Installation & Licensing
AutoCAD 2012 Failed Installation aborted Result=1603 on Window 7 64bit
1 REPLY 1
1061 Views, 1 Reply
I tried to install Autocad 2012 on my Laptop Window 7 64bit
but it failed to install with this log file
2014/3/30:22:21:06 Thanapan THANAPAN-PC === Setup started on THANAPAN-PC by Thanapan ===
2014/3/30:22:21:06 Thanapan THANAPAN-PC Launch
2014/3/30:22:21:27 Thanapan THANAPAN-PC === Setup ended ===
2014/3/30:22:21:07 Thanapan THANAPAN-PC === Setup started on THANAPAN-PC by Thanapan ===
2014/3/30:22:21:07 Thanapan THANAPAN-PC Launch
2014/3/30:22:21:28 Thanapan THANAPAN-PC PageOpen LaunchDialog
2014/3/30:22:21:41 Thanapan THANAPAN-PC PageOpen LicenseDialog
2014/3/30:22:21:51 Thanapan THANAPAN-PC PageOpen ProductInfoDialog
2014/3/30:22:22:25 Thanapan THANAPAN-PC PageOpen ProductSelectionDialog2
2014/3/30:22:22:28 Thanapan THANAPAN-PC PageOpen FullProgressDialog
2014/3/30:22:22:29 Thanapan THANAPAN-PC Installing .NET Framework Runtime 4.0: E:\drive D\Autodesk\Autocad 2012 - 64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2014/3/30:22:22:54 Thanapan THANAPAN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2014/3/30:22:22:54 Thanapan THANAPAN-PC PageOpen InstallCompleteDialog
2014/3/30:22:23:17 Thanapan THANAPAN-PC === Setup ended ===
2014/3/30:22:37:22 Thanapan THANAPAN-PC === Setup started on THANAPAN-PC by Thanapan ===
2014/3/30:22:37:22 Thanapan THANAPAN-PC Launch
2014/3/30:22:37:27 Thanapan THANAPAN-PC === Setup ended ===
2014/3/30:22:37:27 Thanapan THANAPAN-PC PageOpen LaunchDialog
2014/3/30:22:37:34 Thanapan THANAPAN-PC PageOpen LicenseDialog
2014/3/30:22:37:37 Thanapan THANAPAN-PC PageOpen ProductInfoDialog
2014/3/30:22:37:43 Thanapan THANAPAN-PC PageOpen ProductSelectionDialog2
2014/3/30:22:37:45 Thanapan THANAPAN-PC PageOpen FullProgressDialog
2014/3/30:22:37:45 Thanapan THANAPAN-PC Installing .NET Framework Runtime 4.0: E:\drive D\Autodesk\Autocad 2012 - 64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2014/3/30:22:38:10 Thanapan THANAPAN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2014/3/30:22:38:10 Thanapan THANAPAN-PC PageOpen InstallCompleteDialog
2014/3/30:23:01:04 Thanapan THANAPAN-PC === Setup ended ===
2014/3/31:13:58:50 Thanapan THANAPAN-PC === Setup started on THANAPAN-PC by Thanapan ===
2014/3/31:13:58:50 Thanapan THANAPAN-PC Launch
2014/3/31:13:59:24 Thanapan THANAPAN-PC === Setup ended ===
2014/3/31:13:59:25 Thanapan THANAPAN-PC PageOpen LaunchDialog
2014/3/31:13:59:55 Thanapan THANAPAN-PC PageOpen LicenseDialog
2014/3/31:14:00:15 Thanapan THANAPAN-PC PageOpen ProductInfoDialog
2014/3/31:14:00:22 Thanapan THANAPAN-PC PageOpen ProductSelectionDialog2
2014/3/31:14:00:23 Thanapan THANAPAN-PC PageOpen FullProgressDialog
2014/3/31:14:00:23 Thanapan THANAPAN-PC Installing .NET Framework Runtime 4.0: C:\Users\Thanapan\Documents\Autocad 2012 - 64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2014/3/31:14:00:39 Thanapan THANAPAN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
I already have a microsoft c++ on my computer follow by this list
Microsoft visual c++ 2005 redistributable
Microsoft visual c++ 2005 redistributable (x64)
Microsoft visual c++ 2008 redistributable - x64 9.0.30729.17
Microsoft visual c++ 2008 redistributable - x64 9.0.30729.4148
Microsoft visual c++ 2008 redistributable - x86 9.0.30729.4148
Microsoft visual c++ 2010 x64 redistributable - 10.0.40219
Microsoft visual c++ 2010 x86 redistributable - 10.0.40219
Please help me if you know the silution of this problem, I really need to use Autocad as fast as I can. Thank you very much for your help.
1 REPLY 1
pendean
To resolve the error 1603 please do the following:
- Uninstall .NET and all versions of C++.
- Disable User Account Controls and Antivirus software.
- Make sure you are logged in as the administrator and have full access.
- Make sure you meet all system requirements.
- When running the installer right-click and select the option ‘Run as administrator’.
- http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1...
Administrator Productivity
