Installation & Licensing
AutoCAD 2013 Install issue
1 REPLY 1
mphipps
1830 Views, 1 Reply
While installing 2013, the installation stalled and I had to close it through task manager.
When I tried to run the install again, it showed that 2013 was installed. It showed the 2013 icon on the desktop but it would not run when clicked. I then tried to uninstall it though the control panel but a prompt came up stating it did not exist and removed 2013 from the list.
I've now manually deleted 2013 files from anywhere I can find them, as well as entries in the registry.
The install is still saying that 2013 is already installed.
- windows 7 64-bit installation
1 REPLY 1
TravisNave
in reply to: mphipps
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
