I was wondering if anyone ever tried to install AutoCad 2012 using the extracted MSIs? if yes, what would be the right installation sequence? I know there are some Pre-Reqs that need to be installed as well prior running the main MSI. But I also know that some of those Pre-Reqs are already pat of Win7 OS
Any suggestion would be greatly appreciated!
Sim
The pre-requisites are listed here:
.NET 4.0 is required. There are some posts in various other forums.
Another important piece of information which might be helpful is in the Network Administrator's Guide. The MSI packages are dependent on certain properties being passed to them so the section, Use Scripts to Deploy the Program is useful in that it gives you a list of any properties which might also be needed:
AutoCAD 2012 Network Administrator's Guide
Hope this helps,
Alison
where do i download acad.msi for acad 2012 i ccidently deleted the file and downloaded the software from ur site only.
