Installation & Licensing
New Member
2015hlee
Message 1 of 3 (475 Views)
AutoCAD 2013 Installation Failure
475 Views, 2 Replies
01-02-2013 05:03 PM
Hi, I'm having trouble installing AutoCAD 2013 (Free for students). I have Windows 8 32-bit. Here is my AutoCAD 2013 Setup.log file that I found on my %TEMP% folder:
2013/1/2:16:02:05 Hojae Lee HOJAELEE-THINK === Setup started on HOJAELEE-THINK by Hojae Lee ===
2013/1/2:16:02:05 Hojae Lee HOJAELEE-THINK Launch
2013/1/2:16:02:05 Hojae Lee HOJAELEE-THINK CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-24782690 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/2:16:03:02 Hojae Lee HOJAELEE-THINK === Setup ended ===
2013/1/2:16:02:07 Hojae Lee HOJAELEE-THINK === Setup started on HOJAELEE-THINK by Hojae Lee ===
2013/1/2:16:02:07 Hojae Lee HOJAELEE-THINK Launch
2013/1/2:16:02:08 Hojae Lee HOJAELEE-THINK Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/2:16:02:59 Hojae Lee HOJAELEE-THINK Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/2:16:03:01 Hojae Lee HOJAELEE-THINK PageOpen LaunchDialog
2013/1/2:16:03:16 Hojae Lee HOJAELEE-THINK PageOpen LicenseDialog
2013/1/2:16:03:16 Hojae Lee HOJAELEE-THINK PageOpen ProductInfoDialog
2013/1/2:16:03:16 Hojae Lee HOJAELEE-THINK PageOpen ProductSelectionDialog2
2013/1/2:16:07:08 Hojae Lee HOJAELEE-THINK === Setup ended ===
2013/1/2:16:17:47 Hojae Lee HOJAELEE-THINK === Setup started on HOJAELEE-THINK by Hojae Lee ===
2013/1/2:16:17:47 Hojae Lee HOJAELEE-THINK Launch
2013/1/2:16:17:47 Hojae Lee HOJAELEE-THINK CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-24782690 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/2:16:18:00 Hojae Lee HOJAELEE-THINK === Setup ended ===
2013/1/2:16:17:53 Hojae Lee HOJAELEE-THINK === Setup started on HOJAELEE-THINK by Hojae Lee ===
2013/1/2:16:17:53 Hojae Lee HOJAELEE-THINK Launch
2013/1/2:16:17:53 Hojae Lee HOJAELEE-THINK Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/2:16:17:56 Hojae Lee HOJAELEE-THINK PageOpen LaunchDialog
2013/1/2:16:18:11 Hojae Lee HOJAELEE-THINK PageOpen LicenseDialog
2013/1/2:16:18:12 Hojae Lee HOJAELEE-THINK PageOpen ProductInfoDialog
2013/1/2:16:18:12 Hojae Lee HOJAELEE-THINK PageOpen ProductSelectionDialog2
2013/1/2:16:19:34 Hojae Lee HOJAELEE-THINK PageOpen FullProgressDialog
2013/1/2:16:19:35 Hojae Lee HOJAELEE-THINK Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/2:16:19:42 Hojae Lee HOJAELEE-THINK Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/2:16:19:42 Hojae Lee HOJAELEE-THINK Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/2:16:19:57 Hojae Lee HOJAELEE-THINK Install DirectX Runtime Succeeded
2013/1/2:16:19:57 Hojae Lee HOJAELEE-THINK Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/2:16:20:22 Hojae Lee HOJAELEE-THINK Install FaroSDK Succeeded
2013/1/2:16:20:23 Hojae Lee HOJAELEE-THINK Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/2:16:20:51 Hojae Lee HOJAELEE-THINK Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/2:16:20:51 Hojae Lee HOJAELEE-THINK Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/2:16:21:24 Hojae Lee HOJAELEE-THINK Install Autodesk Material Library 2013 Succeeded
2013/1/2:16:21:25 Hojae Lee HOJAELEE-THINK Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/2:16:22:01 Hojae Lee HOJAELEE-THINK Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CMI...
2013/1/2:16:22:01 Hojae Lee HOJAELEE-THINK Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/2:16:22:16 Hojae Lee HOJAELEE-THINK Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/2:16:22:16 Hojae Lee HOJAELEE-THINK Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x86\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/2:16:22:41 Hojae Lee HOJAELEE-THINK Install Autodesk Content Service Succeeded
2013/1/2:16:22:41 Hojae Lee HOJAELEE-THINK Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/2:16:22:46 Hojae Lee HOJAELEE-THINK Install Autodesk Content Service Language Pack Succeeded
2013/1/2:16:22:46 Hojae Lee HOJAELEE-THINK Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/2:16:26:53 Hojae Lee HOJAELEE-THINK Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/2:16:26:55 Hojae Lee HOJAELEE-THINK Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x86\en-us\acad\acad.mst;C:\Users\HOJAEL~1\AppData\Local\Temp\_AI342A.tmp\x86\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/2:16:33:06 Hojae Lee HOJAELEE-THINK Install AutoCAD® 2013 Succeeded
2013/1/2:16:33:06 Hojae Lee HOJAELEE-THINK Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/2:16:35:16 Hojae Lee HOJAELEE-THINK Download Aborted ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA...
2013/1/2:16:35:16 Hojae Lee HOJAELEE-THINK Install AutoCAD® 2013 Language Pack Failed Download Failed, Installation aborted, Result=1603
2013/1/2:16:37:14 Hojae Lee HOJAELEE-THINK Rollback AutoCAD® 2013 Succeeded
2013/1/2:16:37:17 Hojae Lee HOJAELEE-THINK Rollback Autodesk Content Service Language Pack Succeeded
2013/1/2:16:37:25 Hojae Lee HOJAELEE-THINK Rollback Autodesk Content Service Succeeded
2013/1/2:16:37:46 Hojae Lee HOJAELEE-THINK Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/2:16:38:13 Hojae Lee HOJAELEE-THINK Rollback Autodesk Material Library 2013 Succeeded
2013/1/2:16:38:19 Hojae Lee HOJAELEE-THINK Rollback FaroSDK Succeeded
2013/1/2:16:38:20 Hojae Lee HOJAELEE-THINK Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/2:16:38:24 Hojae Lee HOJAELEE-THINK PageOpen InstallCompleteDialog
2013/1/2:16:57:17 Hojae Lee HOJAELEE-THINK === Setup ended ===
Any help would be very greatly appreciated!
-Hojae
DarrenP
Message 2 of 3 (471 Views)
Re: AutoCAD 2013 Installation Failure
01-02-2013 05:07 PM in reply to: 2015hlee
do a search for windows 8 on these forums and you will find your answer
Member
samuelwilliam
Message 3 of 3 (454 Views)
01-03-2013 01:02 AM in reply to: 2015hlee
use window 8  64 bit platform hope that successfully installed.
