Hi
I have a problem with AutoCAD 2011 on my new notebook with windows 7 and directX 11, cause during installation it says that i don't have directX 9.0c, i tryied to install it from autocad install folder, but it says that i already have directX 9.0, but autocad still says me that I don't have that... Is it possible that AutoCAD 2011 just doesn't support directX 11?
2011/2/1:17:31:20 User USER-LAPTOP === Setup started on USER-LAPTOP by User ===
2011/2/1:17:44:02 User USER-LAPTOP Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded
2011/2/1:17:44:26 User USER-LAPTOP Install DirectX 9.0 Runtime Failed Failure is ignored, Result=-9
2011/2/1:17:44:44 User USER-LAPTOP Install FARO LS 1.1.406.58 Succeeded
2011/2/1:17:45:10 User USER-LAPTOP Install Autodesk Material Library 2011 Succeeded
2011/2/1:17:45:34 User USER-LAPTOP Install Autodesk Material Library 2011 Base Image library Succeeded
2011/2/1:17:45:43 User USER-LAPTOP Install AutoCAD 2011 Failed Installation aborted, Result=1603
2011/2/1:17:45:57 User USER-LAPTOP Rollback Autodesk Material Library 2011 Base Image library Succeeded
2011/2/1:17:46:17 User USER-LAPTOP Rollback Autodesk Material Library 2011 Succeeded
2011/2/1:17:46:19 User USER-LAPTOP Rollback FARO LS 1.1.406.58 Succeeded
2011/2/1:17:46:19 User USER-LAPTOP Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1619
In this case, you could try to install directx manually from MS site.
http://www.microsoft.com/download/en/details.aspx?id=19743
but the actual issue is Autocad installation error 1603.
1603 is generic permission error, please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persisits, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
