Installation & Licensing
AutoCAD 2013, Windows 8
29 REPLIES 29
Message 1 of 30
kmfinchpdx
45329 Views, 29 Replies
Will the educational version of AutoCAD run on Windows 8? Microsoft says it's compatible but some people have said it doesn't work. Also wondering about the educational version of Revit.
Tags (2)
29 REPLIES 29
Message 2 of 30
DarrenP
in reply to: kmfinchpdx
look through here: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&location=forum-board%3A2...
DarrenP
Message 3 of 30
kmfinchpdx
in reply to: DarrenP
I looked through the questions and answers but did not see a definite answer if the educational version of AutoCAD 2013 and Revit will install and work in Windows 8. Sounds like some people are experiencing problems with it. Not sure what to do. Any suggestions. I have a 64 bit machine. Seems to be working for some but not for others. Wonder why?
Message 4 of 30
DarrenP
windows 8 isn't supported yet
DarrenP
Message 5 of 30
kmfinchpdx
Does Autodesk plan to release an update sometime soon that will work with Windows 8 (for Autocad and Revit)?
Message 6 of 30
dembkod
kmfinchpdx,
Hello. AutoCAD is not a supported product for Windows 8 at this point- which means it has not been thoroughly tested. It could very well work, but we have not tested it.
Please note that the educational version is the same program as the regular version, it just has an educational license and should watermark files. As for an update- no specific update for any of our 2013 products to offer Windows 8 support has been released or announced at this time.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Message 7 of 30
dgorsman
Anybody who knows what updates will be released when are bound by non-disclosure agreements, so you won't find a conclusive answer.  Pure speculation: based on past releases, programming knowledge, prior release timings, etc. I would say you will see the next release come out before any update to 2013 products that will "guarantee" compatibility with the new OS.  There may not even be a compatibility release, although I'm reasonably confident the higher-ups at AutoDesk have had a look at the work required vs. the potential benefits rather than simply saying "No".
Message 8 of 30
kmfinchpdx
in reply to: dgorsman
I'm a bit puzzled as to why AutoCAD 2013 seems to work in Windows 8 for some users and not for others. Same with Revit. Seems like in years past the launch date for the next year's AutoCAD version is sometime during the summer? Maybe Autodesk should put out a beta version of AutoCAD 2013 for Windows 8. I'm no programmer but Windows 8 seems like a major overhaul from any previous version.  Of course if Windows 8 is where the PC world is headed Autodesk would probably make more money by putting out a compatible version ASAP? Not sure, just some thoughts.
Message 9 of 30
mansker2004
in reply to: dembkod
Is there a chance that I can still use my AutoCAD 2012 in the future when I upgrade to the windows 8 os?
Message 10 of 30
kmfinchpdx
in reply to: mansker2004
Possibly. The strange thing is that Microsoft claims on it's Windows 8 site that AutoCAD 2012 is compatible. Evidently it is for some but not for others.
Message 11 of 30
dembkod
kmfinchpdx,
Hello. If it is working for some people and not others, then clearly there is a block of some type on the system. For cases like this I would simply go with the basics. Turn off Antivirus, turn off UAC, log in as admin and test. Then start turning off competing products running in your services. Also check the NET version, is it newer than the NET that was released with the 2012 products? 2013 shipped with NET 4.0, if you are on 4.5 it was not tested. Can you roll back to 4.0? This is not to say 4.5 is incompatible, but when dealing with a new system, there are many areas that will receive constant updates, all of which came after the product was released.
I am guessing there is an Event Viewer in Win 8, so I would take a look there to see if there are any listed conflicts. If others have this working, there is something different with your machine. Have you looked at the Windows 8 forums on the Microsoft site? I would definitely go there if I had a problem like this.
David Dembkoski
David Dembkoski
Message 12 of 30
kmfinchpdx
Thanks for the posting. I haven't tried downloading AutoCAD 2013 since I purchased the new computer last week since I've been uncertain about compatibility with Windows 8. My old computer has Windows XP so it's quite a jump.
I was wondering what UAC stands for? How do I check the NET version in Windows?
I'm not certain what the event viewer is but I think I've run across it trying to learn more about Windows 8. I'll try looking through the Windows 8 forums on the Microsoft site as you suggested.
Message 13 of 30
dgorsman
UAC = User Access Control.  Basically, prevents certain changes to the system by programs.  At the most agressive level it won't allow any changes, at the default level it will prevent some and warn the user before most which can actually *prevent* some automated changes.  Most power users turn UAC off completely so it doesn't get in the way.
The differences in who can run/not run can easily be explained by the variations in hardware, drivers, expertise in problem solving (Spock-like vs. modern dance flailing), and what constitutes "running properly".  Its the same reason why companies like AutoDesk can't produce a product that runs *completely* error free on all systems - there's too much variation at our end.
Message 14 of 30
kmfinchpdx
Thanks. Not really expecting completely error free. AutoCAD hasn't been without bugs since I started with R14. Just looking to learn the new software (both AutoCAD 2013 and Revit). Hopefully to get back into the field since it's what my degree is in.
I don't know how much of a difference in programming it will take to produce a compatible version on Windows 8 since this version of Windows seems so much of a jump from the other versions. Not like going from say, Windows ME to Windows XP.
Not sure if I dare yet download the educational versions from the Autodesk site or not on the new computer. My old computer was much too slow to even attempt Revit.
Message 15 of 30
rgraffe
I have autocad civil 3d and windows 8 - I loaded it in windows 8 and it worked for 2d but not anything 3d.  So I loaded the program in windows 7 running in hyper-v on the windows 8 machine and it works fine.  Hyper-v comes with windows 8 and can be loaded from programs and features (turn windows features on or off).  Hopefully Autodesk will come out with a patch so it will work directly in windows 8.
Message 16 of 30
StevenLow
I have windows 8, and whenever I attempt to install autocad 2013, it always stops installing when it gets to 4 of # remaining. Can someone help?
Message 17 of 30
I was able to successfully install AutoCAD 2013 on Windows 8. I am only able to tell you what system that I have. Lenovo M Series Think Center. However, I did not have much luck with Inventor. I think that I used the down load manager with AutoCAD 2013. With Inventor 2012 I was only given the browser option. I think that it down loaded all of the program files, but it failed to install. Why did I choose Inventor 2012. My instructor told me that there are some issues with 2013 Inventor. Right or wrong, I followed her lead.
Back to AutoCAD 2013. I understand that a lot of install success has to do with the .net framework on the computer. Maybe a comparison of the 2 systems will give you an idea.
Another area is that I read in another blog that after an unsucessfull install, the person down loaded the product again. A reply to their thread was: "Why did you download it again?" The reply was from a CAD manager at a facility, perhaps someone can give some insight as to what acutally occurs with the download and then install process.
Message 18 of 30
Anyplace online that explains more about the .net framework when downloading and installing AutoCAD 2013 on Windows 8? It's not something I understand. I'm still puzzled, trying to figure out what about Windows 8 makes it work for some people but not for others.
Message 19 of 30
rreid
We have deployed ACAD 2013 on windows 8 x64 and have mixed results.  Here is some info that may help:
In windows 8, you can no longer disable UAC entirely.  It is possible via a registry edit, but then the Windows Store will no longer work.  The most you can do is turn the slide for notifications all the way down.  But UAC is still enabled and still automatically elevates your priveleges if the program calls for it correctly even though it is not notifying you of it. If the program does not call UAC for admin priveleges then the program will fail to run correctly.
To run Autocad correctly (or to install it correctly) you need to mark the executable with 'Run as Administrator'.  Then Autocad will call for UAC elevation correctly.  You do this by navigating to the acad.exe file, right click and select 'Properties', go to the 'Compatibility' tab and click the box under 'Privilege Level'.  This setting will stick.
Autodesk Sync creates a hidden drive mapping (using subst) that is for the local sync store.  If you have other drive maps that conflict with this, then it will break autodesk sync.  By default, the installer attempts to create the map to X:, if X is in use then it moves it to Y:.  You wont see this mapping unless you do a registry edit to show all hidden drives.  See reference here: http://www.pctools.com/guides/registry/detail/148/
Win 8 is still using the Win 7 kernel.  So there is no obvious reason why Acad would not run on it.  But the security has been tightened up and Autocad tends to want read/write access to secure store locations (basically any folder outside of a user's storage folder on the hard disk).  So Autocad HAS to elevate if you want it to run corrrectly.  There are other programs out there that have similar issues.
If you are not a local admin on the computer, then i am not sure if you can get Autocad to run reliably.  Perhaps an Autocad Support MVP will be able to weigh in on this.
Message 20 of 30
kmfinchpdx
in reply to: rreid
A few questions: what is "UAC"? Since I'd be running it at home with just one computer I assume that makes me the "administrator" in Windows 8? How do I know if I have other drive maps that could conflict with the local sync store? Would my files at home be considered "secure" locations by AutoCAD since I'm guessing I'd be the administrator?
Thanks.
Administrator Productivity
