Installation & Licensing
jody_vaclav
Message 1 of 4 (7,800 Views)
AutoCAD 2013 won't install
7800 Views, 3 Replies
04-24-2012 05:07 PM
I hope someone could help me. I'm trying to install AutoCAD 2013 on my laptop computer and the installation is failing.
I presently have 2010 installed and working and TONS of space for the new program. It's a 64 bit system runing Windows 7. This is the contents of the Failure log:
2012/4/24:15:45:58 jvaclav SPPSNLTP2013165 === Setup started on SPPSNLTP2013165 by jvaclav ===
2012/4/24:15:45:58 jvaclav SPPSNLTP2013165 Launch
2012/4/24:15:47:18 jvaclav SPPSNLTP2013165 === Setup ended ===
2012/4/24:15:46:11 jvaclav SPPSNLTP2013165 === Setup started on SPPSNLTP2013165 by jvaclav ===
2012/4/24:15:46:11 jvaclav SPPSNLTP2013165 Launch
2012/4/24:15:47:11 jvaclav SPPSNLTP2013165 PageOpen LaunchDialog
2012/4/24:15:47:13 jvaclav SPPSNLTP2013165 PageOpen LicenseDialog
2012/4/24:15:47:17 jvaclav SPPSNLTP2013165 PageOpen ProductInfoDialog
2012/4/24:15:47:54 jvaclav SPPSNLTP2013165 PageOpen ProductSelectionDialog2
2012/4/24:15:48:16 jvaclav SPPSNLTP2013165 PageOpen FullProgressDialog
2012/4/24:15:48:17 jvaclav SPPSNLTP2013165 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\TEMP\vcredist_x86_2010.log
2012/4/24:15:48:48 jvaclav SPPSNLTP2013165 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2012/4/24:15:48:48 jvaclav SPPSNLTP2013165 Installing .NET Framework Runtime 4.0: D:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/4/24:15:51:10 jvaclav SPPSNLTP2013165 Install .NET Framework Runtime 4.0 Succeeded
2012/4/24:15:51:10 jvaclav SPPSNLTP2013165 Installing .NET Framework Runtime 4.0 KB2468871: D:\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2012/4/24:15:57:25 jvaclav SPPSNLTP2013165 Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2012/4/24:15:57:25 jvaclav SPPSNLTP2013165 Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\TEMP\_AI39C5.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/4/24:15:58:54 jvaclav SPPSNLTP2013165 Install Autodesk® Design Review 2013 Succeeded
2012/4/24:15:58:54 jvaclav SPPSNLTP2013165 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2012/4/24:15:59:01 jvaclav SPPSNLTP2013165 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2012/4/24:15:59:01 jvaclav SPPSNLTP2013165 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\TEMP\vcredist_x64_2010.log
2012/4/24:15:59:11 jvaclav SPPSNLTP2013165 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2012/4/24:15:59:11 jvaclav SPPSNLTP2013165 Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/24:15:59:49 jvaclav SPPSNLTP2013165 Install DirectX Runtime Succeeded
2012/4/24:15:59:50 jvaclav SPPSNLTP2013165 Installing FaroSDK:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\TEMP\_AI39C5.tmp\Media.mst"
 2012/4/24:15:59:53 jvaclav SPPSNLTP2013165 Install FaroSDK Failed Failure is ignored, Result=1618
2012/4/24:15:59:53 jvaclav SPPSNLTP2013165 Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\TEMP\_AI39C5.tmp\Media.mst"
 2012/4/24:15:59:56 jvaclav SPPSNLTP2013165 Install Autodesk Material Library 2013 Failed Installation aborted, Result=1618
2012/4/24:15:59:59 jvaclav SPPSNLTP2013165 Rollback DirectX Runtime Failed Failure is ignored, Result=1618
2012/4/24:16:00:03 jvaclav SPPSNLTP2013165 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1618
2012/4/24:16:00:06 jvaclav SPPSNLTP2013165 Rollback Autodesk® Design Review 2013 Failed Failure is ignored, Result=1618
2012/4/24:16:00:10 jvaclav SPPSNLTP2013165 Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1618
2012/4/24:16:00:13 jvaclav SPPSNLTP2013165 Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1618
2012/4/24:16:00:16 jvaclav SPPSNLTP2013165 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1618
2012/4/24:16:00:46 jvaclav SPPSNLTP2013165 PageOpen InstallCompleteDialog
2012/4/24:16:02:39 jvaclav SPPSNLTP2013165 === Setup ended ===
2012/4/24:16:03:02 jvaclav SPPSNLTP2013165 === Setup started on SPPSNLTP2013165 by jvaclav ===
2012/4/24:16:03:02 jvaclav SPPSNLTP2013165 Launch
2012/4/24:16:03:10 jvaclav SPPSNLTP2013165 === Setup ended ===
2012/4/24:16:03:05 jvaclav SPPSNLTP2013165 === Setup started on SPPSNLTP2013165 by jvaclav ===
2012/4/24:16:03:05 jvaclav SPPSNLTP2013165 Launch
2012/4/24:16:03:08 jvaclav SPPSNLTP2013165 PageOpen LaunchDialog
2012/4/24:16:03:11 jvaclav SPPSNLTP2013165 PageOpen LicenseDialog
2012/4/24:16:03:14 jvaclav SPPSNLTP2013165 PageOpen ProductInfoDialog
2012/4/24:16:03:45 jvaclav SPPSNLTP2013165 PageOpen ProductSelectionDialog2
2012/4/24:16:03:51 jvaclav SPPSNLTP2013165 PageOpen FullProgressDialog
2012/4/24:16:03:51 jvaclav SPPSNLTP2013165 Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/24:16:04:02 jvaclav SPPSNLTP2013165 Install DirectX Runtime Succeeded
2012/4/24:16:04:02 jvaclav SPPSNLTP2013165 Installing FaroSDK:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\TEMP\_AID98C.tmp\Media.mst"
 2012/4/24:16:04:05 jvaclav SPPSNLTP2013165 Install FaroSDK Failed Failure is ignored, Result=1618
2012/4/24:16:04:05 jvaclav SPPSNLTP2013165 Installing Autodesk Material Library 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\TEMP\_AID98C.tmp\Media.mst"
 2012/4/24:16:04:08 jvaclav SPPSNLTP2013165 Install Autodesk Material Library 2013 Failed Installation aborted, Result=1618
2012/4/24:16:04:12 jvaclav SPPSNLTP2013165 Rollback DirectX Runtime Failed Failure is ignored, Result=1618
Any idea what this even mean?
Thanks in advance for the help.
TravisNave
Message 2 of 4 (7,769 Views)
Re: AutoCAD 2013 won't install
04-25-2012 07:08 AM in reply to: jody_vaclav
It's failing on the Material Library.  You might uninstall your old materials library first then try to install again.
jody_vaclav
Message 3 of 4 (7,738 Views)
04-25-2012 10:26 AM in reply to: TravisNave
Thanks so much! ... I uninstalled AutoCAD 2010 and then installed AutoCAD 2013 and everything went in like clockwork.
I'm so happy!! Thanks again!
New Member
jackie
Message 4 of 4 (6,543 Views)
10-10-2012 01:10 PM in reply to: jody_vaclav
I'm having the same issue.  The installation gets to AutoCAD 2013 and then fails.  I tried unistalling the materials library first but that didn't work.  I have the rest of the BDSP installed, but ACAD 2013 just won't.  Any help would be greatly appreciated.  Here's my log file:
2012/10/2:16:56:34 omar HILLS === Setup started on HILLS by omar === 2012/10/2:16:56:34 omar HILLS Launch 2012/10/2:16:56:59 omar HILLS === Setup ended ===
2012/10/2:16:56:40 omar HILLS === Setup started on HILLS by omar === 2012/10/2:16:56:40 omar HILLS Launch 2012/10/2:16:56:57 omar HILLS Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message: 2012/10/2:16:56:59 omar HILLS PageOpen LaunchDialog   2012/10/2:17:16:04 omar HILLS PageOpen LicenseDialog   2012/10/2:17:16:08 omar HILLS PageOpen ProductInfoDialog   2012/10/2:17:19:02 omar HILLS PageOpen ProductSelectionDialog2   2012/10/2:17:25:59 omar HILLS PageOpen FullProgressDialog   2012/10/2:17:26:00 omar HILLS Installing Autodesk® Design Review 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x86\en-us\Components\adr2013\SetupDesignReview2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:26:32 omar HILLS Install Autodesk® Design Review 2013 Succeeded  2012/10/2:17:26:32 omar HILLS Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\omar\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/10/2:17:26:43 omar HILLS Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded  2012/10/2:17:26:43 omar HILLS Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\x64\VCRedist\2005\vcredist_x64.exe /q:a /T:C:\windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\omar\AppData\Local\Temp\vcredist_x64_2005.log"" " 2012/10/2:17:26:49 omar HILLS Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded  2012/10/2:17:26:49 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:26:52 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded  2012/10/2:17:26:52 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:26:59 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded  2012/10/2:17:26:59 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:05 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded  2012/10/2:17:27:05 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:10 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded  2012/10/2:17:27:10 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:13 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded  2012/10/2:17:27:13 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:20 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded  2012/10/2:17:27:20 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:26 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded  2012/10/2:17:27:26 omar HILLS Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:27:31 omar HILLS Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded  2012/10/2:17:27:31 omar HILLS Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\omar\AppData\Local\Temp\vcredist_x86_2005_atl.log"" " 2012/10/2:17:27:46 omar HILLS Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded  2012/10/2:17:27:46 omar HILLS Installing DirectX® Runtime: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/2:17:29:16 omar HILLS Install DirectX® Runtime Succeeded  2012/10/2:17:29:16 omar HILLS Installing FaroSDK: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/2:17:29:47 omar HILLS Install FaroSDK Succeeded  2012/10/2:17:29:48 omar HILLS Installing Autodesk® Revit® 2013:  TRANSFORMS="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\RVT2013\RVT2013.mst;C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:37:51 omar HILLS Install Autodesk® Revit® 2013 Succeeded  2012/10/2:17:37:55 omar HILLS Installing Autodesk® Revit® 2013 Language Pack:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\_laF227.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:38:20 omar HILLS Install Autodesk® Revit® 2013 Language Pack Succeeded  2012/10/2:17:38:22 omar HILLS Installing Web Services Enhancements (WSE) 3.0 for Microsoft .NET:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:38:30 omar HILLS Install Web Services Enhancements (WSE) 3.0 for Microsoft .NET Succeeded  2012/10/2:17:38:30 omar HILLS Installing Autodesk® Navisworks® Simulate 2013:  TRANSFORMS="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\NAVSIM\roamer.mst;C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\NAVSIM\roamer-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Simulate 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:44:18 omar HILLS Install Autodesk® Navisworks® Simulate 2013 Succeeded  2012/10/2:17:44:19 omar HILLS Installing Autodesk® Navisworks® Simulate 2013 Language Pack:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\_laD97B.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\Navisworks Simulate 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:44:28 omar HILLS Install Autodesk® Navisworks® Simulate 2013 Language Pack Succeeded  2012/10/2:17:44:29 omar HILLS Installing Navisworks® Simulate 2013 - 2013 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:44:52 omar HILLS Install Navisworks® Simulate 2013 - 2013 DWG File Reader Succeeded  2012/10/2:17:44:52 omar HILLS Installing Navisworks® Simulate 2013 - 2012 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:45:17 omar HILLS Install Navisworks® Simulate 2013 - 2012 DWG File Reader Succeeded  2012/10/2:17:45:18 omar HILLS Installing Navisworks® Simulate 2013 - 2011 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:45:41 omar HILLS Install Navisworks® Simulate 2013 - 2011 DWG File Reader Succeeded  2012/10/2:17:45:41 omar HILLS Installing Navisworks® Simulate 2013 - 2010 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:45:58 omar HILLS Install Navisworks® Simulate 2013 - 2010 DWG File Reader Succeeded  2012/10/2:17:45:59 omar HILLS Installing Navisworks® Simulate 2013 - 2009 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:46:18 omar HILLS Install Navisworks® Simulate 2013 - 2009 DWG File Reader Succeeded  2012/10/2:17:46:19 omar HILLS Installing Navisworks® Simulate 2013 - 2008 DWG File Reader:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:46:28 omar HILLS Install Navisworks® Simulate 2013 - 2008 DWG File Reader Succeeded  2012/10/2:17:46:28 omar HILLS Installing Autodesk Material Library 2013 - Low Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:47:30 omar HILLS Install Autodesk Material Library 2013 - Low Image Library Succeeded  2012/10/2:17:47:38 omar HILLS Installing Autodesk Material Library 2013 - Medium Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:48:22 omar HILLS Install Autodesk Material Library 2013 - Medium Image Library Succeeded  2012/10/2:17:48:23 omar HILLS Installing Autodesk® DirectConnect 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:50:03 omar HILLS Install Autodesk® DirectConnect 2013 Succeeded  2012/10/2:17:50:08 omar HILLS Installing Autodesk® 3ds Max® Design 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\max\3dsMaxDesign2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max Design 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:17:59:07 omar HILLS Install Autodesk® 3ds Max® Design 2013 Succeeded  2012/10/2:17:59:07 omar HILLS Installing Autodesk® FBX Plug-in 2013: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x86\Components\FBX\fbx20130_3dsmaxDesign2013_win.exe /S 2012/10/2:17:59:07 omar HILLS Install Autodesk® FBX Plug-in 2013 Failed Failure is ignored, Result=2 2012/10/2:17:59:09 omar HILLS Installing Autodesk® Showcase® 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\Showcase\AutodeskShowcase7.0-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\Showcase 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:07:53 omar HILLS Install Autodesk® Showcase® 2013 Succeeded  2012/10/2:18:07:54 omar HILLS Installing Autodesk Workflows - Building Design Suite 2013:  SUITES_TYPE=Premium ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:08:01 omar HILLS Install Autodesk Workflows - Building Design Suite 2013 Succeeded  2012/10/2:18:08:03 omar HILLS Installing AutoCAD® Architecture 2013:  TRANSFORMS="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\ACA\ACA.mst;C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:09:41 omar HILLS Install AutoCAD® Architecture 2013 Succeeded  2012/10/2:18:09:42 omar HILLS Installing AutoCAD® Architecture 2013 Language Pack:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\_la17B7.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:10:16 omar HILLS Install AutoCAD® Architecture 2013 Language Pack Succeeded  2012/10/2:18:10:17 omar HILLS Installing AutoCAD® Architecture 2013 Product Specific Pack:  INSTALLSHORTCUTS=0 CP_SELECTED="" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:16:39 omar HILLS Install AutoCAD® Architecture 2013 Product Specific Pack Succeeded  2012/10/2:18:16:40 omar HILLS Installing Autodesk® SketchBook® Designer 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\SBD\SBD-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\SketchBookDesigner2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:22:01 omar HILLS Install Autodesk® SketchBook® Designer 2013 Succeeded  2012/10/2:18:22:07 omar HILLS Installing Autodesk® SketchBook® Designer for AutoCAD® 2013:  TRANSFORMS="C:\Users\omar\AppData\Local\Temp\_AI2402.tmp\x64\SBDACAD\SBDACAD-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\ApplicationPlugins\SBD.bundle\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:22:48 omar HILLS Install Autodesk® SketchBook® Designer for AutoCAD® 2013 Succeeded  2012/10/2:18:22:56 omar HILLS Installing Autodesk® Backburner 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:23:33 omar HILLS Install Autodesk® Backburner 2013 Succeeded  2012/10/2:18:23:34 omar HILLS Installing Autodesk Inventor Server Engine For 3ds Max Design 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:24:29 omar HILLS Install Autodesk Inventor Server Engine For 3ds Max Design 2013 Succeeded  2012/10/2:18:24:29 omar HILLS Installing 3dsMax Composite 2013:   INSTALLDIR="C:\Program Files\Autodesk\Composite 2013\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:26:37 omar HILLS Install 3dsMax Composite 2013 Succeeded  2012/10/2:18:26:38 omar HILLS Installing Autodesk® Revit Interoperability for 3ds Max 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:28:12 omar HILLS Install Autodesk® Revit Interoperability for 3ds Max 2013 Succeeded  2012/10/2:18:28:20 omar HILLS Installing Autodesk® Civil View 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:29:18 omar HILLS Install Autodesk® Civil View 2013 Succeeded  2012/10/2:18:29:19 omar HILLS Installing Autodesk® Essential Skills Movies for 3dsMax Design 2013:   ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/2:18:30:03 omar HILLS Install Autodesk® Essential Skills Movies for 3dsMax Design 2013 Succeeded  2012/10/2:18:30:09 omar HILLS PageOpen InstallCompleteDialog   2012/10/2:18:33:14 omar HILLS === Setup ended ===
2012/10/10:12:03:44 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:03:44 omar HILLS Launch 2012/10/10:12:04:11 omar HILLS === Setup ended ===
2012/10/10:12:03:49 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:03:49 omar HILLS Launch 2012/10/10:12:04:11 omar HILLS PageOpen LaunchDialog   2012/10/10:12:04:17 omar HILLS PageOpen LicenseDialog   2012/10/10:12:04:20 omar HILLS PageOpen ProductInfoDialog   2012/10/10:12:04:47 omar HILLS PageOpen ProductSelectionDialog2   2012/10/10:12:05:02 omar HILLS PageOpen FullProgressDialog   2012/10/10:12:05:02 omar HILLS Installing DirectX® Runtime: I:\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/10:12:06:41 omar HILLS Install DirectX® Runtime Succeeded  2012/10/10:12:06:41 omar HILLS Installing FaroSDK: I:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/10:12:06:48 omar HILLS Install FaroSDK Succeeded  2012/10/10:12:06:48 omar HILLS Installing AutoCAD® 2013:  TRANSFORMS="I:\x64\en-us\acad\acad.mst;C:\Users\omar\AppData\Local\Temp\_AIE62E.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:12:07:29 omar HILLS Install AutoCAD® 2013 Failed Installation aborted, Result=1602 2012/10/10:12:07:29 omar HILLS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/10/10:12:07:30 omar HILLS PageOpen InstallCompleteDialog   2012/10/10:12:07:36 omar HILLS === Setup ended ===
2012/10/10:12:07:37 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:07:37 omar HILLS Launch 2012/10/10:12:07:46 omar HILLS === Setup ended ===
2012/10/10:12:07:38 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:07:38 omar HILLS Launch 2012/10/10:12:07:46 omar HILLS PageOpen LaunchDialog   2012/10/10:12:07:47 omar HILLS PageOpen LicenseDialog   2012/10/10:12:07:50 omar HILLS PageOpen ProductInfoDialog   2012/10/10:12:08:13 omar HILLS PageOpen ProductSelectionDialog2   2012/10/10:12:08:19 omar HILLS PageOpen FullProgressDialog   2012/10/10:12:08:19 omar HILLS Installing DirectX® Runtime: I:\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/10:12:09:23 omar HILLS Install DirectX® Runtime Succeeded  2012/10/10:12:09:23 omar HILLS Installing FaroSDK: I:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/10:12:09:29 omar HILLS Install FaroSDK Succeeded  2012/10/10:12:09:30 omar HILLS Installing AutoCAD® 2013:  TRANSFORMS="I:\x64\en-us\acad\acad.mst;C:\Users\omar\AppData\Local\Temp\_AI7775.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:12:10:02 omar HILLS Install AutoCAD® 2013 Failed Installation aborted, Result=1602 2012/10/10:12:10:02 omar HILLS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/10/10:12:10:03 omar HILLS PageOpen InstallCompleteDialog   2012/10/10:12:10:07 omar HILLS === Setup ended ===
2012/10/10:12:32:45 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:32:45 omar HILLS Launch 2012/10/10:12:32:55 omar HILLS === Setup ended ===
2012/10/10:12:32:46 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:32:46 omar HILLS Launch 2012/10/10:12:32:55 omar HILLS PageOpen LaunchDialog   2012/10/10:12:32:56 omar HILLS PageOpen LicenseDialog   2012/10/10:12:32:58 omar HILLS PageOpen ProductInfoDialog   2012/10/10:12:33:25 omar HILLS PageOpen ProductSelectionDialog2   2012/10/10:12:33:31 omar HILLS PageOpen FullProgressDialog   2012/10/10:12:33:31 omar HILLS Installing DirectX® Runtime: I:\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/10:12:34:46 omar HILLS Install DirectX® Runtime Succeeded  2012/10/10:12:34:46 omar HILLS Installing FaroSDK: I:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/10:12:34:51 omar HILLS Install FaroSDK Succeeded  2012/10/10:12:34:51 omar HILLS Installing AutoCAD® 2013:  TRANSFORMS="I:\x64\en-us\acad\acad.mst;C:\Users\omar\AppData\Local\Temp\_AI4F67.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="I:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:12:35:49 omar HILLS Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2012/10/10:12:35:49 omar HILLS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/10/10:12:35:50 omar HILLS PageOpen InstallCompleteDialog   2012/10/10:12:36:30 omar HILLS === Setup ended ===
2012/10/10:12:36:32 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:36:32 omar HILLS Launch 2012/10/10:12:36:41 omar HILLS === Setup ended ===
2012/10/10:12:36:33 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:36:33 omar HILLS Launch 2012/10/10:12:36:41 omar HILLS PageOpen LaunchDialog   2012/10/10:12:36:45 omar HILLS === Setup ended ===
2012/10/10:12:58:49 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:58:49 omar HILLS Launch 2012/10/10:12:59:13 omar HILLS === Setup ended ===
2012/10/10:12:58:54 omar HILLS === Setup started on HILLS by omar === 2012/10/10:12:58:54 omar HILLS Launch 2012/10/10:12:59:12 omar HILLS PageOpen LaunchDialog   2012/10/10:12:59:14 omar HILLS PageOpen LicenseDialog   2012/10/10:12:59:16 omar HILLS PageOpen ProductInfoDialog   2012/10/10:12:59:42 omar HILLS PageOpen ProductSelectionDialog2   2012/10/10:12:59:54 omar HILLS PageOpen FullProgressDialog   2012/10/10:12:59:54 omar HILLS Installing DirectX® Runtime: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\DirectX\DXSETUP.exe /silent 2012/10/10:13:01:03 omar HILLS Install DirectX® Runtime Succeeded  2012/10/10:13:01:03 omar HILLS Installing FaroSDK: C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT 2012/10/10:13:01:10 omar HILLS Install FaroSDK Succeeded  2012/10/10:13:01:10 omar HILLS Installing Autodesk Material Library 2013:  MSIFASTINSTALL=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:13:01:26 omar HILLS Install Autodesk Material Library 2013 Succeeded  2012/10/10:13:01:26 omar HILLS Installing AutoCAD® 2013:  TRANSFORMS="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\acad\acad.mst;C:\Users\omar\AppData\Local\Temp\_AI2D18.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/10/10:13:02:31 omar HILLS Install AutoCAD® 2013 Failed Installation aborted, Result=1603 2012/10/10:13:02:48 omar HILLS Rollback Autodesk Material Library 2013 Succeeded  2012/10/10:13:02:48 omar HILLS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Thanks!!
