Installation & Licensing
Autocad 2011 Installation trouble error 1603
23 REPLIES 23
Message 1 of 24
sm4rt
32411 Views, 23 Replies
Hi !
I got a situation when trying to install Autocad 2011 on my PC. The installation failed on Microsoft Visual C++ installation which return the error code 1603 !
here is the log installation file :
2010/6/19:11:28:01	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
2010/6/19:11:28:30	Desktop	MYCOMPUTER	=== Setup ended ===
2010/6/19:11:28:20	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
2010/6/19:11:31:24	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
2010/6/19:11:32:34	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2008 Redistributable (x86)	Failed	Installation aborted, Result=1603
2010/6/19:11:34:31	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
2010/6/19:11:35:32	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
2010/6/19:11:35:46	Desktop	MYCOMPUTER	=== Setup ended ===
2010/6/19:11:37:21	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
2010/6/19:11:37:30	Desktop	MYCOMPUTER	=== Setup ended ===
2010/6/19:11:37:26	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
2010/6/19:11:38:44	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
2010/6/19:11:38:54	Desktop	MYCOMPUTER	=== Setup ended ===
2010/6/19:11:43:17	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
2010/6/19:11:43:27	Desktop	MYCOMPUTER	=== Setup ended ===
2010/6/19:11:43:23	Desktop	MYCOMPUTER	=== Setup started on MYCOMPUTER by Desktop ===
2010/6/19:11:47:47	Desktop	MYCOMPUTER	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1603
I'm currently on an ASUS Windows 7 with an AMD Athlon II Dual-Core M320 2.1GHz processor.
Please help me to solve this probleme
regards
23 REPLIES 23
Message 21 of 24
i have the same problem with autoCAD 2012 tried the diaganostic mode but didn't work, cobied it to HD did/t work also.
log file
2011/10/10:23:47:35    user    KHLAPTOP    === Setup started on KHLAPTOP by user ===
2011/10/10:23:47:35    user    KHLAPTOP    Launch
2011/10/10:23:48:18    user    KHLAPTOP    PageOpen    LaunchDialog
2011/10/10:23:54:18    user    KHLAPTOP    PageOpen    LicenseDialog
2011/10/10:23:54:22    user    KHLAPTOP    PageOpen    ProductInfoDialog
2011/10/10:23:54:39    user    KHLAPTOP    PageOpen    ProductSelectionDialog2
2011/10/10:23:54:50    user    KHLAPTOP    PageOpen    FullProgressDialog
2011/10/10:23:54:50    user    KHLAPTOP    Installing DirectX Runtime: F:\acad2012\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/10:23:55:35    user    KHLAPTOP    Install    DirectX Runtime    Succeeded
2011/10/10:23:55:38    user    KHLAPTOP    Installing AutoCAD® 2012:  TRANSFORMS="F:\acad2012\x86\en-us\acad\acad.mst;C:\DOCUME~1\user\LOCALS~1\Temp\_AI2.tmp\x86\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\acad2012\" INSTALLDIR="e:\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/10/10:23:56:32    user    KHLAPTOP    Install    AutoCAD® 2012    Failed    Installation aborted, Result=1603
2011/10/10:23:56:32    user    KHLAPTOP    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
2011/10/10:23:56:32    user    KHLAPTOP    PageOpen    InstallCompleteDialog
2011/10/10:23:56:46    user    KHLAPTOP    === Setup ended ===
2011/10/11:00:46:35    user    KHLAPTOP    === Setup started on KHLAPTOP by user ===
2011/10/11:00:46:35    user    KHLAPTOP    Launch
2011/10/11:00:47:06    user    KHLAPTOP    === Setup ended ===
2011/10/11:00:47:07    user    KHLAPTOP    PageOpen    LaunchDialog
2011/10/11:00:47:26    user    KHLAPTOP    PageOpen    LicenseDialog
2011/10/11:00:47:34    user    KHLAPTOP    PageOpen    ProductInfoDialog
2011/10/11:00:47:44    user    KHLAPTOP    PageOpen    ProductSelectionDialog2
2011/10/11:00:47:56    user    KHLAPTOP    PageOpen    FullProgressDialog
2011/10/11:00:47:56    user    KHLAPTOP    Installing DirectX Runtime: F:\acad2012\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/11:00:48:26    user    KHLAPTOP    Install    DirectX Runtime    Succeeded
2011/10/11:00:48:27    user    KHLAPTOP    Installing AutoCAD® 2012:  TRANSFORMS="F:\acad2012\x86\en-us\acad\acad.mst;C:\DOCUME~1\user\LOCALS~1\Temp\_AI76.tmp\x86\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\acad2012\" INSTALLDIR="d:\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2011/10/11:00:50:26    user    KHLAPTOP    Install    AutoCAD® 2012    Failed    Installation aborted, Result=1603
2011/10/11:00:50:27    user    KHLAPTOP    Rollback    DirectX Runtime    Failed    Failure is ignored, Result=1619
Message 22 of 24
lpreble
in reply to: ken.stumpf
Seriously, thank you! This fixed my problem too. I also have ArcGIS installed, same version. I had no idea it was the root of my problems. After the registry change, I was able to install Windows 2005 C++ redistribution. My installation of AutoDesk completed without errors. I have been working on this for days. Again, thank you! I was dubious of this suggestion, but I was at my wits end and it worked.
Message 23 of 24
tobyvanderbeek
in reply to: lpreble
I solved this problem in case anyone is still having trouble. I just uninstalled all Visual C++ Redistributable packages in the Add/Remove Programs. All Autodesk programs installed fine after. Then Windows Update wanted to update all Visual packages with several restarts.
Message 24 of 24
thanks  its working good .
Administrator Productivity
