Installation & Licensing
Member
st10000226
Message 1 of 17 (6,609 Views)
AutoCad 2013 student activation problem
6609 Views, 16 Replies
06-18-2012 07:45 PM
I am using AutoCad 2013 Student version. After installing, entering the correct serial number and key, when it comes to the activation part,nothing just happen! I just see an empty window.
I reinstalled it couple of times and tried to use the 30 days trial version to spot the problem but same thing just happens. Any idea how to solve this?
arlinpega.bibat
Message 2 of 17 (6,599 Views)
Re: AutoCad 2013 student activation problem
06-18-2012 09:36 PM in reply to: st10000226
Hi st10000226:
I checked our record and the registered serial number we have on record's for Autodesk Showcase , Autodesk SketchBook Designer and Autodesk 3DS Max Design. Should you require registration assistance, you may contact our Registration and Activation team through thsi link:http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Have a nice day!
Best Regards,
Arlin Bibat
Member
st10000226
Message 3 of 17 (6,587 Views)
06-19-2012 09:55 AM in reply to: arlinpega.bibat
Thank you for your reply. To use this link, I got to have a request code. However, I don’t reach that stage to see the activation request code. The screen freezes before it shows anything not even the request code. All I got are the serial number and key.
New Member
duzeem
Message 4 of 17 (6,290 Views)
07-26-2012 03:58 AM in reply to: st10000226
Hi!
Have you solved this problem? My Autodesk MEP 2013 has the same issue. When I start program I have window of MEP and this licence window, then I see an information that insoluble problem has occured and main window of program disappears.
Mariusz
Member
st10000226
Message 5 of 17 (6,284 Views)
07-26-2012 07:33 AM in reply to: st10000226
I dunno if u got the same problem or not.. but mt problem is solved through the following link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Simply uninstall internet expolrer 9.. will take u back to 8 and it should work probably
New Member
duzeem
Message 6 of 17 (6,269 Views)
07-27-2012 03:57 PM in reply to: st10000226
Thank you for response and help!!! I had IE7 so I downloaded IE8 which requires ServicePack3 fo Win XP. After installing both of them MEP finally works and licence window has content instead of blank page. I have never thought that I will have problem with IE in standalone application :smileywink: Thanks once again!!!
Distinguished Contributor
afif90
Message 7 of 17 (6,241 Views)
07-29-2012 10:02 PM in reply to: duzeem
Try check at your registry.. dlete folder name 'L'
Thank You&Best Regards,
Autodesk Reseller Malaysia
Mohd Afif
New Member
alex_do
Message 8 of 17 (3,488 Views)
03-19-2013 06:41 PM in reply to: afif90
Hi, I registered for the student version and it provided me with a Serial number.
However, when I tried to use the serial number to register it says "The serial number you entered is not valid".
Customer Service
joane.bonghanoy
Message 9 of 17 (3,480 Views)
03-19-2013 07:28 PM in reply to: alex_do
Hi alex_do,
I was able to pull up your Serial Number using the email address on file. I sent you a Private Message (small envelope beside your profile name) with the Serial Number. Please double check if that is the correct one?
Upon reply, please also include the Request Code
Joane Bonghanoy
New Member
tmertcosar
Message 10 of 17 (3,215 Views)
04-04-2013 01:17 PM in reply to: joane.bonghanoy
 when I tried to use the serial number to register it says "The serial number you entered is not valid".  I have same problem with alex , please help me soon as you can
