Installation & Licensing
Autocad 2014 crashes during inital startup.
1 REPLY 1
ivor
2204 Views, 1 Reply
Autocad 2014 crashes with a message "Configuration file may be locked by another process or file is set as read only". This occured after deployment to the client workstation. I can't even find the ACAD2014.CFG file in the specified directory. The computer is a 32bit with an Intel I5 processor and 4GB of ram. Is there something I missed in the deployment setups?
Thanks in advance
1 REPLY 1
TravisNave
in reply to: ivor
You probably have UAC set too high or the user does not have local admin rights.  This is easily fixable.
http://upandready.typepad.com/up_and_ready/2012/05/autocad-family-configuration-file-may-be-locked-b...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
