My name is Koen and I am using AutoCad 2014 as a student. Recently my laptop suggested me to update to Windows 8.1. I was using Windows 8 before and AutoCad 2014 was working just fine. However after I installed the update and tried to launch AutoCad it came up with this error:
FATAL ERROR: Unhandled Acces Violating Reading 0x0020 Exception at 83194c12h
I contacted the Autodesk Customer Care about this error and they came up with some steps. I have tried all of those steps but sadly none of these worked with succes. They told me this:
I see it crashed at the video driver, could you try the following workarounds and Which one works for you?
1. Update the video driver to latest version.
2. If you have dual video cards, try to switch the AutoCAD to run on another video card.
3. If it still doesn't work for above 2 options, try to disable the video card in Windows Device Manager.
I still have the same error. They advised me to place a forum post on this forum to ask the professionals for help. So thats why I am here.
I am planning to downgrade my Windows back to Windows 8 and see if this might solve the problem but first I wanted to hear what the professionals think about this issue.
I am hoping to get a reply a.s.a.p.
Kind Regards,
Koen Reinders
Student
there are several suggestions
read through these: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=windows+8.1&search_submi...
DarrenP
You can try these 2 suggestions as well.
http://upandready.typepad.com/up_and_ready/2012/07/the-easiest-way-to-reset-autocad.html
