Installation & Licensing
Autocad 2014 network License unable to take server name
3 REPLIES 3
pritamcad
2507 Views, 3 Replies
i have configure network license on server sucessfully but when i m installing on client giving the server name, it was not taking and next tab is non higlighted. this server is on different VLanes ports. please help me on this issue.
3 REPLIES 3
TravisNave
in reply to: pritamcad
You can type the server name in and it will work.
Autodesk Forums:
pritamcad
in reply to: TravisNave
I typed server name but its not coming.
Sent from my iPhone
TravisNave
Then use IP address or pick any other server listed.  It doesn't matter because you can change the LICPATH.LIC file after install or create an ADSKFLEX_LICENSE_FILE system environment variable to override the installation setting.
Autodesk Forums:
Administrator Productivity
