LicenseDialog
2013/10/22:22:06:03 Richard RT_PC PageOpen ProductInfoDialog
2013/10/22:22:06:03 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/22:22:07:29 Richard RT_PC PageOpen FullProgressDialog
2013/10/22:22:07:51 Richard RT_PC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:09:08 Richard RT_PC Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:09:26 Richard RT_PC Download User Resume DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:09:58 Richard RT_PC Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:11:04 Richard RT_PC Download User Pause DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:11:04 Richard RT_PC Download Paused DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:11:55 Richard RT_PC Download User Resume DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:12:16 Richard RT_PC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:12:16 Richard RT_PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/22:22:14:08 Richard RT_PC Install DirectX Runtime Succeeded
2013/10/22:22:14:08 Richard RT_PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/22:22:14:26 Richard RT_PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/23:00:35:00 Richard RT_PC Download Play CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:00:36:22 Richard RT_PC Download Error CM Unknown error! http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:00:36:26 Richard RT_PC Download Aborted CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:00:36:26 Richard RT_PC Install Autodesk Material Library 2014 Failed Download Failed, Installation aborted, Result=1603
2013/10/23:00:36:31 Richard RT_PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/23:00:36:32 Richard RT_PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/10/23:00:36:33 Richard RT_PC PageOpen InstallCompleteDialog
2013/10/23:06:45:11 Richard RT_PC === Setup ended ===
2013/10/23:19:50:10 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/23:19:50:10 Richard RT_PC Path_Length: 155
2013/10/23:19:50:10 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/23:19:50:10 Richard RT_PC Launch
2013/10/23:19:50:10 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/23:19:50:10 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIE8C2.tmp
2013/10/23:19:50:46 Richard RT_PC === Setup ended ===
2013/10/23:19:50:23 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/23:19:50:23 Richard RT_PC Path_Length: 155
2013/10/23:19:50:23 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIE8C2.tmp
2013/10/23:19:50:23 Richard RT_PC Launch
2013/10/23:19:50:24 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:19:50:24 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIE8C2.tmp\Setup\AcSetup.dll
2013/10/23:19:50:24 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/23:19:50:26 Richard RT_PC PageOpen LaunchDialog
2013/10/23:19:54:48 Richard RT_PC PageOpen LicenseDialog
2013/10/23:19:54:48 Richard RT_PC PageOpen ProductInfoDialog
2013/10/23:19:54:48 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/23:19:55:23 Richard RT_PC PageOpen FullProgressDialog
2013/10/23:19:55:24 Richard RT_PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:19:55:24 Richard RT_PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/23:19:57:35 Richard RT_PC Install DirectX Runtime Failed Failure is ignored, Result=-9
2013/10/23:19:57:35 Richard RT_PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/23:19:57:56 Richard RT_PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/23:19:58:39 Richard RT_PC Download Play CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:19:59:56 Richard RT_PC Download Error CM <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:21:04 Richard RT_PC Download User Resume CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:21:36 Richard RT_PC Download Error CM <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:22:07 Richard RT_PC Download User Resume CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:22:47 Richard RT_PC Download Error CM <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:30:30 Richard RT_PC Download Error CM <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:34:09 Richard RT_PC Download Complete CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:34:09 Richard RT_PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/23:20:34:47 Richard RT_PC Install Autodesk Material Library 2014 Succeeded
2013/10/23:20:35:38 Richard RT_PC Download Play CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:39:42 Richard RT_PC Download Complete CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:39:42 Richard RT_PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/23:20:40:08 Richard RT_PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/10/23:20:40:09 Richard RT_PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/23:20:40:24 Richard RT_PC Install Autodesk Content Service Succeeded
2013/10/23:20:40:26 Richard RT_PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/23:20:40:35 Richard RT_PC Install Autodesk Content Service Language Pack Succeeded
2013/10/23:20:41:21 Richard RT_PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:42:38 Richard RT_PC Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:48:03 Richard RT_PC Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:21:08:49 Richard RT_PC Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:21:08:50 Richard RT_PC Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AIE8C2.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/23:21:09:13 Richard RT_PC Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1603
2013/10/23:21:09:24 Richard RT_PC Rollback Autodesk Content Service Language Pack Succeeded
2013/10/23:21:09:47 Richard RT_PC Rollback Autodesk Content Service Succeeded
2013/10/23:21:10:33 Richard RT_PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/10/23:21:11:44 Richard RT_PC Rollback Autodesk Material Library 2014 Succeeded
2013/10/23:21:11:49 Richard RT_PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/23:21:11:50 Richard RT_PC PageOpen InstallCompleteDialog
2013/10/23:21:25:11 Richard RT_PC === Setup ended ===
2013/10/24:19:30:36 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/24:19:30:36 Richard RT_PC Path_Length: 155
2013/10/24:19:30:36 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/24:19:30:36 Richard RT_PC Launch
2013/10/24:19:30:36 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/24:19:30:36 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI6414.tmp
2013/10/24:19:31:35 Richard RT_PC === Setup ended ===
2013/10/24:19:30:50 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/24:19:30:50 Richard RT_PC Path_Length: 155
2013/10/24:19:30:50 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI6414.tmp
2013/10/24:19:30:50 Richard RT_PC Launch
2013/10/24:19:31:34 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:19:31:34 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI6414.tmp\Setup\AcSetup.dll
2013/10/24:19:31:34 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/24:19:31:35 Richard RT_PC PageOpen LaunchDialog
2013/10/24:19:31:46 Richard RT_PC PageOpen LicenseDialog
2013/10/24:19:31:46 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/24:19:32:02 Richard RT_PC PageOpen FullProgressDialog
2013/10/24:19:32:02 Richard RT_PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/24:19:32:05 Richard RT_PC Install Network License Manager Succeeded
2013/10/24:19:32:48 Richard RT_PC Download Play CADM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:19:40:01 Richard RT_PC Download Complete CADM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:19:40:01 Richard RT_PC Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/24:19:40:06 Richard RT_PC Install Autodesk CAD Manager Tools Succeeded
2013/10/24:19:40:06 Richard RT_PC PageOpen InstallCompleteDialog
2013/10/24:19:43:07 Richard RT_PC === Setup ended ===
2013/10/24:19:44:15 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/24:19:44:15 Richard RT_PC Path_Length: 155
2013/10/24:19:44:15 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/24:19:44:15 Richard RT_PC Launch
2013/10/24:19:44:15 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/24:19:44:15 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AID434.tmp
2013/10/24:19:45:01 Richard RT_PC === Setup ended ===
2013/10/24:19:44:34 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/24:19:44:34 Richard RT_PC Path_Length: 155
2013/10/24:19:44:34 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AID434.tmp
2013/10/24:19:44:34 Richard RT_PC Launch
2013/10/24:19:45:00 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:19:45:00 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AID434.tmp\Setup\AcSetup.dll
2013/10/24:19:45:00 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/24:19:45:01 Richard RT_PC PageOpen LaunchDialog
2013/10/24:20:00:04 Richard RT_PC === Setup ended ===
2013/10/24:22:17:59 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/24:22:17:59 Richard RT_PC Path_Length: 155
2013/10/24:22:17:59 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/24:22:17:59 Richard RT_PC Launch
2013/10/24:22:17:59 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/24:22:17:59 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIA1A3.tmp
2013/10/24:22:18:45 Richard RT_PC === Setup ended ===
2013/10/24:22:18:16 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/24:22:18:16 Richard RT_PC Path_Length: 155
2013/10/24:22:18:16 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIA1A3.tmp
2013/10/24:22:18:16 Richard RT_PC Launch
2013/10/24:22:18:41 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:18:41 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIA1A3.tmp\Setup\AcSetup.dll
2013/10/24:22:18:41 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/24:22:18:43 Richard RT_PC PageOpen LaunchDialog
2013/10/24:22:19:21 Richard RT_PC PageOpen LicenseDialog
2013/10/24:22:19:21 Richard RT_PC PageOpen ProductInfoDialog
2013/10/24:22:19:21 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/24:22:24:27 Richard RT_PC PageOpen FullProgressDialog
2013/10/24:22:24:28 Richard RT_PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:24:28 Richard RT_PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/24:22:26:24 Richard RT_PC Install DirectX Runtime Succeeded
2013/10/24:22:26:24 Richard RT_PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/24:22:26:44 Richard RT_PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/24:22:26:44 Richard RT_PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:26:44 Richard RT_PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/24:22:27:29 Richard RT_PC Install Autodesk Material Library 2014 Succeeded
2013/10/24:22:27:29 Richard RT_PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:27:29 Richard RT_PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/24:22:28:02 Richard RT_PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/10/24:22:28:02 Richard RT_PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/24:22:28:15 Richard RT_PC Install Autodesk Content Service Succeeded
2013/10/24:22:28:17 Richard RT_PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/24:22:28:22 Richard RT_PC Install Autodesk Content Service Language Pack Succeeded
2013/10/24:22:28:22 Richard RT_PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:28:23 Richard RT_PC Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AIA1A3.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/24:23:38:54 Richard RT_PC Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1602
2013/10/24:23:39:01 Richard RT_PC Rollback Autodesk Content Service Language Pack Succeeded
2013/10/24:23:39:17 Richard RT_PC Rollback Autodesk Content Service Succeeded
2013/10/24:23:40:08 Richard RT_PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/10/24:23:41:47 Richard RT_PC Rollback Autodesk Material Library 2014 Succeeded
2013/10/24:23:41:53 Richard RT_PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/24:23:41:53 Richard RT_PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/10/24:23:41:54 Richard RT_PC PageOpen InstallCompleteDialog
2013/10/24:23:46:46 Richard RT_PC === Setup ended ===
2013/10/25:19:30:05 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/25:19:30:05 Richard RT_PC Path_Length: 155
2013/10/25:19:30:05 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/25:19:30:05 Richard RT_PC Launch
2013/10/25:19:30:05 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/25:19:30:05 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI48D2.tmp
2013/10/25:19:30:58 Richard RT_PC === Setup ended ===
2013/10/25:19:30:37 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/25:19:30:37 Richard RT_PC Path_Length: 155
2013/10/25:19:30:37 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI48D2.tmp
2013/10/25:19:30:37 Richard RT_PC Launch
2013/10/25:19:30:37 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:30:38 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI48D2.tmp\Setup\AcSetup.dll
2013/10/25:19:30:38 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/25:19:30:54 Richard RT_PC PageOpen LaunchDialog
2013/10/25:19:32:04 Richard RT_PC PageOpen LicenseDialog
2013/10/25:19:32:04 Richard RT_PC PageOpen ProductInfoDialog
2013/10/25:19:32:04 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/25:19:39:52 Richard RT_PC PageOpen FullProgressDialog
2013/10/25:19:39:52 Richard RT_PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:39:52 Richard RT_PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/25:19:41:53 Richard RT_PC Install DirectX Runtime Succeeded
2013/10/25:19:41:53 Richard RT_PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:19:42:17 Richard RT_PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/25:19:42:38 Richard RT_PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:42:38 Richard RT_PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:19:43:17 Richard RT_PC Install Autodesk Material Library 2014 Succeeded
2013/10/25:19:43:44 Richard RT_PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:43:44 Richard RT_PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:19:44:09 Richard RT_PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/10/25:19:44:10 Richard RT_PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:19:44:26 Richard RT_PC Install Autodesk Content Service Succeeded
2013/10/25:19:44:26 Richard RT_PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:19:44:34 Richard RT_PC Install Autodesk Content Service Language Pack Succeeded
2013/10/25:19:44:34 Richard RT_PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:44:35 Richard RT_PC Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AI48D2.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:19:45:13 Richard RT_PC Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1602
2013/10/25:19:45:19 Richard RT_PC Rollback Autodesk Content Service Language Pack Succeeded
2013/10/25:19:45:41 Richard RT_PC Rollback Autodesk Content Service Succeeded
2013/10/25:19:46:30 Richard RT_PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/10/25:19:48:14 Richard RT_PC Rollback Autodesk Material Library 2014 Succeeded
2013/10/25:19:48:16 Richard RT_PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/25:19:48:16 Richard RT_PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/10/25:19:48:17 Richard RT_PC PageOpen InstallCompleteDialog
2013/10/25:20:00:42 Richard RT_PC === Setup ended ===
2013/10/25:20:03:07 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/25:20:03:07 Richard RT_PC Path_Length: 155
2013/10/25:20:03:07 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/25:20:03:07 Richard RT_PC Launch
2013/10/25:20:03:07 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/25:20:03:07 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI87E5.tmp
2013/10/25:20:04:02 Richard RT_PC === Setup ended ===
2013/10/25:20:03:47 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/25:20:03:47 Richard RT_PC Path_Length: 155
2013/10/25:20:03:47 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI87E5.tmp
2013/10/25:20:03:47 Richard RT_PC Launch
2013/10/25:20:03:49 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:03:49 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI87E5.tmp\Setup\AcSetup.dll
2013/10/25:20:03:49 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/25:20:03:53 Richard RT_PC PageOpen LaunchDialog
2013/10/25:20:04:57 Richard RT_PC PageOpen LicenseDialog
2013/10/25:20:04:57 Richard RT_PC PageOpen ProductInfoDialog
2013/10/25:20:04:57 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/25:20:05:04 Richard RT_PC PageOpen FullProgressDialog
2013/10/25:20:05:04 Richard RT_PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:05:04 Richard RT_PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/25:20:06:25 Richard RT_PC Install DirectX Runtime Succeeded
2013/10/25:20:06:25 Richard RT_PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:20:06:42 Richard RT_PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/25:20:06:42 Richard RT_PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:06:42 Richard RT_PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:20:07:17 Richard RT_PC Install Autodesk Material Library 2014 Succeeded
2013/10/25:20:07:17 Richard RT_PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:07:17 Richard RT_PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:20:07:42 Richard RT_PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/10/25:20:07:42 Richard RT_PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:20:08:00 Richard RT_PC Install Autodesk Content Service Succeeded
2013/10/25:20:08:00 Richard RT_PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:20:08:08 Richard RT_PC Install Autodesk Content Service Language Pack Succeeded
2013/10/25:20:08:08 Richard RT_PC Download Skipped ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:08:10 Richard RT_PC Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AI87E5.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/25:20:16:35 Richard RT_PC Install Autodesk® AutoCAD® 2014 Succeeded Reboot is required
2013/10/25:20:17:21 Richard RT_PC Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:18:38 Richard RT_PC Download Error ACAD_en-us <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:20:58 Richard RT_PC Download Aborted ACAD_en-us http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:20:58 Richard RT_PC Install AutoCAD® 2014 Language Pack Failed Download Failed, Installation aborted, Result=1603
2013/10/25:20:25:03 Richard RT_PC Rollback Autodesk® AutoCAD® 2014 Succeeded
2013/10/25:20:25:10 Richard RT_PC Rollback Autodesk Content Service Language Pack Succeeded
2013/10/25:20:25:23 Richard RT_PC Rollback Autodesk Content Service Succeeded
2013/10/25:20:26:06 Richard RT_PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/10/25:20:27:39 Richard RT_PC Rollback Autodesk Material Library 2014 Succeeded
2013/10/25:20:27:44 Richard RT_PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/10/25:20:27:44 Richard RT_PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/10/25:20:27:45 Richard RT_PC PageOpen InstallCompleteDialog
2013/10/25:20:41:13 Richard RT_PC === Setup ended ===
2013/10/25:21:26:19 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/25:21:26:19 Richard RT_PC Path_Length: 155
2013/10/25:21:26:19 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/25:21:26:19 Richard RT_PC Launch
2013/10/25:21:26:19 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/25:21:26:19 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI3AAF.tmp
2013/10/25:21:27:16 Richard RT_PC === Setup ended ===
2013/10/25:21:26:39 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/25:21:26:39 Richard RT_PC Path_Length: 155
2013/10/25:21:26:39 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI3AAF.tmp
2013/10/25:21:26:39 Richard RT_PC Launch
2013/10/25:21:27:01 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:21:27:02 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI3AAF.tmp\Setup\AcSetup.dll
2013/10/25:21:27:02 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/25:21:27:04 Richard RT_PC PageOpen LaunchDialog
2013/10/25:22:25:04 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/25:22:25:04 Richard RT_PC Path_Length: 155
2013/10/25:22:25:04 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AICA04.tmp
2013/10/25:22:25:04 Richard RT_PC Launch
2013/10/25:22:25:05 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:22:25:05 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AICA04.tmp\Setup\AcSetup.dll
2013/10/25:22:25:05 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/25:22:25:07 Richard RT_PC PageOpen LaunchDialog
2013/10/25:22:24:49 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/25:22:24:49 Richard RT_PC Path_Length: 155
2013/10/25:22:24:49 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/25:22:24:49 Richard RT_PC Launch
2013/10/25:22:24:49 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/25:22:24:49 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AICA04.tmp
2013/10/25:22:25:43 Richard RT_PC === Setup ended ===
2013/10/26:11:50:06 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/26:11:50:06 Richard RT_PC Path_Length: 155
2013/10/26:11:50:06 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/26:11:50:06 Richard RT_PC Launch
2013/10/26:11:50:06 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/26:11:50:06 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIC062.tmp
2013/10/26:11:51:00 Richard RT_PC === Setup ended ===
2013/10/26:11:50:28 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/26:11:50:28 Richard RT_PC Path_Length: 155
2013/10/26:11:50:28 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIC062.tmp
2013/10/26:11:50:28 Richard RT_PC Launch
2013/10/26:11:50:31 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/26:11:50:32 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIC062.tmp\Setup\AcSetup.dll
2013/10/26:11:50:32 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/26:11:50:35 Richard RT_PC PageOpen LaunchDialog
2013/10/26:11:53:24 Richard RT_PC PageOpen LicenseDialog
2013/10/26:11:53:24 Richard RT_PC PageOpen ProductInfoDialog
2013/10/26:11:53:24 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/26:11:53:42 Richard RT_PC === Setup ended ===
2013/10/26:11:59:01 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/26:11:59:01 Richard RT_PC Path_Length: 155
2013/10/26:11:59:01 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIC294.tmp
2013/10/26:11:59:01 Richard RT_PC Launch
2013/10/26:11:59:23 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/26:11:59:24 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIC294.tmp\Setup\AcSetup.dll
2013/10/26:11:59:24 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/26:11:59:25 Richard RT_PC PageOpen LaunchDialog
2013/10/26:11:58:50 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/26:11:58:50 Richard RT_PC Path_Length: 155
2013/10/26:11:58:50 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/26:11:58:50 Richard RT_PC Launch
2013/10/26:11:58:50 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/26:11:58:50 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIC294.tmp
2013/10/26:11:59:42 Richard RT_PC === Setup ended ===
2013/10/26:11:59:30 Richard RT_PC PageOpen LicenseDialog
2013/10/26:11:59:30 Richard RT_PC PageOpen ProductInfoDialog
2013/10/26:11:59:30 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/26:12:00:05 Richard RT_PC === Setup ended ===
2013/10/29:19:31:26 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/29:19:31:26 Richard RT_PC Path_Length: 155
2013/10/29:19:31:26 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/29:19:31:26 Richard RT_PC Launch
2013/10/29:19:31:26 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/29:19:31:26 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI2FC1.tmp
2013/10/29:19:32:34 Richard RT_PC === Setup ended ===
2013/10/29:19:31:44 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/29:19:31:44 Richard RT_PC Path_Length: 155
2013/10/29:19:31:44 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI2FC1.tmp
2013/10/29:19:31:44 Richard RT_PC Launch
2013/10/29:19:31:48 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/29:19:32:02 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI2FC1.tmp\Setup\AcSetup.dll
2013/10/29:19:32:02 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/29:19:32:07 Richard RT_PC PageOpen LaunchDialog
2013/10/29:19:32:56 Richard RT_PC PageOpen LicenseDialog
2013/10/29:19:32:57 Richard RT_PC PageOpen ProductInfoDialog
2013/10/29:19:32:57 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/29:19:36:16 Richard RT_PC PageOpen ProductInfoDialog
2013/10/29:19:36:16 Richard RT_PC PageOpen LicenseDialog
2013/10/29:19:36:16 Richard RT_PC PageOpen LaunchDialog
2013/10/29:19:36:18 Richard RT_PC PageOpen LicenseDialog
2013/10/29:19:36:18 Richard RT_PC PageOpen ProductInfoDialog
2013/10/29:19:36:18 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/29:19:41:26 Richard RT_PC PageOpen ProductInfoDialog
2013/10/29:19:41:27 Richard RT_PC PageOpen LicenseDialog
2013/10/29:19:41:27 Richard RT_PC PageOpen LaunchDialog
2013/10/29:19:41:28 Richard RT_PC PageOpen LicenseDialog
2013/10/29:19:41:28 Richard RT_PC PageOpen ProductInfoDialog
2013/10/29:19:41:28 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/29:19:41:30 Richard RT_PC PageOpen ProductInfoDialog
2013/10/29:19:41:30 Richard RT_PC PageOpen LicenseDialog
2013/10/29:19:41:30 Richard RT_PC PageOpen LaunchDialog
2013/10/29:19:41:34 Richard RT_PC PageOpen LicenseDialog
2013/10/29:19:41:34 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/29:19:41:43 Richard RT_PC === Setup ended ===
2013/10/29:19:46:25 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/29:19:46:25 Richard RT_PC Path_Length: 155
2013/10/29:19:46:25 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI72F8.tmp
2013/10/29:19:46:25 Richard RT_PC Launch
2013/10/29:19:46:27 Richard RT_PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/29:19:46:28 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI72F8.tmp\Setup\AcSetup.dll
2013/10/29:19:46:28 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/29:19:46:34 Richard RT_PC PageOpen LaunchDialog
2013/10/29:19:45:54 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/10/29:19:45:54 Richard RT_PC Path_Length: 155
2013/10/29:19:45:54 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/29:19:45:54 Richard RT_PC Launch
2013/10/29:19:45:54 Richard RT_PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/10/29:19:45:54 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI72F8.tmp
2013/10/29:19:46:56 Richard RT_PC === Setup ended ===
2013/10/29:19:46:53 Richard RT_PC PageOpen LicenseDialog
2013/10/29:19:46:53 Richard RT_PC PageOpen ProductInfoDialog
2013/10/29:19:46:54 Richard RT_PC PageOpen ProductSelectionDialog2
2013/10/29:19:47:50 Richard RT_PC === Setup ended ===
2013/11/5:09:33:28 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:09:33:28 Richard RT_PC Path_Length: 155
2013/11/5:09:33:28 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:09:33:28 Richard RT_PC Launch
2013/11/5:09:33:28 Richard RT_PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2013/11/5:09:33:28 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIE4D0.tmp
2013/11/5:09:40:51 Richard RT_PC === Setup ended ===
2013/11/5:09:33:50 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:09:33:50 Richard RT_PC Path_Length: 155
2013/11/5:09:33:50 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIE4D0.tmp
2013/11/5:09:33:50 Richard RT_PC Launch
2013/11/5:09:37:01 Richard RT_PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:09:38:18 Richard RT_PC Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:09:40:49 Richard RT_PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:09:40:50 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIE4D0.tmp\Setup\AcSetup.dll
2013/11/5:09:40:50 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:09:40:51 Richard RT_PC PageOpen LaunchDialog
2013/11/5:09:46:18 Richard RT_PC PageOpen LicenseDialog
2013/11/5:09:49:42 Richard RT_PC PageOpen ProductInfoDialog
2013/11/5:09:49:43 Richard RT_PC PageOpen ProductSelectionDialog2
2013/11/5:09:50:07 Richard RT_PC PageOpen FullProgressDialog
2013/11/5:09:52:58 Richard RT_PC Download Play VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST2008...
2013/11/5:09:54:27 Richard RT_PC Download Error VCREDIST2008SP1X64_6161 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST2008...
2013/11/5:09:56:43 Richard RT_PC Download User Cancel VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST2008...
2013/11/5:09:56:43 Richard RT_PC PageOpen InstallCompleteDialog
2013/11/5:09:56:44 Richard RT_PC Download Aborted VCREDIST2008SP1X64_6161 http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST2008...
2013/11/5:09:56:51 Richard RT_PC === Setup ended ===
2013/11/5:10:14:53 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:10:14:53 Richard RT_PC Path_Length: 155
2013/11/5:10:14:53 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI5C12.tmp
2013/11/5:10:14:53 Richard RT_PC Launch
2013/11/5:10:14:59 Richard RT_PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:10:15:17 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI5C12.tmp\Setup\AcSetup.dll
2013/11/5:10:15:17 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:10:15:25 Richard RT_PC PageOpen LaunchDialog
2013/11/5:10:14:24 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:10:14:24 Richard RT_PC Path_Length: 155
2013/11/5:10:14:24 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:10:14:24 Richard RT_PC Launch
2013/11/5:10:14:24 Richard RT_PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2013/11/5:10:14:24 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI5C12.tmp
2013/11/5:10:15:58 Richard RT_PC === Setup ended ===
2013/11/5:10:15:47 Richard RT_PC PageOpen LicenseDialog
2013/11/5:10:24:37 Richard RT_PC PageOpen ProductInfoDialog
2013/11/5:10:24:37 Richard RT_PC PageOpen ProductSelectionDialog2
2013/11/5:10:29:15 Richard RT_PC PageOpen ProductInfoDialog
2013/11/5:10:29:16 Richard RT_PC PageOpen LicenseDialog
2013/11/5:10:29:17 Richard RT_PC PageOpen ProductInfoDialog
2013/11/5:10:29:17 Richard RT_PC PageOpen ProductSelectionDialog2
2013/11/5:10:29:26 Richard RT_PC === Setup ended ===
2013/11/5:16:51:08 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:16:51:08 Richard RT_PC Path_Length: 155
2013/11/5:16:51:08 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:16:51:08 Richard RT_PC Launch
2013/11/5:16:51:08 Richard RT_PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2013/11/5:16:51:08 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI942A.tmp
2013/11/5:16:52:15 Richard RT_PC === Setup ended ===
2013/11/5:16:51:30 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:16:51:30 Richard RT_PC Path_Length: 155
2013/11/5:16:51:30 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI942A.tmp
2013/11/5:16:51:30 Richard RT_PC Launch
2013/11/5:16:52:14 Richard RT_PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:16:52:14 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI942A.tmp\Setup\AcSetup.dll
2013/11/5:16:52:14 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:16:52:15 Richard RT_PC PageOpen LaunchDialog
2013/11/5:17:59:46 Richard RT_PC PageOpen LicenseDialog
2013/11/5:17:59:57 Richard RT_PC PageOpen ProductInfoDialog
2013/11/5:17:59:57 Richard RT_PC PageOpen ProductSelectionDialog2
2013/11/5:18:00:16 Richard RT_PC === Setup ended ===
2013/11/5:21:12:38 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:21:12:38 Richard RT_PC Path_Length: 155
2013/11/5:21:12:38 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:21:12:38 Richard RT_PC Launch
2013/11/5:21:12:38 Richard RT_PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2013/11/5:21:12:38 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIFBD6.tmp
2013/11/5:21:13:42 Richard RT_PC === Setup ended ===
2013/11/5:21:12:48 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:21:12:48 Richard RT_PC Path_Length: 155
2013/11/5:21:12:48 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIFBD6.tmp
2013/11/5:21:12:48 Richard RT_PC Launch
2013/11/5:21:12:48 Richard RT_PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:21:12:49 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIFBD6.tmp\Setup\AcSetup.dll
2013/11/5:21:12:49 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:21:12:52 Richard RT_PC PageOpen LaunchDialog
2013/11/5:21:13:50 Richard RT_PC PageOpen LicenseDialog
2013/11/5:21:16:19 Richard RT_PC PageOpen ProductInfoDialog
2013/11/5:21:16:19 Richard RT_PC PageOpen ProductSelectionDialog2
2013/11/5:21:16:39 Richard RT_PC PageOpen FullProgressDialog
2013/11/5:21:16:43 Richard RT_PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.tar....
2013/11/5:21:18:00 Richard RT_PC Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.tar....
2013/11/5:21:22:16 Richard RT_PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.tar....
2013/11/5:21:22:16 Richard RT_PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/11/5:21:25:40 Richard RT_PC Install DirectX Runtime Succeeded
2013/11/5:21:25:40 Richard RT_PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/5:21:26:13 Richard RT_PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/11/5:21:28:34 Richard RT_PC Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:29:54 Richard RT_PC Download Error CM <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:30:57 Richard RT_PC Download User Resume CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:31:35 Richard RT_PC Download Error CM <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:35:50 Richard RT_PC Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:35:50 Richard RT_PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/5:21:36:45 Richard RT_PC Install Autodesk Material Library 2014 Succeeded
2013/11/5:21:38:44 Richard RT_PC Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:40:01 Richard RT_PC Download Error CMILB <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:41:47 Richard RT_PC Download User Resume CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:42:18 Richard RT_PC Download Error CMILB <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:42:21 Richard RT_PC Download User Resume CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:45:26 Richard RT_PC Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:45:26 Richard RT_PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/5:21:45:47 Richard RT_PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/11/5:21:45:47 Richard RT_PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/5:21:46:04 Richard RT_PC Install Autodesk Content Service Succeeded
2013/11/5:21:46:05 Richard RT_PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/5:21:46:16 Richard RT_PC Install Autodesk Content Service Language Pack Succeeded
2013/11/5:21:48:46 Richard RT_PC Download Play ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:50:15 Richard RT_PC Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:50:20 Richard RT_PC Download User Resume ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:50:52 Richard RT_PC Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:50:55 Richard RT_PC Download User Resume ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:51:26 Richard RT_PC Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:51:28 Richard RT_PC Download User Resume ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:52:00 Richard RT_PC Download Error ACAD <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:52:09 Richard RT_PC Download User Resume ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:22:03:26 Richard RT_PC Download Aborted ACAD http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:22:03:26 Richard RT_PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/11/5:22:03:55 Richard RT_PC Rollback Autodesk Content Service Language Pack Succeeded
2013/11/5:22:04:29 Richard RT_PC Rollback Autodesk Content Service Succeeded
2013/11/5:22:05:40 Richard RT_PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/11/5:22:07:51 Richard RT_PC Rollback Autodesk Material Library 2014 Succeeded
2013/11/5:22:07:57 Richard RT_PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/11/5:22:07:58 Richard RT_PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/11/5:22:07:58 Richard RT_PC PageOpen InstallCompleteDialog
2013/11/5:22:09:07 Richard RT_PC === Setup ended ===
2013/11/5:22:12:40 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:22:12:40 Richard RT_PC Path_Length: 155
2013/11/5:22:12:40 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:22:12:40 Richard RT_PC Launch
2013/11/5:22:12:40 Richard RT_PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student /akamai /auth authparam /sid SESSION_ID
2013/11/5:22:12:40 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIF5A0.tmp
2013/11/5:22:14:04 Richard RT_PC === Setup ended ===
2013/11/5:22:13:00 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/5:22:13:00 Richard RT_PC Path_Length: 155
2013/11/5:22:13:00 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AIF5A0.tmp
2013/11/5:22:13:00 Richard RT_PC Launch
2013/11/5:22:13:25 Richard RT_PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:22:13:28 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIF5A0.tmp\Setup\AcSetup.dll
2013/11/5:22:13:28 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:22:13:32 Richard RT_PC PageOpen LaunchDialog
2013/11/5:22:14:25 Richard RT_PC PageOpen LicenseDialog
2013/11/5:22:14:29 Richard RT_PC PageOpen ProductInfoDialog
2013/11/5:22:14:29 Richard RT_PC PageOpen ProductSelectionDialog2
2013/11/5:22:14:42 Richard RT_PC === Setup ended ===
2013/11/6:13:00:08 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/6:13:00:08 Richard RT_PC Path_Length: 155
2013/11/6:13:00:08 Richard RT_PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/11/6:13:00:08 Richard RT_PC Launch
2013/11/6:13:00:08 Richard RT_PC CommandLine
2013/11/6:13:00:08 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI76F0.tmp
2013/11/6:13:02:11 Richard RT_PC === Setup ended ===
2013/11/6:13:00:38 Richard RT_PC === Setup started on RT_PC by Richard ===
2013/11/6:13:00:38 Richard RT_PC Path_Length: 155
2013/11/6:13:00:38 Richard RT_PC Current Directory C:\Users\Richard\AppData\Local\Temp\_AI76F0.tmp
2013/11/6:13:00:38 Richard RT_PC Launch
2013/11/6:13:00:39 Richard RT_PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI76F0.tmp\Setup\AcSetup.dll
2013/11/6:13:00:39 Richard RT_PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/6:13:01:04 Richard RT_PC PageOpen LaunchDialog
2013/11/6:13:01:14 Richard RT_PC PageOpen LicenseDialog
2013/11/6:13:01:19 Richard RT_PC PageOpen ProductInfoDialog
2013/11/6:13:02:18 Richard RT_PC PageOpen ProductSelectionDialog2
2013/11/6:13:02:27 Richard RT_PC PageOpen FullProgressDialog
2013/11/6:13:02:29 Richard RT_PC Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2013/11/6:13:18:31 Richard RT_PC Install DirectX Runtime Failed Failure is ignored, Result=-9
2013/11/6:13:18:31 Richard RT_PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/6:13:19:01 Richard RT_PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/11/6:13:19:01 Richard RT_PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/6:13:19:49 Richard RT_PC Install Autodesk Material Library 2014 Succeeded
2013/11/6:13:19:50 Richard RT_PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/6:13:20:17 Richard RT_PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/11/6:13:20:17 Richard RT_PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/6:13:20:33 Richard RT_PC Install Autodesk Content Service Succeeded
2013/11/6:13:20:34 Richard RT_PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/6:13:20:49 Richard RT_PC Install Autodesk Content Service Language Pack Succeeded
2013/11/6:13:20:50 Richard RT_PC Installing Autodesk® AutoCAD® 2014: TRANSFORMS="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AI76F0.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/6:13:34:22 Richard RT_PC Install Autodesk® AutoCAD® 2014 Failed Installation aborted, Result=1603
2013/11/6:13:34:33 Richard RT_PC Rollback Autodesk Content Service Language Pack Succeeded
2013/11/6:13:35:12 Richard RT_PC Rollback Autodesk Content Service Succeeded
2013/11/6:13:36:09 Richard RT_PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/11/6:13:38:37 Richard RT_PC Rollback Autodesk Material Library 2014 Succeeded
2013/11/6:13:38:44 Richard RT_PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
i tried browser download and install now, it still failed
Hi r_tj,
Welcome to Autodesk Discussion Group.
Please attempt a re-download via the Virtual Agent within our support.
*Select [Downloading and Installation] --> [Software Download Links] --> [I need to redownload my product] --> Then select the product you wish to download.
More importantly, please refer to the below article on the permission required and restrictions to avoid, in order to facilitate a smooth installation.
Thank you.
