I can't install Autocad, the installer I downloaded does not launch in my computer. There's no error messages. I deactivated firewall and antivirus uac, cleaned temp folder...
In the log file in temp folder there's allways the same message:
2014/11/2:18:52:50 === Logging started ===
2014/11/2:18:52:50 Opened store success.
2014/11/2:18:52:50 Certificate not found, registering.
2014/11/2:18:52:50 Unregistering the certificate.
Can somebody help me? Thanks
Solved by david.lau. Go to Solution.
Can you try a browser download of your AutoCAD product from the Virtual Agent?
https://screencast.autodesk.com/main/details/be571ea9-fffc-40d6-8338-e0e7a3d82a3b
