Installation & Licensing
New Member
minzayarnaing
Message 1 of 3 (342 Views)
AutoCAD 2012 License Error
342 Views, 2 Replies
11-15-2012 06:40 AM
I am experiencing FATAL Error while working.
After the error, the program terminated.
After re-run the program, the program stop at "Checking License" for long time and it says License Error ask to activate.
I cannot do Connect and Activate as my limit has reached.
I requested the Activation Code from Autodesk.
After getting the Code, I re-activated and it went well for about 3 hours.
It happen again with different Request Code. Cannot use the Activation Code which was previously issued.
Please help me and advise me how to prevent not to happen like that again.
TravisNave
Message 2 of 3 (327 Views)
Re: AutoCAD 2012 License Error
11-15-2012 11:59 AM in reply to: minzayarnaing
You need to determine what is causing the fatal error.  In many cases it is video card / driver related.  What is the error code that you get?
Product Support
jingy
Message 3 of 3 (292 Views)
11-18-2012 08:36 PM in reply to: minzayarnaing
You should check what cause program terminate, software itself or the license.
Please follow below link to check what issue casue program hangs.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10244411&linkID=9240617
Yong Jing
Product Support Specialist
Frontline Technical Support, CSS. GCSO
