I've been trying to install 2014 on a new machine after deleting it from an old machine. I cannot get past the net framework part of the installation. It crashes everytime. Any ideas on how to get past this? My install log is below.
2014/11/13:11:04:46 rdsAdmin RDS008W813-2014 === Setup started on RDS008W813-2014 by rdsAdmin ===
2014/11/13:11:04:46 rdsAdmin RDS008W813-2014 Path_Length: 155
2014/11/13:11:04:46 rdsAdmin RDS008W813-2014 Current Directory C:\Users\RDSadmin\AppData\Local\Temp\_AIABD7.tmp
2014/11/13:11:04:46 rdsAdmin RDS008W813-2014 Launch
2014/11/13:11:04:46 rdsAdmin RDS008W813-2014 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\RDSadmin\AppData\Local\Temp\_AIABD7.tmp\Setup\AcSetup.dll
2014/11/13:11:04:46 rdsAdmin RDS008W813-2014 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/11/13:11:04:47 rdsAdmin RDS008W813-2014 PageOpen LaunchDialog
2014/11/13:11:04:49 rdsAdmin RDS008W813-2014 PageOpen LicenseDialog
2014/11/13:11:04:52 rdsAdmin RDS008W813-2014 PageOpen ProductInfoDialog
2014/11/13:11:05:06 rdsAdmin RDS008W813-2014 PageOpen ProductSelectionDialog2
2014/11/13:11:05:08 rdsAdmin RDS008W813-2014 PageOpen FullProgressDialog
2014/11/13:11:05:08 rdsAdmin RDS008W813-2014 Installing .NET Framework Runtime 3.5 SP1: "C:\Autodesk\AutoCAD_2014_English_Win_64bit_dlm\3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe"
2014/11/13:11:06:20 rdsAdmin RDS008W813-2014 Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
If you are installing on Windows 8, you need to install the .NET 3.5 from the Control Panel. It's a Windows add-in.
