Installation & Licensing
AutoCAD 2013 on Windows 7 64 bit crashes on startup
1 REPLY 1
harris35
2710 Views, 1 Reply
After installing the student edition of AutoCAD 2013 for school, I've been met with the following message upon starting the program:
"Unhandled access violation at 0xffffffff exception at f8770004h."
The program then exits and offers to alert Autodesk.
Does anyone have a workaround?
1 REPLY 1
TravisNave
in reply to: harris35
Update your video card to a certified driver.  Then if you still have issues, and your AutoCAD is up-to-date on patches, then you might need to reinstall your .NET Framework.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
