Installation & Licensing
Active Member
ivor
Message 1 of 2 (1,596 Views)
Autocad 2014 crashes during inital startup.
1596 Views, 1 Replies
08-29-2013 12:51 PM
Autocad 2014 crashes with a message "Configuration file may be locked by another process or file is set as read only". This occured after deployment to the client workstation. I can't even find the ACAD2014.CFG file in the specified directory. The computer is a 32bit with an Intel I5 processor and 4GB of ram. Is there something I missed in the deployment setups?
Thanks in advance
You probably have UAC set too high or the user does not have local admin rights.  This is easily fixable.
http://upandready.typepad.com/up_and_ready/2012/05/autocad-family-configuration-file-may-be-locked-by-another-process-or-have-been-set-read-only-cfg-bak.html
Good Luck!
TravisNave
Message 2 of 2 (1,589 Views)
Re: Autocad 2014 crashes during inital startup.
08-29-2013 01:17 PM in reply to: ivor
http://upandready.typepad.com/up_and_ready/2012/05/autocad-family-configuration-file-may-be-locked-b...
Good Luck!
