Installation & Licensing
AutoCAD 2012 License Error
2 REPLIES 2
minzayarnaing
527 Views, 2 Replies
I am experiencing FATAL Error while working.
After the error, the program terminated.
After re-run the program, the program stop at "Checking License" for long time and it says License Error ask to activate.
I cannot do Connect and Activate as my limit has reached.
I requested the Activation Code from Autodesk.
After getting the Code, I re-activated and it went well for about 3 hours.
It happen again with different Request Code. Cannot use the Activation Code which was previously issued.
Please help me and advise me how to prevent not to happen like that again.
2 REPLIES 2
TravisNave
in reply to: minzayarnaing
You need to determine what is causing the fatal error.  In many cases it is video card / driver related.  What is the error code that you get?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Yong.Jing
You should check what cause program terminate, software itself or the license.
Please follow below link to check what issue casue program hangs.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10244411&linkID=9240617
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Administrator Productivity
