Installation & Licensing
AutoCAD 2014 installation error
4 REPLIES 4
FEI_Jennifer
317 Views, 4 Replies
I'm trying to download and install AutoCAD 2014 and I continue to get this error message.
I've tried different download methods, I've cleaned out the temp folder, blocked cookies, and all the other suggestions I've read about.
Any help on this would be appreciated.
4 REPLIES 4
TravisNave
in reply to: FEI_Jennifer
The problem is with your Trend Micro antivirus.  Disable it and reinstall your Autodesk software.  It should work.
http://esupport.trendmicro.com/solution/en-US/1096841.aspx
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
FEI_Jennifer
in reply to: TravisNave
I disabled the antivirus software, restarted, cleaned out the temp folder, redownloaded AutoCAD and tried installing and ended up getting the same error message. 😞
TravisNave
Do you have Trend Micro?  If so, you might check that link I posted to find more information on this known work-around.
If it does end up being the download itself, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
FEI_Jennifer
Travis,
I don't have Trend Micro on this computer.
I tried downloading through the virtual assistant and then installing. I ended up with the same error message. 😞
Any other ideas?
Jenn
Administrator Productivity
