Installation & Licensing
AutoCAD 2013 won't install
3 REPLIES 3
jody_vaclav
8866 Views, 3 Replies
I hope someone could help me. I'm trying to install AutoCAD 2013 on my laptop computer and the installation is failing.
I presently have 2010 installed and working and TONS of space for the new program. It's a 64 bit system runing Windows 7. This is the contents of the Failure log:
2012/4/24:15:45:58 jvaclav SPPSNLTP2013165 === Setup started on SPPSNLTP2013165 by jvaclav ===
2012/4/24:15:45:58 jvaclav SPPSNLTP2013165 Launch
2012/4/24:15:47:18 jvaclav SPPSNLTP2013165 === Setup ended ===
2012/4/24:15:46:11 jvaclav SPPSNLTP2013165 === Setup started on SPPSNLTP2013165 by jvaclav ===
2012/4/24:15:46:11 jvaclav SPPSNLTP2013165 Launch
2012/4/24:15:47:11 jvaclav SPPSNLTP2013165 PageOpen LaunchDialog
2012/4/24:15:47:13 jvaclav SPPSNLTP2013165 PageOpen LicenseDialog
2012/4/24:15:47:17 jvaclav SPPSNLTP2013165 PageOpen ProductInfoDialog
2012/4/24:15:47:54 jvaclav SPPSNLTP2013165 PageOpen ProductSelectionDialog2
2012/4/24:15:48:16 jvaclav SPPSNLTP2013165 PageOpen FullProgressDialog
2012/4/24:15:48:17 jvaclav SPPSNLTP2013165 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\TEMP\vcredist_x86_2010.log
2012/4/24:15:48:48 jvaclav SPPSNLTP2013165 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/4/24:15:48:48 jvaclav SPPSNLTP2013165 Installing .NET Framework Runtime 4.0: D:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/4/24:15:51:10 jvaclav SPPSNLTP2013165 Install .NET Framework Runtime 4.0 Succeeded
2012/4/24:15:51:10 jvaclav SPPSNLTP2013165 Installing .NET Framework Runtime 4.0 KB2468871: D:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/4/24:15:57:25 jvaclav SPPSNLTP2013165 Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2012/4/24:15:57:25 jvaclav SPPSNLTP2013165 Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\TEMP\_AI39C5.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/4/24:15:58:54 jvaclav SPPSNLTP2013165 Install Autodesk® Design Review 2013 Succeeded
2012/4/24:15:58:54 jvaclav SPPSNLTP2013165 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/4/24:15:59:01 jvaclav SPPSNLTP2013165 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2012/4/24:15:59:01 jvaclav SPPSNLTP2013165 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\TEMP\vcredist_x64_2010.log
2012/4/24:15:59:11 jvaclav SPPSNLTP2013165 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/4/24:15:59:11 jvaclav SPPSNLTP2013165 Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/24:15:59:49 jvaclav SPPSNLTP2013165 Install DirectX Runtime Succeeded
2012/4/24:15:59:50 jvaclav SPPSNLTP2013165 Installing FaroSDK:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\TEMP\_AI39C5.tmp\Media.mst"
 2012/4/24:15:59:53 jvaclav SPPSNLTP2013165 Install FaroSDK Failed Failure is ignored, Result=1618
2012/4/24:15:59:53 jvaclav SPPSNLTP2013165 Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\TEMP\_AI39C5.tmp\Media.mst"
 2012/4/24:15:59:56 jvaclav SPPSNLTP2013165 Install Autodesk Material Library 2013 Failed Installation aborted, Result=1618
2012/4/24:15:59:59 jvaclav SPPSNLTP2013165 Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2012/4/24:16:00:03 jvaclav SPPSNLTP2013165 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1618
2012/4/24:16:00:06 jvaclav SPPSNLTP2013165 Rollback Autodesk® Design Review 2013 Failed Failure is ignored, Result=1618
2012/4/24:16:00:10 jvaclav SPPSNLTP2013165 Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1618
2012/4/24:16:00:13 jvaclav SPPSNLTP2013165 Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1618
2012/4/24:16:00:16 jvaclav SPPSNLTP2013165 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1618
2012/4/24:16:00:46 jvaclav SPPSNLTP2013165 PageOpen InstallCompleteDialog
2012/4/24:16:02:39 jvaclav SPPSNLTP2013165 === Setup ended ===
2012/4/24:16:03:02 jvaclav SPPSNLTP2013165 === Setup started on SPPSNLTP2013165 by jvaclav ===
2012/4/24:16:03:02 jvaclav SPPSNLTP2013165 Launch
2012/4/24:16:03:10 jvaclav SPPSNLTP2013165 === Setup ended ===
2012/4/24:16:03:05 jvaclav SPPSNLTP2013165 === Setup started on SPPSNLTP2013165 by jvaclav ===
2012/4/24:16:03:05 jvaclav SPPSNLTP2013165 Launch
2012/4/24:16:03:08 jvaclav SPPSNLTP2013165 PageOpen LaunchDialog
2012/4/24:16:03:11 jvaclav SPPSNLTP2013165 PageOpen LicenseDialog
2012/4/24:16:03:14 jvaclav SPPSNLTP2013165 PageOpen ProductInfoDialog
2012/4/24:16:03:45 jvaclav SPPSNLTP2013165 PageOpen ProductSelectionDialog2
2012/4/24:16:03:51 jvaclav SPPSNLTP2013165 PageOpen FullProgressDialog
2012/4/24:16:03:51 jvaclav SPPSNLTP2013165 Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/24:16:04:02 jvaclav SPPSNLTP2013165 Install DirectX Runtime Succeeded
2012/4/24:16:04:02 jvaclav SPPSNLTP2013165 Installing FaroSDK:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\TEMP\_AID98C.tmp\Media.mst"
 2012/4/24:16:04:05 jvaclav SPPSNLTP2013165 Install FaroSDK Failed Failure is ignored, Result=1618
2012/4/24:16:04:05 jvaclav SPPSNLTP2013165 Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\TEMP\_AID98C.tmp\Media.mst"
 2012/4/24:16:04:08 jvaclav SPPSNLTP2013165 Install Autodesk Material Library 2013 Failed Installation aborted, Result=1618
2012/4/24:16:04:12 jvaclav SPPSNLTP2013165 Rollback DirectX Runtime Failed Failure is ignored, Result=1618
Any idea what this even mean?
Thanks in advance for the help.
3 REPLIES 3
TravisNave
in reply to: jody_vaclav
It's failing on the Material Library.  You might uninstall your old materials library first then try to install again.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
jody_vaclav
in reply to: TravisNave
Thanks so much! ... I uninstalled AutoCAD 2010 and then installed AutoCAD 2013 and everything went in like clockwork.
I'm so happy!! Thanks again!
jctstudio
I'm having the same issue.  The installation gets to AutoCAD 2013 and then fails.  I tried unistalling the materials library first but that didn't work.  I have the rest of the BDSP installed, but ACAD 2013 just won't.  Any help would be greatly appreciated.  Here's my log file:
2012/10/2:16:56:34 omar HILLS === Setup started on HILLS by omar === 2012/10/2:16:56:34 omar HILLS Launch 2012/10/2:16:56:59 omar HILLS === Setup ended ===
2012/10/2:16:56:40 omar HILLS === Setup started on HILLS by omar === 2012/10/2:16:56:40 omar HILLS Launch 2012/10/2:16:56:57 omar HILLS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2012/10/2:16:56:59 omar HILLS PageOpen LaunchDialog   2012/10/2:17:16:04 omar HILLS PageOpen LicenseDialog   2012/10/2:17:16:08 omar HILLS PageOpen ProductInfoDialog   2012/10/2:17:19:02 omar HILLS PageOpen ProductSelectionDialog2   2012/10/2:17:25:59 omar HILLS PageOpen FullProgressDialog   2012/10/2:17:26:00 omar HILLS Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:26:32 omar HILLS Install Autodesk® Design Review 2013 Succeeded  2012/10/2:17:26:32 omar HILLS Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\omar\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/10/2:17:26:43 omar HILLS Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded  2012/10/2:17:26:43 omar HILLS Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\x64\VCRedist\2005\vcredist_x64.exe /q:a /T:C:\windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\omar\AppData\Local\Temp\vcredist_x64_2005.log"" " 2012/10/2:17:26:49 omar HILLS Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded  2012/10/2:17:26:49 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:26:52 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded  2012/10/2:17:26:52 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:26:59 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded  2012/10/2:17:26:59 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:05 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded  2012/10/2:17:27:05 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:10 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded  2012/10/2:17:27:10 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:13 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded  2012/10/2:17:27:13 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:20 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded  2012/10/2:17:27:20 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:26 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded  2012/10/2:17:27:26 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:31 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded  2012/10/2:17:27:31 omar HILLS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\omar\AppData\Local\Temp\vcredist_x86_2005_atl.log"" " 2012/10/2:17:27:46 omar HILLS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded  2012/10/2:17:27:46 omar HILLS Installing DirectX® Runtime: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/2:17:29:16 omar HILLS Install DirectX® Runtime Succeeded  2012/10/2:17:29:16 omar HILLS Installing FaroSDK: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/2:17:29:47 omar HILLS Install FaroSDK Succeeded  2012/10/2:17:29:48 omar HILLS Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\RVT2013\RVT2013.mst;C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:37:51 omar HILLS Install Autodesk® Revit® 2013 Succeeded  2012/10/2:17:37:55 omar HILLS Installing Autodesk® Revit® 2013 Language Pack:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\_laF227.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:38:20 omar HILLS Install Autodesk® Revit® 2013 Language Pack Succeeded  2012/10/2:17:38:22 omar HILLS Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:38:30 omar HILLS Install Web Services Enhancements (WSE) 3.0 for Microsoft .NET Succeeded  2012/10/2:17:38:30 omar HILLS Installing Autodesk® Navisworks® Simulate 2013:  TRANSFORMS="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\NAVSIM\roamer.mst;C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\NAVSIM\roamer-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Simulate 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:44:18 omar HILLS Install Autodesk® Navisworks® Simulate 2013 Succeeded  2012/10/2:17:44:19 omar HILLS Installing Autodesk® Navisworks® Simulate 2013 Language Pack:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\_laD97B.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Simulate 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:44:28 omar HILLS Install Autodesk® Navisworks® Simulate 2013 Language Pack Succeeded  2012/10/2:17:44:29 omar HILLS Installing Navisworks® Simulate 2013 - 2013 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:44:52 omar HILLS Install Navisworks® Simulate 2013 - 2013 DWG File Reader Succeeded  2012/10/2:17:44:52 omar HILLS Installing Navisworks® Simulate 2013 - 2012 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:45:17 omar HILLS Install Navisworks® Simulate 2013 - 2012 DWG File Reader Succeeded  2012/10/2:17:45:18 omar HILLS Installing Navisworks® Simulate 2013 - 2011 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:45:41 omar HILLS Install Navisworks® Simulate 2013 - 2011 DWG File Reader Succeeded  2012/10/2:17:45:41 omar HILLS Installing Navisworks® Simulate 2013 - 2010 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:45:58 omar HILLS Install Navisworks® Simulate 2013 - 2010 DWG File Reader Succeeded  2012/10/2:17:45:59 omar HILLS Installing Navisworks® Simulate 2013 - 2009 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:46:18 omar HILLS Install Navisworks® Simulate 2013 - 2009 DWG File Reader Succeeded  2012/10/2:17:46:19 omar HILLS Installing Navisworks® Simulate 2013 - 2008 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:46:28 omar HILLS Install Navisworks® Simulate 2013 - 2008 DWG File Reader Succeeded  2012/10/2:17:46:28 omar HILLS Installing Autodesk Material Library 2013 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:47:30 omar HILLS Install Autodesk Material Library 2013 - Low Image Library Succeeded  2012/10/2:17:47:38 omar HILLS Installing Autodesk Material Library 2013 - Medium Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:48:22 omar HILLS Install Autodesk Material Library 2013 - Medium Image Library Succeeded  2012/10/2:17:48:23 omar HILLS Installing Autodesk® DirectConnect 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:50:03 omar HILLS Install Autodesk® DirectConnect 2013 Succeeded  2012/10/2:17:50:08 omar HILLS Installing Autodesk® 3ds Max® Design 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\max\3dsMaxDesign2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max Design 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:59:07 omar HILLS Install Autodesk® 3ds Max® Design 2013 Succeeded  2012/10/2:17:59:07 omar HILLS Installing Autodesk® FBX Plug-in 2013: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x86\Components\FBX\fbx20130_3dsmaxDesign2013_win.exe /S 2012/10/2:17:59:07 omar HILLS Install Autodesk® FBX Plug-in 2013 Failed Failure is ignored, Result=2 2012/10/2:17:59:09 omar HILLS Installing Autodesk® Showcase® 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\Showcase\AutodeskShowcase7.0-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:07:53 omar HILLS Install Autodesk® Showcase® 2013 Succeeded  2012/10/2:18:07:54 omar HILLS Installing Autodesk Workflows - Building Design Suite 2013:  SUITES_TYPE=Premium ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:08:01 omar HILLS Install Autodesk Workflows - Building Design Suite 2013 Succeeded  2012/10/2:18:08:03 omar HILLS Installing AutoCAD® Architecture 2013:  TRANSFORMS="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\ACA\ACA.mst;C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:09:41 omar HILLS Install AutoCAD® Architecture 2013 Succeeded  2012/10/2:18:09:42 omar HILLS Installing AutoCAD® Architecture 2013 Language Pack:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\_la17B7.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:10:16 omar HILLS Install AutoCAD® Architecture 2013 Language Pack Succeeded  2012/10/2:18:10:17 omar HILLS Installing AutoCAD® Architecture 2013 Product Specific Pack:  INSTALLSHORTCUTS=0 CP_SELECTED="" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:16:39 omar HILLS Install AutoCAD® Architecture 2013 Product Specific Pack Succeeded  2012/10/2:18:16:40 omar HILLS Installing Autodesk® SketchBook® Designer 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\SBD\SBD-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\SketchBookDesigner2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:22:01 omar HILLS Install Autodesk® SketchBook® Designer 2013 Succeeded  2012/10/2:18:22:07 omar HILLS Installing Autodesk® SketchBook® Designer for AutoCAD® 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\SBDACAD\SBDACAD-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\ApplicationPlugins\SBD.bundle\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:22:48 omar HILLS Install Autodesk® SketchBook® Designer for AutoCAD® 2013 Succeeded  2012/10/2:18:22:56 omar HILLS Installing Autodesk® Backburner 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:23:33 omar HILLS Install Autodesk® Backburner 2013 Succeeded  2012/10/2:18:23:34 omar HILLS Installing Autodesk Inventor Server Engine For 3ds Max Design 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:24:29 omar HILLS Install Autodesk Inventor Server Engine For 3ds Max Design 2013 Succeeded  2012/10/2:18:24:29 omar HILLS Installing 3dsMax Composite 2013:   INSTALLDIR="C:\Program Files\Autodesk\Composite 2013\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:26:37 omar HILLS Install 3dsMax Composite 2013 Succeeded  2012/10/2:18:26:38 omar HILLS Installing Autodesk® Revit Interoperability for 3ds Max 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:28:12 omar HILLS Install Autodesk® Revit Interoperability for 3ds Max 2013 Succeeded  2012/10/2:18:28:20 omar HILLS Installing Autodesk® Civil View 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:29:18 omar HILLS Install Autodesk® Civil View 2013 Succeeded  2012/10/2:18:29:19 omar HILLS Installing Autodesk® Essential Skills Movies for 3dsMax Design 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:30:03 omar HILLS Install Autodesk® Essential Skills Movies for 3dsMax Design 2013 Succeeded  2012/10/2:18:30:09 omar HILLS PageOpen InstallCompleteDialog   2012/10/2:18:33:14 omar HILLS === Setup ended ===
2012/10/10:12:03:44 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:03:44 omar HILLS Launch 2012/10/10:12:04:11 omar HILLS === Setup ended ===
2012/10/10:12:03:49 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:03:49 omar HILLS Launch 2012/10/10:12:04:11 omar HILLS PageOpen LaunchDialog   2012/10/10:12:04:17 omar HILLS PageOpen LicenseDialog   2012/10/10:12:04:20 omar HILLS PageOpen ProductInfoDialog   2012/10/10:12:04:47 omar HILLS PageOpen ProductSelectionDialog2   2012/10/10:12:05:02 omar HILLS PageOpen FullProgressDialog   2012/10/10:12:05:02 omar HILLS Installing DirectX® Runtime: I:\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/10:12:06:41 omar HILLS Install DirectX® Runtime Succeeded  2012/10/10:12:06:41 omar HILLS Installing FaroSDK: I:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/10:12:06:48 omar HILLS Install FaroSDK Succeeded  2012/10/10:12:06:48 omar HILLS Installing AutoCAD® 2013:  TRANSFORMS="I:\x64\en-us\acad\acad.mst;C:\Users\omar\AppData\Local\Temp\_AIE62E.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:12:07:29 omar HILLS Install AutoCAD® 2013 Failed Installation aborted, Result=1602 2012/10/10:12:07:29 omar HILLS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/10/10:12:07:30 omar HILLS PageOpen InstallCompleteDialog   2012/10/10:12:07:36 omar HILLS === Setup ended ===
2012/10/10:12:07:37 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:07:37 omar HILLS Launch 2012/10/10:12:07:46 omar HILLS === Setup ended ===
2012/10/10:12:07:38 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:07:38 omar HILLS Launch 2012/10/10:12:07:46 omar HILLS PageOpen LaunchDialog   2012/10/10:12:07:47 omar HILLS PageOpen LicenseDialog   2012/10/10:12:07:50 omar HILLS PageOpen ProductInfoDialog   2012/10/10:12:08:13 omar HILLS PageOpen ProductSelectionDialog2   2012/10/10:12:08:19 omar HILLS PageOpen FullProgressDialog   2012/10/10:12:08:19 omar HILLS Installing DirectX® Runtime: I:\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/10:12:09:23 omar HILLS Install DirectX® Runtime Succeeded  2012/10/10:12:09:23 omar HILLS Installing FaroSDK: I:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/10:12:09:29 omar HILLS Install FaroSDK Succeeded  2012/10/10:12:09:30 omar HILLS Installing AutoCAD® 2013:  TRANSFORMS="I:\x64\en-us\acad\acad.mst;C:\Users\omar\AppData\Local\Temp\_AI7775.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:12:10:02 omar HILLS Install AutoCAD® 2013 Failed Installation aborted, Result=1602 2012/10/10:12:10:02 omar HILLS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/10/10:12:10:03 omar HILLS PageOpen InstallCompleteDialog   2012/10/10:12:10:07 omar HILLS === Setup ended ===
2012/10/10:12:32:45 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:32:45 omar HILLS Launch 2012/10/10:12:32:55 omar HILLS === Setup ended ===
2012/10/10:12:32:46 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:32:46 omar HILLS Launch 2012/10/10:12:32:55 omar HILLS PageOpen LaunchDialog   2012/10/10:12:32:56 omar HILLS PageOpen LicenseDialog   2012/10/10:12:32:58 omar HILLS PageOpen ProductInfoDialog   2012/10/10:12:33:25 omar HILLS PageOpen ProductSelectionDialog2   2012/10/10:12:33:31 omar HILLS PageOpen FullProgressDialog   2012/10/10:12:33:31 omar HILLS Installing DirectX® Runtime: I:\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/10:12:34:46 omar HILLS Install DirectX® Runtime Succeeded  2012/10/10:12:34:46 omar HILLS Installing FaroSDK: I:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/10:12:34:51 omar HILLS Install FaroSDK Succeeded  2012/10/10:12:34:51 omar HILLS Installing AutoCAD® 2013:  TRANSFORMS="I:\x64\en-us\acad\acad.mst;C:\Users\omar\AppData\Local\Temp\_AI4F67.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:12:35:49 omar HILLS Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2012/10/10:12:35:49 omar HILLS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/10/10:12:35:50 omar HILLS PageOpen InstallCompleteDialog   2012/10/10:12:36:30 omar HILLS === Setup ended ===
2012/10/10:12:36:32 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:36:32 omar HILLS Launch 2012/10/10:12:36:41 omar HILLS === Setup ended ===
2012/10/10:12:36:33 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:36:33 omar HILLS Launch 2012/10/10:12:36:41 omar HILLS PageOpen LaunchDialog   2012/10/10:12:36:45 omar HILLS === Setup ended ===
2012/10/10:12:58:49 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:58:49 omar HILLS Launch 2012/10/10:12:59:13 omar HILLS === Setup ended ===
2012/10/10:12:58:54 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:58:54 omar HILLS Launch 2012/10/10:12:59:12 omar HILLS PageOpen LaunchDialog   2012/10/10:12:59:14 omar HILLS PageOpen LicenseDialog   2012/10/10:12:59:16 omar HILLS PageOpen ProductInfoDialog   2012/10/10:12:59:42 omar HILLS PageOpen ProductSelectionDialog2   2012/10/10:12:59:54 omar HILLS PageOpen FullProgressDialog   2012/10/10:12:59:54 omar HILLS Installing DirectX® Runtime: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/10:13:01:03 omar HILLS Install DirectX® Runtime Succeeded  2012/10/10:13:01:03 omar HILLS Installing FaroSDK: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/10:13:01:10 omar HILLS Install FaroSDK Succeeded  2012/10/10:13:01:10 omar HILLS Installing Autodesk Material Library 2013:  MSIFASTINSTALL=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:13:01:26 omar HILLS Install Autodesk Material Library 2013 Succeeded  2012/10/10:13:01:26 omar HILLS Installing AutoCAD® 2013:  TRANSFORMS="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\acad\acad.mst;C:\Users\omar\AppData\Local\Temp\_AI2D18.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:13:02:31 omar HILLS Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2012/10/10:13:02:48 omar HILLS Rollback Autodesk Material Library 2013 Succeeded  2012/10/10:13:02:48 omar HILLS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Thanks!!
Administrator Productivity
