Hi ,
I am new to this thread.
Today when i am trying to deploy the AuytoCAD 2013 mechanical using the SCCM. so many machines are failing
with error code 1603 & 1619. We are having AutoCAd 2011 mechanical installed in all those machines.
While uninstalling the AutoCAD 2011 we are getting these errors. We are having the full access on all the machines in our domain. And when i checked the SCCM advert the error is. A failure exit code of 1073807364 was returned.
Below are the logs from one of the machine.
08/02/13 15:45:16: Application .NET Framework 3.5 is currently installed.
08/02/13 15:45:16: Checking HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Client
08/02/13 15:45:16: Application .NET Framework 4.0 is currently installed - version is 4.0.30319.
08/02/13 15:45:16: Check HKLM\Software\Microsoft\DirectX | Version
08/02/13 15:45:16: Value = 4.09.00.0904 that is version = 9.0c
08/02/13 15:45:21: Checking to see the status of the following processes: acad.exe
08/02/13 15:45:21: If any are running the package will wait for them to be closed
08/02/13 15:45:28:
08/02/13 15:45:28
08/02/13 15:45:28: =============== Setup or other configuration beginning ===============
08/02/13 15:45:28: Check previous version SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5783F2D7-9005-0411-0102-0060B0CE6BBA}\{5783F2D7-9005-0411-0102-0060B0CE6BBA}
08/02/13 15:45:28: Found previous version in C:\ENGapps\ADSKacad\2011\
08/02/13 15:45:28:
08/02/13 15:45:28: Uninstalling AutoCAD Mechanical 2011 via MSIEXEC
08/02/13 15:45:28: Executing msiexec /x {5783F2D7-9005-0411-0102-0060B0CE6BBA} /qn REBOOT="ReallySuppress" ALLUSERS="1" /lev C:\APPS\LOGS\ADSKacad2013_msi.log
08/02/13 15:46:07: Windows Installer Status = 1603: A fatal error occurred during installation. - fail
08/02/13 15:46:07: Installation/setup was *NOT* successful.
08/02/13 15:46:07: Setting status for MIF to: Failed
08/02/13 15:46:07: Setting reason for MIF to: MSI
08/02/13 15:46:07: Executing EXIT section
08/02/13 15:46:07:
08/02/13 15:46:07: Creating ADSKacad2013.mif file with Status: Failed and Reason: MSI
08/02/13 15:46:07: Copying SMSInvy.exe to C:\APPS\TEMP\SmsPkgUtils
08/02/13 15:46:07: Start SMSInvy.exe HINV D C:\apps\logs\HINV.log
08/02/13 15:46:07: Package complete
Please some one reply me ASAP. Due to this we are facing so many issues.AutoCAd 2011 wont work and 2013 wont get installed through SCCM.
You might also try posting this in the Installation and Licensing forum.
And see the links in the signature of TravisNave (this is a post of his, the post itself doesn't have anything to do with your Q)
Welcome to the community.
At first thought, there's no reason to first uninstall 2011 automatically before installing 2013. You might just try to SCCM deploy 2013 first to at least get that much working.
As for uninstalling 2011, sometimes the uninstaller often still needs the original source for the uninstall. This can be problematic if the source install no longer exists, or the client no longer matches the source because of additional hotfixes and service packs added after initial install. That mismatch has plagued the Autodesk installer for quite some time. In fact, it completely hosed 2013. So when you do install 2013, do NOT install any service packs with the installation. Install them after. Then update your deployment.
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Otherwise use the Microsoft Fix it tool and be done with it.
Good Luck!
