Installation & Licensing
AutoCad 2013 student version activation problem
1 REPLY 1
KmillosRod
274 Views, 1 Reply
first i will excuse for my bad englishSmiley Very Happy. Well, my problem is that i installed AutoCAD Electrical 2013 and after the installation i have entered the serial number and product key. But now i can´t activate it. The window show me this problem
Ok sorry it´s in german but i hope the error code (800c0005) is the same.
What can i do to activate it?
Thanks for help
1 REPLY 1
TravisNave
in reply to: KmillosRod
That means that automatic activation is failing.  You need to manually activate your product.
http://knowledge.autodesk.com/support-topics/483/486#OfflineActivation
Start there.  Otherwise, you might need help from your Reseller.
Autodesk Forums:
Administrator Productivity
