I have got a problem with an Autocad 2012 trial version.
I have just installed a windows 7 32bits with an autocad 2012 trial version yesterday and I can't use it because it asks me to activate the licence.
When I edit the ACD2012FRAAdlm.log file I obtain the following message :
3500 2012/01/06 10:52:22 Reason=Fatal error
3500 2012/01/06 10:52:22 ComputerName=YL7J016755
3500 2012/01/06 10:52:22 OS=6.1.7601.Service Pack 1
3500 2012/01/06 10:52:22 File=AdlmIntSATSLicense.cpp,Line=416
3500 2012/01/06 10:52:22 VendorID=2 [ADLMACT]
3500 2012/01/06 10:52:22 VendorError=2 [An operation is cancelled]
3500 2012/01/06 10:52:22 File=AdlmIntSATSLicense.cpp,Line=422
3500 2012/01/06 10:52:22 AdlmIntError=19 [The license checkout was cancelled by the user]
3500 2012/01/06 10:52:22 File=AdlmIntSATSLicense.cpp,Line=2164
3500 2012/01/06 10:52:22 AdlmIntError=17 [The license was not found]
2224 2012/01/06 11:32:08 Reason=Fatal error
2224 2012/01/06 11:32:08 ComputerName=YL7J016755
2224 2012/01/06 11:32:08 OS=6.1.7601.Service Pack 1
2224 2012/01/06 11:32:08 File=AdlmIntSATSLicense.cpp,Line=416
2224 2012/01/06 11:32:08 VendorID=2 [ADLMACT]
2224 2012/01/06 11:32:08 VendorError=2 [An operation is cancelled]
2224 2012/01/06 11:32:08 File=AdlmIntSATSLicense.cpp,Line=422
2224 2012/01/06 11:32:08 AdlmIntError=19 [The license checkout was cancelled by the user]
I need to use the trial version before activating it on my enterprise's computers because I have to test our acadtools functioning.
Can somebody helps me?
Tahnks in advance.
Have you installed AutoCAD 2012 at your computer before? If yes, you could not use the trial after it has expired and need to active it.
You could install this software at another computer which has never installed AutoCAD 2012 before.
