Installation & Licensing
AutoCAD 2014 (64 bit) Crashing Issues
2 REPLIES 2
BetoHGI
3192 Views, 2 Replies
AutoCAD 2014 (64 bit) randomly crashes on my new dell windows 7 PC. This has happened when I have the program minimized, opening a file, running a command, etc. I don't know what triggers it.
Here's the error message I get
Problem signature:
Problem Event Name: BEX64
Application Name: acad.exe
Application Version: 25.1.18.0
Application Timestamp: 5114be09
Fault Module Name: StackHash_1e37
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 0000000067b465fe
Exception Code: c0000005
Exception Data: 0000000000000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 1e37
Additional Information 2: 1e373e69fff075aed81f57003e66ce10
Additional Information 3: 9f0e
Additional Information 4: 9f0e095f32a88249d7a2b7eca4e322ea
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linki...
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Any ideas on what is causing this?
2 REPLIES 2
BetoHGI
in reply to: BetoHGI
Here's another I just recieved, it's slightly different
Problem signature:
Fault Module Name: QtCore_Ad_SyncNs_4.dll_unloaded
Fault Module Timestamp: 50d3fca7
Exception Offset: 0000000064f665fe
Locale ID: 1033
Additional Information 1: 76a1
Additional Information 2: 76a173c26a6dc2e3cd83ac8fd9f8bdb9
Additional Information 3: dc79
Additional Information 4: dc79fb03c3da55dd42136843462c88c6
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
TravisNave
You might check the BIOS  to see if Optimus is enabled. If so, disable it.  We had to do that on our new Dells as well.  After that, reinstall the latest WHQL certified video driver.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
