Installation & Licensing
AutoCad 2013 failed to install
6 REPLIES 6
condorhero85
3404 Views, 6 Replies
I cant install autocad 2013 here is the error logs somone please help thank you so much
2012/11/6:12:37:41 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:12:37:41 Owner OWNER-PC Launch 2012/11/6:12:38:22 Owner OWNER-PC === Setup ended ===
2012/11/6:12:37:48 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:12:37:48 Owner OWNER-PC Launch 2012/11/6:12:37:48 Owner OWNER-PC [Error: 1060] The specified service does not exist as an installed service. 2012/11/6:12:37:48 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:12:37:48 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:12:38:22 Owner OWNER-PC PageOpen LaunchDialog   2012/11/6:12:38:26 Owner OWNER-PC PageOpen LicenseDialog   2012/11/6:12:38:30 Owner OWNER-PC PageOpen ProductInfoDialog   2012/11/6:12:42:47 Owner OWNER-PC PageOpen ProductSelectionDialog2   2012/11/6:12:43:00 Owner OWNER-PC PageOpen FullProgressDialog   2012/11/6:12:43:00 Owner OWNER-PC Installing .NET Framework Runtime 4.0: C:\Users\Owner\Documents\acad2013_x64\acad2013_x64\New Folder\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2012/11/6:12:43:46 Owner OWNER-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2012/11/6:12:43:53 Owner OWNER-PC PageOpen InstallCompleteDialog   2012/11/6:12:44:06 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:12:44:06 Owner OWNER-PC === Setup ended ===
2012/11/6:12:54:23 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:12:54:23 Owner OWNER-PC Launch 2012/11/6:12:54:35 Owner OWNER-PC === Setup ended ===
2012/11/6:12:54:27 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:12:54:27 Owner OWNER-PC Launch 2012/11/6:12:54:27 Owner OWNER-PC [Error: 1060] The specified service does not exist as an installed service. 2012/11/6:12:54:27 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:12:54:27 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:12:54:35 Owner OWNER-PC PageOpen LaunchDialog   2012/11/6:12:54:45 Owner OWNER-PC PageOpen LicenseDialog   2012/11/6:12:54:49 Owner OWNER-PC PageOpen ProductInfoDialog   2012/11/6:12:55:00 Owner OWNER-PC PageOpen ProductSelectionDialog2   2012/11/6:12:55:12 Owner OWNER-PC PageOpen FullProgressDialog   2012/11/6:12:55:12 Owner OWNER-PC Installing .NET Framework Runtime 4.0: C:\Users\Owner\Documents\acad2013_x64\acad2013_x64\New Folder\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2012/11/6:12:55:58 Owner OWNER-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2012/11/6:12:56:03 Owner OWNER-PC PageOpen InstallCompleteDialog   2012/11/6:12:56:10 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:12:56:10 Owner OWNER-PC === Setup ended ===
2012/11/6:16:12:51 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:16:12:51 Owner OWNER-PC Launch 2012/11/6:16:13:01 Owner OWNER-PC === Setup ended ===
2012/11/6:16:12:54 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:16:12:54 Owner OWNER-PC Launch 2012/11/6:16:12:54 Owner OWNER-PC [Error: 1060] The specified service does not exist as an installed service. 2012/11/6:16:12:54 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:16:12:54 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:16:13:01 Owner OWNER-PC PageOpen LaunchDialog   2012/11/6:16:15:33 Owner OWNER-PC PageOpen LicenseDialog   2012/11/6:16:15:36 Owner OWNER-PC PageOpen ProductInfoDialog   2012/11/6:16:16:22 Owner OWNER-PC PageOpen ProductSelectionDialog2   2012/11/6:16:16:31 Owner OWNER-PC PageOpen FullProgressDialog   2012/11/6:16:16:31 Owner OWNER-PC Installing .NET Framework Runtime 4.0: C:\Users\Owner\Documents\acad2013_x64\acad2013_x64\New Folder\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2012/11/6:16:17:11 Owner OWNER-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2012/11/6:16:35:56 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:16:35:57 Owner OWNER-PC Launch 2012/11/6:16:36:08 Owner OWNER-PC === Setup ended ===
2012/11/6:16:36:00 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:16:36:00 Owner OWNER-PC Launch 2012/11/6:16:36:00 Owner OWNER-PC [Error: 1060] The specified service does not exist as an installed service. 2012/11/6:16:36:00 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:16:36:00 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:16:36:08 Owner OWNER-PC PageOpen LaunchDialog   2012/11/6:16:36:33 Owner OWNER-PC PageOpen LicenseDialog   2012/11/6:16:36:37 Owner OWNER-PC PageOpen ProductInfoDialog   2012/11/6:16:37:21 Owner OWNER-PC PageOpen ProductSelectionDialog2   2012/11/6:16:37:51 Owner OWNER-PC PageOpen FullProgressDialog   2012/11/6:16:37:51 Owner OWNER-PC Installing .NET Framework Runtime 4.0: C:\Users\Owner\Documents\acad2013_x64\acad2013_x64\New Folder\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2012/11/6:16:38:37 Owner OWNER-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2012/11/6:16:38:40 Owner OWNER-PC PageOpen InstallCompleteDialog   2012/11/6:16:41:55 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:16:41:55 Owner OWNER-PC === Setup ended ===
2012/11/6:16:55:07 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:16:55:07 Owner OWNER-PC Launch 2012/11/6:16:55:16 Owner OWNER-PC === Setup ended ===
2012/11/6:16:55:10 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:16:55:10 Owner OWNER-PC Launch 2012/11/6:16:55:10 Owner OWNER-PC [Error: 1060] The specified service does not exist as an installed service. 2012/11/6:16:55:10 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:16:55:10 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:16:55:16 Owner OWNER-PC PageOpen LaunchDialog   2012/11/6:16:58:07 Owner OWNER-PC PageOpen LicenseDialog   2012/11/6:16:58:17 Owner OWNER-PC PageOpen ProductInfoDialog   2012/11/6:16:58:37 Owner OWNER-PC PageOpen ProductSelectionDialog2   2012/11/6:16:58:39 Owner OWNER-PC PageOpen FullProgressDialog   2012/11/6:16:58:40 Owner OWNER-PC Installing .NET Framework Runtime 4.0: C:\Users\Owner\Documents\acad2013_x64\acad2013_x64\New Folder\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2012/11/6:16:59:18 Owner OWNER-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2012/11/6:16:59:22 Owner OWNER-PC PageOpen InstallCompleteDialog   2012/11/6:17:00:34 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:17:00:34 Owner OWNER-PC === Setup ended ===
2012/11/6:17:07:51 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:17:07:51 Owner OWNER-PC Launch 2012/11/6:17:08:03 Owner OWNER-PC === Setup ended ===
2012/11/6:17:08:00 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:17:08:00 Owner OWNER-PC Launch 2012/11/6:17:08:00 Owner OWNER-PC [Error: 1060] The specified service does not exist as an installed service. 2012/11/6:17:08:00 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:17:08:00 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:17:08:03 Owner OWNER-PC PageOpen LaunchDialog   2012/11/6:17:09:03 Owner OWNER-PC PageOpen LicenseDialog   2012/11/6:17:09:08 Owner OWNER-PC PageOpen ProductInfoDialog   2012/11/6:17:09:30 Owner OWNER-PC PageOpen ProductSelectionDialog2   2012/11/6:17:09:32 Owner OWNER-PC PageOpen FullProgressDialog   2012/11/6:17:09:33 Owner OWNER-PC Installing .NET Framework Runtime 4.0: C:\Users\Owner\Documents\acad2013_x64\acad2013_x64\New Folder\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2012/11/6:17:10:12 Owner OWNER-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2012/11/6:17:10:16 Owner OWNER-PC PageOpen InstallCompleteDialog   2012/11/6:17:12:29 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:17:12:29 Owner OWNER-PC === Setup ended ===
2012/11/6:17:14:37 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:17:14:37 Owner OWNER-PC Launch 2012/11/6:17:14:48 Owner OWNER-PC === Setup ended ===
2012/11/6:17:14:43 Owner OWNER-PC === Setup started on OWNER-PC by Owner === 2012/11/6:17:14:43 Owner OWNER-PC Launch 2012/11/6:17:14:43 Owner OWNER-PC [Error: 1060] The specified service does not exist as an installed service. 2012/11/6:17:14:43 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:17:14:43 Owner OWNER-PC [Error: 6] The handle is invalid. 2012/11/6:17:14:48 Owner OWNER-PC PageOpen LaunchDialog   2012/11/6:17:15:27 Owner OWNER-PC PageOpen LicenseDialog   2012/11/6:17:17:21 Owner OWNER-PC PageOpen ProductInfoDialog   2012/11/6:17:18:22 Owner OWNER-PC PageOpen ProductSelectionDialog2   2012/11/6:17:18:24 Owner OWNER-PC PageOpen FullProgressDialog   2012/11/6:17:18:24 Owner OWNER-PC Installing .NET Framework Runtime 4.0: C:\Users\Owner\Documents\acad2013_x64\acad2013_x64\New Folder\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2012/11/6:17:19:06 Owner OWNER-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
6 REPLIES 6
david.lau
in reply to: condorhero85
Repair .NET as noted in this post:
http://upandready.typepad.com/up_and_ready/2012/01/installation-net-repair-for-windows-7-the-easy-wa...
If not, then uninstall it.  Let the Autodesk product reinstall the .NET as necessary.
David Lau
condorhero85
in reply to: david.lau
i did everything your post says and the program still doesnt install?
david.lau
Download the trial version of AutoCAD and use a browser download if possible and try again.
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
Also, see if you can elevated your Windows 7 administrator role.  Perform steps 1, 3, 5 from this post:
http://upandready.typepad.com/up_and_ready/2012/03/general-systems-windows-7-administrator-tips-tric...
David Lau
condorhero85
it still not working what else can i do
ukdxb012
Administrator Productivity
