Installation & Licensing
Autocad 2013 Not installing
0 REPLIES 0
Message 1 of 1
608 Views, 0 Replies
Whenever I try to install AUTOCAD 2013, which I need for one of my classes and this error message pops up. What do I do?
2013/1/25:01:22:51 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/25:01:22:51 Julio JULIO-PC Launch
2013/1/25:01:22:51 Julio JULIO-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35899492 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/25:01:23:16 Julio JULIO-PC === Setup ended ===
2013/1/25:01:22:52 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/25:01:22:52 Julio JULIO-PC Launch
2013/1/25:01:22:52 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/25:01:22:52 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/25:01:22:52 Julio JULIO-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/25:01:23:16 Julio JULIO-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/25:01:23:16 Julio JULIO-PC PageOpen LaunchDialog
2013/1/25:01:23:50 Julio JULIO-PC PageOpen LicenseDialog
2013/1/25:01:23:50 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/25:01:23:50 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/25:01:24:03 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/25:01:24:04 Julio JULIO-PC Download Play DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT...
2013/1/25:01:24:44 Julio JULIO-PC Download Complete DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT...
2013/1/25:01:24:44 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/25:01:25:05 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/1/25:01:25:06 Julio JULIO-PC PageOpen InstallCompleteDialog
2013/1/25:01:25:12 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/25:01:25:12 Julio JULIO-PC === Setup ended ===
2013/1/25:02:00:18 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/25:02:00:18 Julio JULIO-PC Launch
2013/1/25:02:00:31 Julio JULIO-PC === Setup ended ===
2013/1/25:02:00:22 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/25:02:00:22 Julio JULIO-PC Launch
2013/1/25:02:00:22 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/25:02:00:22 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/25:02:00:30 Julio JULIO-PC PageOpen LaunchDialog
2013/1/25:02:00:34 Julio JULIO-PC PageOpen LicenseDialog
2013/1/25:02:00:36 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/25:02:01:27 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/25:02:01:33 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/25:02:01:33 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/25:02:01:56 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/1/29:14:51:53 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:14:51:53 Julio JULIO-PC Launch
2013/1/29:14:51:53 Julio JULIO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/1/29:14:51:56 Julio JULIO-PC === Setup ended ===
2013/1/29:14:51:51 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:14:51:51 Julio JULIO-PC Launch
2013/1/29:14:52:03 Julio JULIO-PC === Setup ended ===
2013/1/29:14:51:53 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/29:14:51:53 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:14:52:02 Julio JULIO-PC PageOpen LaunchDialog
2013/1/29:14:52:11 Julio JULIO-PC PageOpen LicenseDialog
2013/1/29:14:52:11 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/29:14:52:18 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/29:14:52:19 Julio JULIO-PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/29:14:52:20 Julio JULIO-PC Install Network License Manager Succeeded
2013/1/29:14:52:20 Julio JULIO-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\Julio\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/29:14:52:25 Julio JULIO-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/29:14:52:25 Julio JULIO-PC Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/29:14:52:27 Julio JULIO-PC Install Autodesk CAD Manager Tools Succeeded
2013/1/29:14:52:27 Julio JULIO-PC PageOpen InstallCompleteDialog
2013/1/29:14:52:29 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:14:52:29 Julio JULIO-PC === Setup ended ===
2013/1/29:14:52:33 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:14:52:33 Julio JULIO-PC Launch
2013/1/29:14:52:35 Julio JULIO-PC === Setup ended ===
2013/1/29:14:52:34 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:14:52:34 Julio JULIO-PC Launch
2013/1/29:14:52:34 Julio JULIO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/1/29:14:52:35 Julio JULIO-PC === Setup ended ===
2013/1/29:14:52:34 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/29:14:52:34 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:14:52:35 Julio JULIO-PC PageOpen LaunchDialog
2013/1/29:14:52:36 Julio JULIO-PC PageOpen LicenseDialog
2013/1/29:14:52:39 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/29:14:53:19 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/29:14:53:22 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/29:14:53:25 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/29:14:54:14 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/29:14:54:15 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/29:14:54:35 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/1/29:14:54:37 Julio JULIO-PC PageOpen InstallCompleteDialog
2013/1/29:14:54:53 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:14:54:53 Julio JULIO-PC === Setup ended ===
2013/1/29:14:58:44 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:14:58:44 Julio JULIO-PC Launch
2013/1/29:14:58:44 Julio JULIO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/1/29:14:58:45 Julio JULIO-PC === Setup ended ===
2013/1/29:14:58:43 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:14:58:43 Julio JULIO-PC Launch
2013/1/29:14:58:58 Julio JULIO-PC === Setup ended ===
2013/1/29:14:58:45 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:14:58:45 Julio JULIO-PC Launch
2013/1/29:14:58:45 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/29:14:58:45 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:14:58:57 Julio JULIO-PC PageOpen LaunchDialog
2013/1/29:14:59:01 Julio JULIO-PC PageOpen LicenseDialog
2013/1/29:14:59:04 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/29:15:13:02 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/29:15:13:17 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/29:15:13:17 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/29:15:13:40 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/1/29:15:13:42 Julio JULIO-PC PageOpen InstallCompleteDialog
2013/1/29:15:26:32 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:15:26:32 Julio JULIO-PC === Setup ended ===
2013/1/29:15:26:34 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:15:26:34 Julio JULIO-PC Launch
2013/1/29:15:26:34 Julio JULIO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/1/29:15:26:36 Julio JULIO-PC === Setup ended ===
2013/1/29:15:26:37 Julio JULIO-PC === Setup ended ===
2013/1/29:15:28:24 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:15:28:24 Julio JULIO-PC Launch
2013/1/29:15:28:35 Julio JULIO-PC === Setup ended ===
2013/1/29:15:28:27 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:15:28:27 Julio JULIO-PC Launch
2013/1/29:15:28:27 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/29:15:28:27 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:15:28:35 Julio JULIO-PC PageOpen LaunchDialog
2013/1/29:15:28:40 Julio JULIO-PC PageOpen LicenseDialog
2013/1/29:15:28:46 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/29:15:30:50 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/29:15:31:27 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/29:15:31:27 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/29:15:31:56 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/1/29:15:39:19 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:15:39:19 Julio JULIO-PC Launch
2013/1/29:15:39:26 Julio JULIO-PC === Setup ended ===
2013/1/29:15:39:20 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/29:15:39:20 Julio JULIO-PC Launch
2013/1/29:15:39:20 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/29:15:39:20 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:15:39:26 Julio JULIO-PC PageOpen LaunchDialog
2013/1/29:15:39:31 Julio JULIO-PC PageOpen BeginDeploymentDialog
2013/1/29:15:40:09 Julio JULIO-PC PageOpen LaunchDialog
2013/1/29:15:40:10 Julio JULIO-PC PageOpen LicenseDialog
2013/1/29:15:40:13 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/29:15:40:28 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/29:15:40:35 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/29:15:40:35 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/29:15:41:01 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/1/29:15:41:03 Julio JULIO-PC PageOpen InstallCompleteDialog
2013/1/29:15:41:07 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/29:15:41:07 Julio JULIO-PC === Setup ended ===
2013/1/29:15:39:19 Julio JULIO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/1/29:15:41:08 Julio JULIO-PC === Setup ended ===
2013/1/30:14:44:53 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/30:14:44:53 Julio JULIO-PC Launch
2013/1/30:14:44:53 Julio JULIO-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/1/30:14:44:56 Julio JULIO-PC === Setup ended ===
2013/1/30:14:44:59 Julio JULIO-PC === Setup ended ===
2013/1/30:14:44:54 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/30:14:44:54 Julio JULIO-PC Launch
2013/1/30:14:44:54 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/30:14:44:54 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/30:14:44:59 Julio JULIO-PC PageOpen LaunchDialog
2013/1/30:14:45:05 Julio JULIO-PC PageOpen LicenseDialog
2013/1/30:14:45:08 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/30:14:45:14 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/30:14:45:17 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/30:14:45:17 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/30:14:45:40 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/1/30:14:45:42 Julio JULIO-PC PageOpen InstallCompleteDialog
2013/1/30:14:45:46 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/30:14:45:46 Julio JULIO-PC === Setup ended ===
2013/1/31:12:25:21 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/31:12:25:21 Julio JULIO-PC Launch
2013/1/31:12:25:55 Julio JULIO-PC === Setup ended ===
2013/1/31:12:25:29 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/31:12:25:29 Julio JULIO-PC Launch
2013/1/31:12:25:30 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/31:12:25:30 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/31:12:25:56 Julio JULIO-PC PageOpen LaunchDialog
2013/1/31:12:26:42 Julio JULIO-PC PageOpen LicenseDialog
2013/1/31:12:26:44 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/31:12:27:00 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/31:12:27:08 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/31:12:27:08 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/31:12:27:32 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2013/1/31:12:27:33 Julio JULIO-PC PageOpen InstallCompleteDialog
2013/1/31:12:27:36 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/31:12:27:36 Julio JULIO-PC === Setup ended ===
2013/1/31:12:35:10 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/31:12:35:10 Julio JULIO-PC Launch
2013/1/31:12:35:27 Julio JULIO-PC === Setup ended ===
2013/1/31:12:35:15 Julio JULIO-PC === Setup started on JULIO-PC by Julio ===
2013/1/31:12:35:15 Julio JULIO-PC Launch
2013/1/31:12:35:15 Julio JULIO-PC [Error: 1060] The specified service does not exist as an installed service.
2013/1/31:12:35:15 Julio JULIO-PC [Error: 6] The handle is invalid.
2013/1/31:12:35:26 Julio JULIO-PC PageOpen LaunchDialog
2013/1/31:12:35:43 Julio JULIO-PC PageOpen LicenseDialog
2013/1/31:12:35:45 Julio JULIO-PC PageOpen ProductInfoDialog
2013/1/31:12:36:09 Julio JULIO-PC PageOpen ProductSelectionDialog2
2013/1/31:12:36:12 Julio JULIO-PC PageOpen FullProgressDialog
2013/1/31:12:36:12 Julio JULIO-PC Installing .NET Framework Runtime 4.0: C:\Autocad\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/31:12:37:11 Julio JULIO-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
0 REPLIES 0
Administrator Productivity
