I downloaded the student version of AutoCAD 2012 English for Windows 64-bit and extracted to C:\Autodesk as suggested. When I ran through the setup, I answered all of the questions and entered my newly appointed product key and serial number. It accepted it and started installing. The installer got as far as the initial installation of .NET and then just hung there forever. On the bottom it said "13 of 14", I believe, and the overall progress bar at the top had barely moved. I actually left it on all day to see if it would continue slowly. It didn't, and after around 10 hours it was still stalled at the same spot. I restarted the computer and tried again, several times. Every time since the first time it hangs much earlier in the installation, before answering any questions.
My suspicion is that the installer is somehow negatively interacting with my antivirus software, Avast Free ver 6.0.1367. The reason for this suspicion is my CPU usage shoots up while it's hung and it's AvastSvc.exe chewing up about 50% of the CPU. As a workaround I tried to disable Avast's Real-Time Shield before starting the installer, but this didn't change anything.
Does anyone know what the problem might be?
hello.
can you please help me fix a similar problem but in revit? i run the entire setup successfully and enter the keys.... but the overall progress comes till 1/4 remaining and gets stuck there!i left it like that for 7 hours and still no progress. what shud i do?(i dont have any softwares like u mentioned but i hav norton something that i am not really familiar with...which also gives me a message of high memory usage.......
thank you.
Do you have a active internet connection? The Revit installer will look to download files during he install depending on families and templates selected I beleive...
This can take a while depending on you internet connection. Can you verify at what step the install hangs.
