Installation & Licensing
Autocad 2014 and VMware View Horizon issue
4 REPLIES 4
4123 Views, 4 Replies
Autocad 2014 and VMware View Horizon issue. We have the following architecture: - SAN FC 8GB - Server biprocessor with 192GB RAM and NVIDIA Grid K1 configured as vSGA - VMware View 5.3 in linked clones configuration - Windows 7 64 bit - AutoCAD 2014 -- LAN gigabit - Terminal Wyse P25 Tera2 Test settings on the architecture above: one pool with max video RAM and one VM active only. Issue:, the mouse pointer is lagging and not working as desired in the users Autodesk MAP 3D 2014 application. We checked with VMware’s engineer that there was no latency shown by the PCOIP. I ask to you if someone know this issue and if exist some solution. Let me know your implementations. Thanks Enrico
4 REPLIES 4
TravisNave
This environment is unsupported and is a violation of the license agreement.  You will not receive technical support for this setup.  If you wish to use virtualization, you need to comply with the Citrix solution.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13959101
Autodesk Forums:
in reply to: TravisNave
Hello Travis, I understand, now Autocad is used in phisical workstations, and VMware is used for servers and desktops virtualization, so we can't virtualize workstations. Ok, do you know if in the future Autodesk will agree a partnership with VMware ? Many thanks. Enrico
TravisNave
I agree with you completely. But unfortunately, I do not know if or when that might happen.
Autodesk Forums:
Hi Travis, thanks for your support. Best regards, Enrico
Administrator Productivity
