We've installed Autocad 2014 Lt on 2 Windows XP PRO Sp3 PCs, both installations went well, but as soon as we start the software, it will halt on loading plug-in, specifically ACCOREMGD.DLL.
On one Pc, before the installation, we removed Autocad 2008 LT and on both we cleaned registry, user folder, program folder and temporary folders.
VGA Card Drivers and Windows XP are up to date, even .Net Framework 4.
The problem still happens on both PCs.
Is there any solution for this issue?
Kind regards.
Mirko
Hi I am having the same issue. Starts with the main load window, and immediately get a windows program stopped working error with APPCRASH as the event name.
I've seen this happen if you are running a real-time antivirus like Avast. You might disable the anti-virus and see if it makes any difference. Also, did you migrate any programming stuff from 2008 when you loaded 2014?
Hello, this computer does not have any anti-virus and the machine is not infected.
Unfortunately, I have not yet found a solution.
@Anonymous wrote:
I have to same problem. AUTOCAD 2014 a Windows 7 32bit.
Please HELP.
Create an exception for your AutoCAD in your anti-virus or disable it.
