Installation & Licensing
AutoCAD 2011 on directX 11
1 REPLY 1
2759 Views, 1 Reply
Hi
I have a problem with AutoCAD 2011 on my new notebook with windows 7 and directX 11, cause during installation it says that i don't have directX 9.0c, i tryied to install it from autocad install folder, but it says that i already have directX 9.0, but autocad still says me that I don't have that... Is it possible that AutoCAD 2011 just doesn't support directX 11?
2011/2/1:17:31:20    User    USER-LAPTOP    === Setup started on USER-LAPTOP by User ===
2011/2/1:17:44:02    User    USER-LAPTOP    Install    Microsoft Visual C++ 2008 Redistributable (x86)    Succeeded
2011/2/1:17:44:26    User    USER-LAPTOP    Install    DirectX 9.0 Runtime    Failed    Failure is ignored, Result=-9
2011/2/1:17:44:44    User    USER-LAPTOP    Install    FARO LS 1.1.406.58    Succeeded
2011/2/1:17:45:10    User    USER-LAPTOP    Install    Autodesk Material Library 2011    Succeeded
2011/2/1:17:45:34    User    USER-LAPTOP    Install    Autodesk Material Library 2011 Base Image library    Succeeded
2011/2/1:17:45:43    User    USER-LAPTOP    Install    AutoCAD 2011    Failed    Installation aborted, Result=1603
2011/2/1:17:45:57    User    USER-LAPTOP    Rollback    Autodesk Material Library 2011 Base Image library    Succeeded
2011/2/1:17:46:17    User    USER-LAPTOP    Rollback    Autodesk Material Library 2011    Succeeded
2011/2/1:17:46:19    User    USER-LAPTOP    Rollback    FARO LS 1.1.406.58    Succeeded
2011/2/1:17:46:19    User    USER-LAPTOP    Rollback    Microsoft Visual C++ 2008 Redistributable (x86)    Failed    Installation aborted, Result=1619
1 REPLY 1
hashim.mundol
In this case, you could try to install directx manually from MS site.
http://www.microsoft.com/download/en/details.aspx?id=19743
but the actual issue is Autocad installation error 1603.
1603 is generic permission error, please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persisits, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Administrator Productivity
