Installation & Licensing
Autocad 2013 windows 7 64 bit fatal error message
3 REPLIES 3
dj_wienna
3153 Views, 3 Replies
I am getting the message FATAL ERROR unhandled acsess violation READING 0x4962b980 EXCEPTION AT f9bfd87fh.
The message shows each time I start AutoCAD. I have gotten this message before as I were drawing, but then i restarted it and everything eas fine. Now I cant even start up. The messages change from each time I try to start up AutoCAD.
I have tried:
-Hotfix for cloud
-Repairing
-Downloading servicepack(won't run)
I run windows 7 64 bit on a two year old Asus pc.
HELP ME?
3 REPLIES 3
TravisNave
in reply to: dj_wienna
Typically these errors are due to .NET Framework corruption or a bad video card driver.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
ehappepo29
Mark.Lancaster
in reply to: ehappepo29
@ehappepo29
Welcome to the community...
Did you forget to post your issue?
Mark Lancaster
Administrator Productivity
