We have purchased an Autocad 2014 education licence, it has installed fine, but when we try to activate the product we have run into some problems.
Firstly i cannot activate over the inernet, the first attached screeen grab shows the message. We have an unblocked working internet connection.
We then tried to Request an activation code using an offline method. But the system just stops here (2nd screen grab below), there is no form to complete:
Any help would be great!
Hi gjs010 and welcome to the Autodesk Community!
Please contact our Activation and Registration department with your request code to reach your activation code:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus.
4. Select “I Still Need Help” if you need personal assistance.
If you have any other questions or concerns please respond to this post. Thank you!
Hi, still having problems.
Trying to do an offline activation because for whatever reason Autodesk cannot detect my internet connection. However I cannot find the "Request form" to insert my "Request code" that I should find by browsing to http://www.autodesk.com/productlicensesupport_en
Could someone send me the direct link to this form?
Using the above link, I click on "Stand alone licence" click "Activate and Register" then i reach a dead end with no sign of this request form.
This link confuses me also:
http://knowledge.autodesk.com/support-topics/483/486#OfflineActivation After clicking Next on step 3, i dont get what the window in step 4 says, all i get is the following message:
Using a computer with an Internet connection, request an activation code for your product license by completing the following request form. Be prepared to provide the Product, Serial Number, Product Key, and Request Code(above).
The URL in this message does not take me to any request form.
Hi @Anonymous,
Please send me a private message with your request code and serial number and I will generate an activation code.
Then please follow these directions on how to manually activate your Autodesk product using an activation code which might be easier to follow.
Thank you,
