Installation & Licensing
Autocad 2012 reinstall failure Win 7 1603/1619
2 REPLIES 2
257 Views, 2 Replies
  I'm trying to reinstall Autocad 2012 on Windows 7.
I'm receiving an installation aborted error 1603
(it also fails to rollback DirectX - error 1619).
I've attached the log file.
I've never had to decipher one of these.
Could someone take a look and recommend a fix?
2 REPLIES 2
TravisNave
Does the log file that shows the rollback also show which part failed?  Usually these failures are caused by:
1.  Prerequisite installation failure
2.  Installing with a service pack
3.  Installing from media instead of from hard drive
If you have the other installation log, post it.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Hello again,
  That was a quick reply. Thank you. I think I should fill you
in on my situation.
  I just completed a new installation of Windows 7 Pro on a new internal hard drive.
After that, I migrated my old XP Home drive to Windows 7 Pro using
Laplink PC Mover Pro (Image and Drive Assistant). This migration moved
many of my old educational Autodesk products successfully, but it also failed
a number of others.
   I have read that AutoCAD 2012 balks at installation if certain other Autodesk products
are already present. I need to know which "successfully" transfered products I need
to remove before I try another AutoCAD 2012 installation. I certainly don't want to
remove all of them!!! Here is my current installation:
Successful Transfers:        *   Unsuccessful:
    Design Review 2012               Mudbox 2012                                   *    AutoCAD 2012
    Design Reviewn                      Robot Strucutral Analsysis Pro 2012  *    Architecture 2012 (?)
    DWG True View 2007             Softimage 2012 Sp1                         *    Electrical 2012
    Inventor Fusion 2012              Backburner                                       *    Map 3D 2012
    Alias Automotive 2012           Composite 2012                               *    Mechanical 2012
    Alias Design 2012                   DWG True View 2009                       *    P&ID 2012
    OEM View 2008                     DWG True View 2012                       *    Maya 2012
    OEM View 2009                     Showcase 2012                                *    MEP 2012
    Architecture 2012 (?)              Sketch Book Pro 2011 sp2                *    Sketch Book Designer 2012
    3DS Max 2012
    3DS Max Design 2012
    Algor Simulation 2012
    Data Management
    FBX Plug-Ins
    Impression 3
    Infrastructure Administrator 2012
    Inventor 2012
    Inventor Publisher 2012
    Match Mover 2012
    Moldflow Advisor
    Motion Builder 2012
I hope I'm asking the "right" question
Comments?
Thanks again
Administrator Productivity
