Installation & Licensing
AutoCAD 2014 stuck on loading
14 REPLIES 14
Message 1 of 15
ruipfbarreiros
7163 Views, 14 Replies
In my office we have an Autodesk Building Design Suite with several licenses available, both standalone and network.
The problem is that there's one computer which can't open Autocad 2014 with a standalone license: it gets stuck on loading in the splash screen.
Every other computer which has the same software works fine. We tried to reinstall the building design suite, we even formatted the hard drive but the problem still remains..
The thing is, if we disconnect the pc from the network, it opens autocad...
What may be the problem?
What more information on this error should I give you?
Using Building Design Suite 2019
14 REPLIES 14
Message 2 of 15
anyone?
Message 3 of 15
pendean
in reply to: ruipfbarreiros
Grab some free Windows tools to monitor activities while that PC is connected to the network and identify what is hanging the program. Something like Microsoft's Process Monitor freeware etc.
Message 4 of 15
Yong.Jing
Have you tried this solution? http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD...
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Message 5 of 15
ruipfbarreiros
in reply to: Yong.Jing
sorry for the delay....
yes, I did try the method suggested but to no avail...I did a clean uninstall of all autodesk products as they suggest, including registry data and hidden files in programdata folder and so on...
But the problem remains...autocad opens for the first time, but when I turn the pc off and then back on, it gets stuck on loading again....
I don't know what to do now...there should be no problem with the license file, because here in our company we have 9 licenses and only 5 are in use...We have both network and standalone licenses and neither seems to work on this particular PC....
do you think a format will solve the problem?
Message 6 of 15
pendean
Stop turning off your PC and see if the problem reappears.
Message 7 of 15
strangely, Revit works but all autocad products dont'! I'm installing Building Design Suite Premium...
why would Revit open but autocad not? Do these products have different activation methods or something?
edit: In fact, all products in the suite work except for AutoCAD's (Vanilla, Architecture, MEP....)
Message 8 of 15
pendean
Apples and Oranges comparisons are meaningless: REVIT is not AutoCAD etc. You might as well be comparing Photoshop and Microsoft Office. Unrelated.
Message 9 of 15
ruipfbarreiros
in reply to: pendean
If both Revit and Autocad are installed through the same suite and share the same licensing method the comparison is not meaningless in what licensing is concerned...
But nevermind...I figured out that the problem is with the user profile which might somehow got corrupted...
Message 10 of 15
pendean
Sorry, but licensing and 'bundling' has nothing to do with the two very different software.
Glad you found the real issue.
Message 11 of 15
ruipfbarreiros
well, at least I thought I did.....now the new profile causes autocad to get stuck again....
guess i'll have to give a go at format c:....
Message 12 of 15
ckcbernabe
Hi i have the same problem with my PC and Design suite. Were you able to solve the problem and may i know how?Thanks
Message 13 of 15
mwilkinsonls2
in reply to: ckcbernabe
Sounds like it might need a interent connection. You could try installing fidler and checking the traffic. Though last time I looked autocad didn't like proxies. Do the users have modify permissions to c:\program files\autodesk ?
Message 14 of 15
Burtlebe
in reply to: mwilkinsonls2
For anyone having this issue after installing windows 10. If you have a network user name, right click the autodesk under c:\program files and adding your network user name to security and give yourself full premissions.
Message 15 of 15
ruipfbarreiros
in reply to: Burtlebe
I'm glad you're still replying after all this time!
I recently found out why I was having such troubles with autocad. It turns out that something is wrong with the deployment of printers from the server, somehow causing autocad to fail to open up. I come to this conclusion because when Autocad is stuck at "loading", if I restart the "spooler" service, autocad magically comes alive and finishes loading.
I hope this may help anyone who might be having the same problem. I don't think this will solve all the problems with "Autocad loading" because I realized that there may be several explanations for this behaviour...
Administrator Productivity
