Installation & Licensing
Valued Mentor
280 Kudos
Post 1 of 76
AutoCAD 2013 serial number and product key
110258 Views, 75 Replies
12-11-2012 08:41 AM
Good Day,
I am about to install AutoCAD 2013 x64 that came with my AutoDesk Product Design Suite Ultimate. I noticed that it is has its pwn installer, but is it part of the Suite?
Would I use the same serial number and the suite product key or same serial number and the AutoCAD product key for 2013?
Sean
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
So I found this on the Autodesk Website:
Product keys are required for installation of Autodesk products and are used to differentiate products that are both sold independently and as part of a product suite. For example, installing AutoCAD 2013 as a point product requires product key 001E1, but installing AutoCAD 2013 from the Autodesk Product Design Suite Ultimate 2013 requires product key 781E1. The same version of AutoCAD is in both software packages but the product key differentiates one package from the other.
So I did use the suite product key and installed with no issues...I googled for a half hour and could not come up with anything, but then I googled product keys for Autodesk and found that paragraph above. Perfect use of office time. haha...
Sean
Valued Mentor
280 Kudos
Post 2 of 76
Re: AutoCAD 2013 serial number and product key
12-11-2012 09:20 AM in reply to: SeanFarr
Sean
Sean Farr
New Member
0 Kudos
Post 3 of 76
01-27-2013 03:33 PM in reply to: SeanFarr
This is realy helpful! Thanks
New Member
0 Kudos
Post 4 of 76
07-09-2013 04:46 AM in reply to: SeanFarr
Yh. Its helpful. Thanks
New Member
0 Kudos
Post 5 of 76
09-06-2013 01:29 PM in reply to: 5ran6
Spoiler
hi
Spoiler
Im using a 64bit pc and my product key for autocad 2014 is not working plz hlp.....
Spoiler
282 Kudos
Post 6 of 76
09-06-2013 02:19 PM in reply to: 201120070
Welcome to the community Mohau!
What product key are you using for your AutoCAD 2014 installation? 001F1?
Philip Schmelzer
New Member
0 Kudos
Post 7 of 76
11-29-2013 01:55 AM in reply to: SeanFarr
serial no and product key my
New Member
0 Kudos
Post 8 of 76
Re: Autocrad 2013 serial number and product key
12-16-2013 08:01 AM in reply to: SeanFarr
Please I want product key of 2013
652 Kudos
Post 9 of 76
12-16-2013 08:18 AM in reply to: gautamvkavithiya
New Member
0 Kudos
Post 10 of 76
02-06-2014 11:28 PM in reply to: gautamvkavithiya
