Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
AutoCAD 2014 Installation Failure
9 REPLIES 9
Message 1 of 10
E.aguilar111
493 Views, 9 Replies
Hello, I have just purchased this new Lenovo laptop and it is set up to run with the AutoCAD suite. I have been trying to install the trial version of AutoCAD for about 3 hours....every time I am receiving an error message due to Communication failure. Help!
9 REPLIES 9
Message 2 of 10
JoAnn_Hogan
in reply to: E.aguilar111
HI There,
Welcome to the community,
Ok so when you are trying to install the software, what are you using? CD,USB or downloading it?
If this post solved your issue please mark as solved and Kudos are always welcome šŸ˜ƒ
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 10
pendean
In addition to the questions above...
Are you connected to the internet directly, or through a server? hardwired, or wireless?
Is your firewall and anti-virus temporarily disabled?
Are you logged into Windows are full Administrator?
Win8.1?
Message 4 of 10
JoAnn_Hogan
in reply to: pendean
Please ensure the following has been done:
1. Computer meets the minimum requirements
2. UAC off
3. Firewall off
4. Anti-Virus off
5. Administrator rights
6. Clear the temp folder
7. Make sure you have enough disc space 60 Gigs at least
8. Make sure the OS is up to date
9. Reinstall C++ redistributable
10. Reinstall .Net Framework
11. Copy the content of the installation media to the C drive. Preferably on the root of the C drive to negate the problem of filenames becoming too long
12. Make sure short file name creation has been enabled HKEY_LOCAL_MACHINE\SYSTEM\
CurrentControlSet\Control\FileSystem Set NtfsDisable8dot3NameCreation to a value of 0
13. Create a new Windows user with full admin rights
14. If the computer is on a domain remove it from the network completely for the duration of installation
Jo - Ann
Message 5 of 10
jim58funai
I'm trying to install AutoDesk AutoCad 2014, bought student version from e-Bay, and am also getting a communications failure. I disabled firewall security and AV. It's not listed in "programs & features", but it does show on my "C" drive. I don't use social media and can be contacted via e-mail at: jim58funai@gmail.com or call at 607-621-8338. I've re-enabled security until I can get help with the installation. Thanks
Message 6 of 10
JoAnn_Hogan
in reply to: jim58funai
Hi Jim,
Please post this as a different post, so we can follow if it has been solved and not get convused with the two different queries.
Follow this link to create a new post: http://forums.autodesk.com/t5/forums/postpage/board-id/24
Jo - Ann
Message 7 of 10
jim58funai
in reply to: JoAnn_Hogan
I"m not a computer whiz, but I'm OK with #1, 3-8; I don't know what "UAC" means. I don't know anything about #9-13?
Message 8 of 10
pendean
You got robbed: Sutdent software is free to all legitemate students direct from Autodesk. Get a refund right away.
Message 9 of 10
pendean
What is UAC: http://windows.microsoft.com/en-us/windows/what-is-user-account-control#1TC=windows-7
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCADĀ® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
More complete .NET fix if you need it as noted above:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Message 10 of 10
pendean
Administrator Productivity
