Installation & Licensing
autocad 2014 - student version installation issues
1 REPLY 1
r_tj
1304 Views, 1 Reply
heres is the install log
2013/10/22:21:56:50    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/22:21:56:50    Richard    RT_PC    Path_Length: 155
2013/10/22:21:56:50    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/22:21:56:50    Richard    RT_PC    Launch
2013/10/22:21:56:50    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/22:21:56:50    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI8CE5.tmp
2013/10/22:22:05:18    Richard    RT_PC    === Setup ended ===
2013/10/22:21:57:02    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/22:21:57:02    Richard    RT_PC    Path_Length: 155
2013/10/22:21:57:02    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI8CE5.tmp
2013/10/22:21:57:02    Richard    RT_PC    Launch
2013/10/22:22:00:51    Richard    RT_PC    Download    Play    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:05:17    Richard    RT_PC    Download    Complete    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:05:17    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI8CE5.tmp\Setup\AcSetup.dll
2013/10/22:22:05:17    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/22:22:05:18    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/22:22:06:03    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/22:22:06:03    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/22:22:06:03    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/22:22:07:29    Richard    RT_PC    PageOpen    FullProgressDialog
2013/10/22:22:07:51    Richard    RT_PC    Download    Play    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:09:08    Richard    RT_PC    Download Error    DIRECTX    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:09:26    Richard    RT_PC    Download    User Resume    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:09:58    Richard    RT_PC    Download Error    DIRECTX    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:11:04    Richard    RT_PC    Download    User Pause    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:11:04    Richard    RT_PC    Download    Paused    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:11:55    Richard    RT_PC    Download    User Resume    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:12:16    Richard    RT_PC    Download    Complete    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/22:22:12:16    Richard    RT_PC    Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/22:22:14:08    Richard    RT_PC    Install    DirectX Runtime    Succeeded
2013/10/22:22:14:08    Richard    RT_PC    Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/22:22:14:26    Richard    RT_PC    Install    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/23:00:35:00    Richard    RT_PC    Download    Play    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:00:36:22    Richard    RT_PC    Download Error    CM    Unknown error!    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:00:36:26    Richard    RT_PC    Download    Aborted    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:00:36:26    Richard    RT_PC    Install    Autodesk Material Library 2014    Failed    Download Failed, Installation aborted, Result=1603
2013/10/23:00:36:31    Richard    RT_PC    Rollback    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/23:00:36:32    Richard    RT_PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/10/23:00:36:33    Richard    RT_PC    PageOpen    InstallCompleteDialog
2013/10/23:06:45:11    Richard    RT_PC    === Setup ended ===
2013/10/23:19:50:10    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/23:19:50:10    Richard    RT_PC    Path_Length: 155
2013/10/23:19:50:10    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/23:19:50:10    Richard    RT_PC    Launch
2013/10/23:19:50:10    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/23:19:50:10    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIE8C2.tmp
2013/10/23:19:50:46    Richard    RT_PC    === Setup ended ===
2013/10/23:19:50:23    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/23:19:50:23    Richard    RT_PC    Path_Length: 155
2013/10/23:19:50:23    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIE8C2.tmp
2013/10/23:19:50:23    Richard    RT_PC    Launch
2013/10/23:19:50:24    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:19:50:24    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIE8C2.tmp\Setup\AcSetup.dll
2013/10/23:19:50:24    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/23:19:50:26    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/23:19:54:48    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/23:19:54:48    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/23:19:54:48    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/23:19:55:23    Richard    RT_PC    PageOpen    FullProgressDialog
2013/10/23:19:55:24    Richard    RT_PC    Download    Skipped    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:19:55:24    Richard    RT_PC    Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/23:19:57:35    Richard    RT_PC    Install    DirectX Runtime    Failed    Failure is ignored, Result=-9
2013/10/23:19:57:35    Richard    RT_PC    Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/23:19:57:56    Richard    RT_PC    Install    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/23:19:58:39    Richard    RT_PC    Download    Play    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:19:59:56    Richard    RT_PC    Download Error    CM    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:21:04    Richard    RT_PC    Download    User Resume    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:21:36    Richard    RT_PC    Download Error    CM    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:22:07    Richard    RT_PC    Download    User Resume    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:22:47    Richard    RT_PC    Download Error    CM    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:30:30    Richard    RT_PC    Download Error    CM    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:34:09    Richard    RT_PC    Download    Complete    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:34:09    Richard    RT_PC    Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/23:20:34:47    Richard    RT_PC    Install    Autodesk Material Library 2014    Succeeded
2013/10/23:20:35:38    Richard    RT_PC    Download    Play    CMILB    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:39:42    Richard    RT_PC    Download    Complete    CMILB    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:39:42    Richard    RT_PC    Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/23:20:40:08    Richard    RT_PC    Install    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/10/23:20:40:09    Richard    RT_PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/23:20:40:24    Richard    RT_PC    Install    Autodesk Content Service    Succeeded
2013/10/23:20:40:26    Richard    RT_PC    Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/23:20:40:35    Richard    RT_PC    Install    Autodesk Content Service Language Pack    Succeeded
2013/10/23:20:41:21    Richard    RT_PC    Download    Play    ACAD    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:42:38    Richard    RT_PC    Download Error    ACAD    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:20:48:03    Richard    RT_PC    Download Error    ACAD    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:21:08:49    Richard    RT_PC    Download    Complete    ACAD    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/23:21:08:50    Richard    RT_PC    Installing Autodesk® AutoCAD® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AIE8C2.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/23:21:09:13    Richard    RT_PC    Install    Autodesk® AutoCAD® 2014    Failed    Installation aborted, Result=1603
2013/10/23:21:09:24    Richard    RT_PC    Rollback    Autodesk Content Service Language Pack    Succeeded
2013/10/23:21:09:47    Richard    RT_PC    Rollback    Autodesk Content Service    Succeeded
2013/10/23:21:10:33    Richard    RT_PC    Rollback    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/10/23:21:11:44    Richard    RT_PC    Rollback    Autodesk Material Library 2014    Succeeded
2013/10/23:21:11:49    Richard    RT_PC    Rollback    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/23:21:11:50    Richard    RT_PC    PageOpen    InstallCompleteDialog
2013/10/23:21:25:11    Richard    RT_PC    === Setup ended ===
2013/10/24:19:30:36    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/24:19:30:36    Richard    RT_PC    Path_Length: 155
2013/10/24:19:30:36    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/24:19:30:36    Richard    RT_PC    Launch
2013/10/24:19:30:36    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/24:19:30:36    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI6414.tmp
2013/10/24:19:31:35    Richard    RT_PC    === Setup ended ===
2013/10/24:19:30:50    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/24:19:30:50    Richard    RT_PC    Path_Length: 155
2013/10/24:19:30:50    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI6414.tmp
2013/10/24:19:30:50    Richard    RT_PC    Launch
2013/10/24:19:31:34    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:19:31:34    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI6414.tmp\Setup\AcSetup.dll
2013/10/24:19:31:34    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/24:19:31:35    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/24:19:31:46    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/24:19:31:46    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/24:19:32:02    Richard    RT_PC    PageOpen    FullProgressDialog
2013/10/24:19:32:02    Richard    RT_PC    Installing Network License Manager:  ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/24:19:32:05    Richard    RT_PC    Install    Network License Manager    Succeeded
2013/10/24:19:32:48    Richard    RT_PC    Download    Play    CADM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:19:40:01    Richard    RT_PC    Download    Complete    CADM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:19:40:01    Richard    RT_PC    Installing Autodesk CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/24:19:40:06    Richard    RT_PC    Install    Autodesk CAD Manager Tools    Succeeded
2013/10/24:19:40:06    Richard    RT_PC    PageOpen    InstallCompleteDialog
2013/10/24:19:43:07    Richard    RT_PC    === Setup ended ===
2013/10/24:19:44:15    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/24:19:44:15    Richard    RT_PC    Path_Length: 155
2013/10/24:19:44:15    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/24:19:44:15    Richard    RT_PC    Launch
2013/10/24:19:44:15    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/24:19:44:15    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AID434.tmp
2013/10/24:19:45:01    Richard    RT_PC    === Setup ended ===
2013/10/24:19:44:34    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/24:19:44:34    Richard    RT_PC    Path_Length: 155
2013/10/24:19:44:34    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AID434.tmp
2013/10/24:19:44:34    Richard    RT_PC    Launch
2013/10/24:19:45:00    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:19:45:00    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AID434.tmp\Setup\AcSetup.dll
2013/10/24:19:45:00    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/24:19:45:01    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/24:20:00:04    Richard    RT_PC    === Setup ended ===
2013/10/24:22:17:59    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/24:22:17:59    Richard    RT_PC    Path_Length: 155
2013/10/24:22:17:59    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/24:22:17:59    Richard    RT_PC    Launch
2013/10/24:22:17:59    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/24:22:17:59    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIA1A3.tmp
2013/10/24:22:18:45    Richard    RT_PC    === Setup ended ===
2013/10/24:22:18:16    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/24:22:18:16    Richard    RT_PC    Path_Length: 155
2013/10/24:22:18:16    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIA1A3.tmp
2013/10/24:22:18:16    Richard    RT_PC    Launch
2013/10/24:22:18:41    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:18:41    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIA1A3.tmp\Setup\AcSetup.dll
2013/10/24:22:18:41    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/24:22:18:43    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/24:22:19:21    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/24:22:19:21    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/24:22:19:21    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/24:22:24:27    Richard    RT_PC    PageOpen    FullProgressDialog
2013/10/24:22:24:28    Richard    RT_PC    Download    Skipped    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:24:28    Richard    RT_PC    Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/24:22:26:24    Richard    RT_PC    Install    DirectX Runtime    Succeeded
2013/10/24:22:26:24    Richard    RT_PC    Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/24:22:26:44    Richard    RT_PC    Install    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/24:22:26:44    Richard    RT_PC    Download    Skipped    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:26:44    Richard    RT_PC    Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/24:22:27:29    Richard    RT_PC    Install    Autodesk Material Library 2014    Succeeded
2013/10/24:22:27:29    Richard    RT_PC    Download    Skipped    CMILB    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:27:29    Richard    RT_PC    Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/24:22:28:02    Richard    RT_PC    Install    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/10/24:22:28:02    Richard    RT_PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/24:22:28:15    Richard    RT_PC    Install    Autodesk Content Service    Succeeded
2013/10/24:22:28:17    Richard    RT_PC    Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/24:22:28:22    Richard    RT_PC    Install    Autodesk Content Service Language Pack    Succeeded
2013/10/24:22:28:22    Richard    RT_PC    Download    Skipped    ACAD    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/24:22:28:23    Richard    RT_PC    Installing Autodesk® AutoCAD® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AIA1A3.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/24:23:38:54    Richard    RT_PC    Install    Autodesk® AutoCAD® 2014    Failed    Installation aborted, Result=1602
2013/10/24:23:39:01    Richard    RT_PC    Rollback    Autodesk Content Service Language Pack    Succeeded
2013/10/24:23:39:17    Richard    RT_PC    Rollback    Autodesk Content Service    Succeeded
2013/10/24:23:40:08    Richard    RT_PC    Rollback    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/10/24:23:41:47    Richard    RT_PC    Rollback    Autodesk Material Library 2014    Succeeded
2013/10/24:23:41:53    Richard    RT_PC    Rollback    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/24:23:41:53    Richard    RT_PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/10/24:23:41:54    Richard    RT_PC    PageOpen    InstallCompleteDialog
2013/10/24:23:46:46    Richard    RT_PC    === Setup ended ===
2013/10/25:19:30:05    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/25:19:30:05    Richard    RT_PC    Path_Length: 155
2013/10/25:19:30:05    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/25:19:30:05    Richard    RT_PC    Launch
2013/10/25:19:30:05    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/25:19:30:05    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI48D2.tmp
2013/10/25:19:30:58    Richard    RT_PC    === Setup ended ===
2013/10/25:19:30:37    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/25:19:30:37    Richard    RT_PC    Path_Length: 155
2013/10/25:19:30:37    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI48D2.tmp
2013/10/25:19:30:37    Richard    RT_PC    Launch
2013/10/25:19:30:37    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:30:38    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI48D2.tmp\Setup\AcSetup.dll
2013/10/25:19:30:38    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/25:19:30:54    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/25:19:32:04    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/25:19:32:04    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/25:19:32:04    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/25:19:39:52    Richard    RT_PC    PageOpen    FullProgressDialog
2013/10/25:19:39:52    Richard    RT_PC    Download    Skipped    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:39:52    Richard    RT_PC    Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/25:19:41:53    Richard    RT_PC    Install    DirectX Runtime    Succeeded
2013/10/25:19:41:53    Richard    RT_PC    Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:19:42:17    Richard    RT_PC    Install    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/25:19:42:38    Richard    RT_PC    Download    Skipped    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:42:38    Richard    RT_PC    Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:19:43:17    Richard    RT_PC    Install    Autodesk Material Library 2014    Succeeded
2013/10/25:19:43:44    Richard    RT_PC    Download    Skipped    CMILB    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:43:44    Richard    RT_PC    Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:19:44:09    Richard    RT_PC    Install    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/10/25:19:44:10    Richard    RT_PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:19:44:26    Richard    RT_PC    Install    Autodesk Content Service    Succeeded
2013/10/25:19:44:26    Richard    RT_PC    Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:19:44:34    Richard    RT_PC    Install    Autodesk Content Service Language Pack    Succeeded
2013/10/25:19:44:34    Richard    RT_PC    Download    Skipped    ACAD    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:19:44:35    Richard    RT_PC    Installing Autodesk® AutoCAD® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AI48D2.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:19:45:13    Richard    RT_PC    Install    Autodesk® AutoCAD® 2014    Failed    Installation aborted, Result=1602
2013/10/25:19:45:19    Richard    RT_PC    Rollback    Autodesk Content Service Language Pack    Succeeded
2013/10/25:19:45:41    Richard    RT_PC    Rollback    Autodesk Content Service    Succeeded
2013/10/25:19:46:30    Richard    RT_PC    Rollback    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/10/25:19:48:14    Richard    RT_PC    Rollback    Autodesk Material Library 2014    Succeeded
2013/10/25:19:48:16    Richard    RT_PC    Rollback    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/25:19:48:16    Richard    RT_PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/10/25:19:48:17    Richard    RT_PC    PageOpen    InstallCompleteDialog
2013/10/25:20:00:42    Richard    RT_PC    === Setup ended ===
2013/10/25:20:03:07    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/25:20:03:07    Richard    RT_PC    Path_Length: 155
2013/10/25:20:03:07    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/25:20:03:07    Richard    RT_PC    Launch
2013/10/25:20:03:07    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/25:20:03:07    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI87E5.tmp
2013/10/25:20:04:02    Richard    RT_PC    === Setup ended ===
2013/10/25:20:03:47    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/25:20:03:47    Richard    RT_PC    Path_Length: 155
2013/10/25:20:03:47    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI87E5.tmp
2013/10/25:20:03:47    Richard    RT_PC    Launch
2013/10/25:20:03:49    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:03:49    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI87E5.tmp\Setup\AcSetup.dll
2013/10/25:20:03:49    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/25:20:03:53    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/25:20:04:57    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/25:20:04:57    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/25:20:04:57    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/25:20:05:04    Richard    RT_PC    PageOpen    FullProgressDialog
2013/10/25:20:05:04    Richard    RT_PC    Download    Skipped    DIRECTX    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:05:04    Richard    RT_PC    Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/25:20:06:25    Richard    RT_PC    Install    DirectX Runtime    Succeeded
2013/10/25:20:06:25    Richard    RT_PC    Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:20:06:42    Richard    RT_PC    Install    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/25:20:06:42    Richard    RT_PC    Download    Skipped    CM    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:06:42    Richard    RT_PC    Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:20:07:17    Richard    RT_PC    Install    Autodesk Material Library 2014    Succeeded
2013/10/25:20:07:17    Richard    RT_PC    Download    Skipped    CMILB    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:07:17    Richard    RT_PC    Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:20:07:42    Richard    RT_PC    Install    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/10/25:20:07:42    Richard    RT_PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:20:08:00    Richard    RT_PC    Install    Autodesk Content Service    Succeeded
2013/10/25:20:08:00    Richard    RT_PC    Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:20:08:08    Richard    RT_PC    Install    Autodesk Content Service Language Pack    Succeeded
2013/10/25:20:08:08    Richard    RT_PC    Download    Skipped    ACAD    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:08:10    Richard    RT_PC    Installing Autodesk® AutoCAD® 2014:  TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AI87E5.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/10/25:20:16:35    Richard    RT_PC    Install    Autodesk® AutoCAD® 2014    Succeeded    Reboot is required
2013/10/25:20:17:21    Richard    RT_PC    Download    Play    ACAD_en-us    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:18:38    Richard    RT_PC    Download Error    ACAD_en-us    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:20:58    Richard    RT_PC    Download    Aborted    ACAD_en-us    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:20:20:58    Richard    RT_PC    Install    AutoCAD® 2014 Language Pack    Failed    Download Failed, Installation aborted, Result=1603
2013/10/25:20:25:03    Richard    RT_PC    Rollback    Autodesk® AutoCAD® 2014    Succeeded
2013/10/25:20:25:10    Richard    RT_PC    Rollback    Autodesk Content Service Language Pack    Succeeded
2013/10/25:20:25:23    Richard    RT_PC    Rollback    Autodesk Content Service    Succeeded
2013/10/25:20:26:06    Richard    RT_PC    Rollback    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/10/25:20:27:39    Richard    RT_PC    Rollback    Autodesk Material Library 2014    Succeeded
2013/10/25:20:27:44    Richard    RT_PC    Rollback    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/10/25:20:27:44    Richard    RT_PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/10/25:20:27:45    Richard    RT_PC    PageOpen    InstallCompleteDialog
2013/10/25:20:41:13    Richard    RT_PC    === Setup ended ===
2013/10/25:21:26:19    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/25:21:26:19    Richard    RT_PC    Path_Length: 155
2013/10/25:21:26:19    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/25:21:26:19    Richard    RT_PC    Launch
2013/10/25:21:26:19    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/25:21:26:19    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI3AAF.tmp
2013/10/25:21:27:16    Richard    RT_PC    === Setup ended ===
2013/10/25:21:26:39    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/25:21:26:39    Richard    RT_PC    Path_Length: 155
2013/10/25:21:26:39    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI3AAF.tmp
2013/10/25:21:26:39    Richard    RT_PC    Launch
2013/10/25:21:27:01    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:21:27:02    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI3AAF.tmp\Setup\AcSetup.dll
2013/10/25:21:27:02    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/25:21:27:04    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/25:22:25:04    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/25:22:25:04    Richard    RT_PC    Path_Length: 155
2013/10/25:22:25:04    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AICA04.tmp
2013/10/25:22:25:04    Richard    RT_PC    Launch
2013/10/25:22:25:05    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/25:22:25:05    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AICA04.tmp\Setup\AcSetup.dll
2013/10/25:22:25:05    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/25:22:25:07    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/25:22:24:49    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/25:22:24:49    Richard    RT_PC    Path_Length: 155
2013/10/25:22:24:49    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/25:22:24:49    Richard    RT_PC    Launch
2013/10/25:22:24:49    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/25:22:24:49    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AICA04.tmp
2013/10/25:22:25:43    Richard    RT_PC    === Setup ended ===
2013/10/26:11:50:06    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/26:11:50:06    Richard    RT_PC    Path_Length: 155
2013/10/26:11:50:06    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/26:11:50:06    Richard    RT_PC    Launch
2013/10/26:11:50:06    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/26:11:50:06    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIC062.tmp
2013/10/26:11:51:00    Richard    RT_PC    === Setup ended ===
2013/10/26:11:50:28    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/26:11:50:28    Richard    RT_PC    Path_Length: 155
2013/10/26:11:50:28    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIC062.tmp
2013/10/26:11:50:28    Richard    RT_PC    Launch
2013/10/26:11:50:31    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/26:11:50:32    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIC062.tmp\Setup\AcSetup.dll
2013/10/26:11:50:32    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/26:11:50:35    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/26:11:53:24    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/26:11:53:24    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/26:11:53:24    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/26:11:53:42    Richard    RT_PC    === Setup ended ===
2013/10/26:11:59:01    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/26:11:59:01    Richard    RT_PC    Path_Length: 155
2013/10/26:11:59:01    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIC294.tmp
2013/10/26:11:59:01    Richard    RT_PC    Launch
2013/10/26:11:59:23    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/26:11:59:24    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIC294.tmp\Setup\AcSetup.dll
2013/10/26:11:59:24    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/26:11:59:25    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/26:11:58:50    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/26:11:58:50    Richard    RT_PC    Path_Length: 155
2013/10/26:11:58:50    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/26:11:58:50    Richard    RT_PC    Launch
2013/10/26:11:58:50    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/26:11:58:50    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIC294.tmp
2013/10/26:11:59:42    Richard    RT_PC    === Setup ended ===
2013/10/26:11:59:30    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/26:11:59:30    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/26:11:59:30    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/26:12:00:05    Richard    RT_PC    === Setup ended ===
2013/10/29:19:31:26    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/29:19:31:26    Richard    RT_PC    Path_Length: 155
2013/10/29:19:31:26    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/29:19:31:26    Richard    RT_PC    Launch
2013/10/29:19:31:26    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/29:19:31:26    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI2FC1.tmp
2013/10/29:19:32:34    Richard    RT_PC    === Setup ended ===
2013/10/29:19:31:44    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/29:19:31:44    Richard    RT_PC    Path_Length: 155
2013/10/29:19:31:44    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI2FC1.tmp
2013/10/29:19:31:44    Richard    RT_PC    Launch
2013/10/29:19:31:48    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/29:19:32:02    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI2FC1.tmp\Setup\AcSetup.dll
2013/10/29:19:32:02    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/29:19:32:07    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/29:19:32:56    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/29:19:32:57    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/29:19:32:57    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/29:19:36:16    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/29:19:36:16    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/29:19:36:16    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/29:19:36:18    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/29:19:36:18    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/29:19:36:18    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/29:19:41:26    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/29:19:41:27    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/29:19:41:27    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/29:19:41:28    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/29:19:41:28    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/29:19:41:28    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/29:19:41:30    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/29:19:41:30    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/29:19:41:30    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/29:19:41:34    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/29:19:41:34    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/29:19:41:43    Richard    RT_PC    === Setup ended ===
2013/10/29:19:46:25    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/29:19:46:25    Richard    RT_PC    Path_Length: 155
2013/10/29:19:46:25    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI72F8.tmp
2013/10/29:19:46:25    Richard    RT_PC    Launch
2013/10/29:19:46:27    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7...
2013/10/29:19:46:28    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI72F8.tmp\Setup\AcSetup.dll
2013/10/29:19:46:28    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/29:19:46:34    Richard    RT_PC    PageOpen    LaunchDialog
2013/10/29:19:45:54    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/10/29:19:45:54    Richard    RT_PC    Path_Length: 155
2013/10/29:19:45:54    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/10/29:19:45:54    Richard    RT_PC    Launch
2013/10/29:19:45:54    Richard    RT_PC    CommandLine    /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_... /SN 900-42610702 /PK 001F1 /student /skipEULA /akamai /auth  /sid
2013/10/29:19:45:54    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI72F8.tmp
2013/10/29:19:46:56    Richard    RT_PC    === Setup ended ===
2013/10/29:19:46:53    Richard    RT_PC    PageOpen    LicenseDialog
2013/10/29:19:46:53    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/10/29:19:46:54    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/10/29:19:47:50    Richard    RT_PC    === Setup ended ===
2013/11/5:09:33:28    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:09:33:28    Richard    RT_PC    Path_Length: 155
2013/11/5:09:33:28    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:09:33:28    Richard    RT_PC    Launch
2013/11/5:09:33:28    Richard    RT_PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student  /akamai /auth authparam /sid SESSION_ID
2013/11/5:09:33:28    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIE4D0.tmp
2013/11/5:09:40:51    Richard    RT_PC    === Setup ended ===
2013/11/5:09:33:50    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:09:33:50    Richard    RT_PC    Path_Length: 155
2013/11/5:09:33:50    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIE4D0.tmp
2013/11/5:09:33:50    Richard    RT_PC    Launch
2013/11/5:09:37:01    Richard    RT_PC    Download    Play    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:09:38:18    Richard    RT_PC    Download Error    SETUP_CONFIG    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:09:40:49    Richard    RT_PC    Download    Complete    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:09:40:50    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIE4D0.tmp\Setup\AcSetup.dll
2013/11/5:09:40:50    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:09:40:51    Richard    RT_PC    PageOpen    LaunchDialog
2013/11/5:09:46:18    Richard    RT_PC    PageOpen    LicenseDialog
2013/11/5:09:49:42    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/11/5:09:49:43    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/11/5:09:50:07    Richard    RT_PC    PageOpen    FullProgressDialog
2013/11/5:09:52:58    Richard    RT_PC    Download    Play    VCREDIST2008SP1X64_6161    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST2008...
2013/11/5:09:54:27    Richard    RT_PC    Download Error    VCREDIST2008SP1X64_6161    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST2008...
2013/11/5:09:56:43    Richard    RT_PC    Download    User Cancel    VCREDIST2008SP1X64_6161    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST2008...
2013/11/5:09:56:43    Richard    RT_PC    PageOpen    InstallCompleteDialog
2013/11/5:09:56:44    Richard    RT_PC    Download    Aborted    VCREDIST2008SP1X64_6161    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/VCREDIST2008...
2013/11/5:09:56:51    Richard    RT_PC    === Setup ended ===
2013/11/5:10:14:53    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:10:14:53    Richard    RT_PC    Path_Length: 155
2013/11/5:10:14:53    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI5C12.tmp
2013/11/5:10:14:53    Richard    RT_PC    Launch
2013/11/5:10:14:59    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:10:15:17    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI5C12.tmp\Setup\AcSetup.dll
2013/11/5:10:15:17    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:10:15:25    Richard    RT_PC    PageOpen    LaunchDialog
2013/11/5:10:14:24    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:10:14:24    Richard    RT_PC    Path_Length: 155
2013/11/5:10:14:24    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:10:14:24    Richard    RT_PC    Launch
2013/11/5:10:14:24    Richard    RT_PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student  /akamai /auth authparam /sid SESSION_ID
2013/11/5:10:14:24    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI5C12.tmp
2013/11/5:10:15:58    Richard    RT_PC    === Setup ended ===
2013/11/5:10:15:47    Richard    RT_PC    PageOpen    LicenseDialog
2013/11/5:10:24:37    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/11/5:10:24:37    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/11/5:10:29:15    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/11/5:10:29:16    Richard    RT_PC    PageOpen    LicenseDialog
2013/11/5:10:29:17    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/11/5:10:29:17    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/11/5:10:29:26    Richard    RT_PC    === Setup ended ===
2013/11/5:16:51:08    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:16:51:08    Richard    RT_PC    Path_Length: 155
2013/11/5:16:51:08    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:16:51:08    Richard    RT_PC    Launch
2013/11/5:16:51:08    Richard    RT_PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student  /akamai /auth authparam /sid SESSION_ID
2013/11/5:16:51:08    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI942A.tmp
2013/11/5:16:52:15    Richard    RT_PC    === Setup ended ===
2013/11/5:16:51:30    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:16:51:30    Richard    RT_PC    Path_Length: 155
2013/11/5:16:51:30    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI942A.tmp
2013/11/5:16:51:30    Richard    RT_PC    Launch
2013/11/5:16:52:14    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:16:52:14    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI942A.tmp\Setup\AcSetup.dll
2013/11/5:16:52:14    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:16:52:15    Richard    RT_PC    PageOpen    LaunchDialog
2013/11/5:17:59:46    Richard    RT_PC    PageOpen    LicenseDialog
2013/11/5:17:59:57    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/11/5:17:59:57    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/11/5:18:00:16    Richard    RT_PC    === Setup ended ===
2013/11/5:21:12:38    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:21:12:38    Richard    RT_PC    Path_Length: 155
2013/11/5:21:12:38    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:21:12:38    Richard    RT_PC    Launch
2013/11/5:21:12:38    Richard    RT_PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student  /akamai /auth authparam /sid SESSION_ID
2013/11/5:21:12:38    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIFBD6.tmp
2013/11/5:21:13:42    Richard    RT_PC    === Setup ended ===
2013/11/5:21:12:48    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:21:12:48    Richard    RT_PC    Path_Length: 155
2013/11/5:21:12:48    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIFBD6.tmp
2013/11/5:21:12:48    Richard    RT_PC    Launch
2013/11/5:21:12:48    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:21:12:49    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIFBD6.tmp\Setup\AcSetup.dll
2013/11/5:21:12:49    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:21:12:52    Richard    RT_PC    PageOpen    LaunchDialog
2013/11/5:21:13:50    Richard    RT_PC    PageOpen    LicenseDialog
2013/11/5:21:16:19    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/11/5:21:16:19    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/11/5:21:16:39    Richard    RT_PC    PageOpen    FullProgressDialog
2013/11/5:21:16:43    Richard    RT_PC    Download    Play    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.tar....
2013/11/5:21:18:00    Richard    RT_PC    Download Error    DIRECTX    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.tar....
2013/11/5:21:22:16    Richard    RT_PC    Download    Complete    DIRECTX    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.tar....
2013/11/5:21:22:16    Richard    RT_PC    Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/11/5:21:25:40    Richard    RT_PC    Install    DirectX Runtime    Succeeded
2013/11/5:21:25:40    Richard    RT_PC    Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/5:21:26:13    Richard    RT_PC    Install    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/11/5:21:28:34    Richard    RT_PC    Download    Play    CM    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:29:54    Richard    RT_PC    Download Error    CM    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:30:57    Richard    RT_PC    Download    User Resume    CM    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:31:35    Richard    RT_PC    Download Error    CM    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:35:50    Richard    RT_PC    Download    Complete    CM    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzma2
2013/11/5:21:35:50    Richard    RT_PC    Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/5:21:36:45    Richard    RT_PC    Install    Autodesk Material Library 2014    Succeeded
2013/11/5:21:38:44    Richard    RT_PC    Download    Play    CMILB    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:40:01    Richard    RT_PC    Download Error    CMILB    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:41:47    Richard    RT_PC    Download    User Resume    CMILB    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:42:18    Richard    RT_PC    Download Error    CMILB    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:42:21    Richard    RT_PC    Download    User Resume    CMILB    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:45:26    Richard    RT_PC    Download    Complete    CMILB    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CMILB.tar.lz...
2013/11/5:21:45:26    Richard    RT_PC    Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/5:21:45:47    Richard    RT_PC    Install    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/11/5:21:45:47    Richard    RT_PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/5:21:46:04    Richard    RT_PC    Install    Autodesk Content Service    Succeeded
2013/11/5:21:46:05    Richard    RT_PC    Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/5:21:46:16    Richard    RT_PC    Install    Autodesk Content Service Language Pack    Succeeded
2013/11/5:21:48:46    Richard    RT_PC    Download    Play    ACAD    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:50:15    Richard    RT_PC    Download Error    ACAD    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:50:20    Richard    RT_PC    Download    User Resume    ACAD    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:50:52    Richard    RT_PC    Download Error    ACAD    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:50:55    Richard    RT_PC    Download    User Resume    ACAD    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:51:26    Richard    RT_PC    Download Error    ACAD    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:51:28    Richard    RT_PC    Download    User Resume    ACAD    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:52:00    Richard    RT_PC    Download Error    ACAD    <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now?     http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:21:52:09    Richard    RT_PC    Download    User Resume    ACAD    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:22:03:26    Richard    RT_PC    Download    Aborted    ACAD    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/ACAD_x64.tar...
2013/11/5:22:03:26    Richard    RT_PC    Install    Autodesk® AutoCAD® 2014    Failed    Download Failed, Installation aborted, Result=1603
2013/11/5:22:03:55    Richard    RT_PC    Rollback    Autodesk Content Service Language Pack    Succeeded
2013/11/5:22:04:29    Richard    RT_PC    Rollback    Autodesk Content Service    Succeeded
2013/11/5:22:05:40    Richard    RT_PC    Rollback    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/11/5:22:07:51    Richard    RT_PC    Rollback    Autodesk Material Library 2014    Succeeded
2013/11/5:22:07:57    Richard    RT_PC    Rollback    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/11/5:22:07:58    Richard    RT_PC    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2013/11/5:22:07:58    Richard    RT_PC    PageOpen    InstallCompleteDialog
2013/11/5:22:09:07    Richard    RT_PC    === Setup ended ===
2013/11/5:22:12:40    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:22:12:40    Richard    RT_PC    Path_Length: 155
2013/11/5:22:12:40    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/11/5:22:12:40    Richard    RT_PC    Launch
2013/11/5:22:12:40    Richard    RT_PC    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup.ex... /SN 900-42610702 /PK 001F1 /student  /akamai /auth authparam /sid SESSION_ID
2013/11/5:22:12:40    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIF5A0.tmp
2013/11/5:22:14:04    Richard    RT_PC    === Setup ended ===
2013/11/5:22:13:00    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/5:22:13:00    Richard    RT_PC    Path_Length: 155
2013/11/5:22:13:00    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AIF5A0.tmp
2013/11/5:22:13:00    Richard    RT_PC    Launch
2013/11/5:22:13:25    Richard    RT_PC    Download    Skipped    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64.ta...
2013/11/5:22:13:28    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AIF5A0.tmp\Setup\AcSetup.dll
2013/11/5:22:13:28    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/5:22:13:32    Richard    RT_PC    PageOpen    LaunchDialog
2013/11/5:22:14:25    Richard    RT_PC    PageOpen    LicenseDialog
2013/11/5:22:14:29    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/11/5:22:14:29    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/11/5:22:14:42    Richard    RT_PC    === Setup ended ===
2013/11/6:13:00:08    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/6:13:00:08    Richard    RT_PC    Path_Length: 155
2013/11/6:13:00:08    Richard    RT_PC    Current Directory C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm
2013/11/6:13:00:08    Richard    RT_PC    Launch
2013/11/6:13:00:08    Richard    RT_PC    CommandLine
2013/11/6:13:00:08    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI76F0.tmp
2013/11/6:13:02:11    Richard    RT_PC    === Setup ended ===
2013/11/6:13:00:38    Richard    RT_PC    === Setup started on RT_PC by Richard ===
2013/11/6:13:00:38    Richard    RT_PC    Path_Length: 155
2013/11/6:13:00:38    Richard    RT_PC    Current Directory C:\Users\Richard\AppData\Local\Temp\_AI76F0.tmp
2013/11/6:13:00:38    Richard    RT_PC    Launch
2013/11/6:13:00:39    Richard    RT_PC    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Richard\AppData\Local\Temp\_AI76F0.tmp\Setup\AcSetup.dll
2013/11/6:13:00:39    Richard    RT_PC    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/6:13:01:04    Richard    RT_PC    PageOpen    LaunchDialog
2013/11/6:13:01:14    Richard    RT_PC    PageOpen    LicenseDialog
2013/11/6:13:01:19    Richard    RT_PC    PageOpen    ProductInfoDialog
2013/11/6:13:02:18    Richard    RT_PC    PageOpen    ProductSelectionDialog2
2013/11/6:13:02:27    Richard    RT_PC    PageOpen    FullProgressDialog
2013/11/6:13:02:29    Richard    RT_PC    Installing DirectX Runtime: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2013/11/6:13:18:31    Richard    RT_PC    Install    DirectX Runtime    Failed    Failure is ignored, Result=-9
2013/11/6:13:18:31    Richard    RT_PC    Installing FARO LS 5.1.0.30630 (64bit):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/6:13:19:01    Richard    RT_PC    Install    FARO LS 5.1.0.30630 (64bit)    Succeeded
2013/11/6:13:19:01    Richard    RT_PC    Installing Autodesk Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/6:13:19:49    Richard    RT_PC    Install    Autodesk Material Library 2014    Succeeded
2013/11/6:13:19:50    Richard    RT_PC    Installing Autodesk Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/6:13:20:17    Richard    RT_PC    Install    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/11/6:13:20:17    Richard    RT_PC    Installing Autodesk Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/6:13:20:33    Richard    RT_PC    Install    Autodesk Content Service    Succeeded
2013/11/6:13:20:34    Richard    RT_PC    Installing Autodesk Content Service Language Pack:  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/6:13:20:49    Richard    RT_PC    Install    Autodesk Content Service Language Pack    Succeeded
2013/11/6:13:20:50    Richard    RT_PC    Installing Autodesk® AutoCAD® 2014:  TRANSFORMS="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\x64\en-us\acad\acad.mst;C:\Users\Richard\AppData\Local\Temp\_AI76F0.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2014\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/11/6:13:34:22    Richard    RT_PC    Install    Autodesk® AutoCAD® 2014    Failed    Installation aborted, Result=1603
2013/11/6:13:34:33    Richard    RT_PC    Rollback    Autodesk Content Service Language Pack    Succeeded
2013/11/6:13:35:12    Richard    RT_PC    Rollback    Autodesk Content Service    Succeeded
2013/11/6:13:36:09    Richard    RT_PC    Rollback    Autodesk Material Library 2014 - Base Image Library    Succeeded
2013/11/6:13:38:37    Richard    RT_PC    Rollback    Autodesk Material Library 2014    Succeeded
2013/11/6:13:38:44    Richard    RT_PC    Rollback    FARO LS 5.1.0.30630 (64bit)    Succeeded
i tried browser download and install now, it still failed
1 REPLY 1
aaronhai
in reply to: r_tj
Hi r_tj,
Welcome to Autodesk Discussion Group.
Please attempt a re-download via the Virtual Agent within our support.
*Select [Downloading and Installation] --> [Software Download Links] --> [I need to redownload my product] --> Then select the product you wish to download.
More importantly, please refer to the below article on the permission required and restrictions to avoid, in order to facilitate a smooth installation.
Thank you.
Aaron Hai
Administrator Productivity
