Hi !
I got a situation when trying to install Autocad 2011 on my PC. The installation failed on Microsoft Visual C++ installation which return the error code 1603 !
here is the log installation file :
2010/6/19:11:28:01 Desktop MYCOMPUTER === Setup started on MYCOMPUTER by Desktop === 2010/6/19:11:28:30 Desktop MYCOMPUTER === Setup ended === 2010/6/19:11:28:20 Desktop MYCOMPUTER === Setup started on MYCOMPUTER by Desktop === 2010/6/19:11:31:24 Desktop MYCOMPUTER Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2010/6/19:11:32:34 Desktop MYCOMPUTER Install Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1603 2010/6/19:11:34:31 Desktop MYCOMPUTER Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2010/6/19:11:35:32 Desktop MYCOMPUTER Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2010/6/19:11:35:46 Desktop MYCOMPUTER === Setup ended === 2010/6/19:11:37:21 Desktop MYCOMPUTER === Setup started on MYCOMPUTER by Desktop === 2010/6/19:11:37:30 Desktop MYCOMPUTER === Setup ended === 2010/6/19:11:37:26 Desktop MYCOMPUTER === Setup started on MYCOMPUTER by Desktop === 2010/6/19:11:38:44 Desktop MYCOMPUTER Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603 2010/6/19:11:38:54 Desktop MYCOMPUTER === Setup ended === 2010/6/19:11:43:17 Desktop MYCOMPUTER === Setup started on MYCOMPUTER by Desktop === 2010/6/19:11:43:27 Desktop MYCOMPUTER === Setup ended === 2010/6/19:11:43:23 Desktop MYCOMPUTER === Setup started on MYCOMPUTER by Desktop === 2010/6/19:11:47:47 Desktop MYCOMPUTER Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
I'm currently on an ASUS Windows 7 with an AMD Athlon II Dual-Core M320 2.1GHz processor.
Please help me to solve this probleme
regards
Solved by jrmaxxx. Go to Solution.
Solved by idlewildbrooklyn. Go to Solution.
Solved by ken.stumpf. Go to Solution.
i have the same problem with autoCAD 2012 tried the diaganostic mode but didn't work, cobied it to HD did/t work also.
log file
2011/10/10:23:47:35 user KHLAPTOP === Setup started on KHLAPTOP by user ===
2011/10/10:23:47:35 user KHLAPTOP Launch
2011/10/10:23:48:18 user KHLAPTOP PageOpen LaunchDialog
2011/10/10:23:54:18 user KHLAPTOP PageOpen LicenseDialog
2011/10/10:23:54:22 user KHLAPTOP PageOpen ProductInfoDialog
2011/10/10:23:54:39 user KHLAPTOP PageOpen ProductSelectionDialog2
2011/10/10:23:54:50 user KHLAPTOP PageOpen FullProgressDialog
2011/10/10:23:54:50 user KHLAPTOP Installing DirectX Runtime: F:\acad2012\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/10:23:55:35 user KHLAPTOP Install DirectX Runtime Succeeded
2011/10/10:23:55:38 user KHLAPTOP Installing AutoCAD® 2012: TRANSFORMS="F:\acad2012\x86\en-us\acad\acad.mst;C:\DOCUME~1\user\LOCALS~1\Temp\_AI2.tmp\x86\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\acad2012\" INSTALLDIR="e:\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/10:23:56:32 user KHLAPTOP Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2011/10/10:23:56:32 user KHLAPTOP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2011/10/10:23:56:32 user KHLAPTOP PageOpen InstallCompleteDialog
2011/10/10:23:56:46 user KHLAPTOP === Setup ended ===
2011/10/11:00:46:35 user KHLAPTOP === Setup started on KHLAPTOP by user ===
2011/10/11:00:46:35 user KHLAPTOP Launch
2011/10/11:00:47:06 user KHLAPTOP === Setup ended ===
2011/10/11:00:47:07 user KHLAPTOP PageOpen LaunchDialog
2011/10/11:00:47:26 user KHLAPTOP PageOpen LicenseDialog
2011/10/11:00:47:34 user KHLAPTOP PageOpen ProductInfoDialog
2011/10/11:00:47:44 user KHLAPTOP PageOpen ProductSelectionDialog2
2011/10/11:00:47:56 user KHLAPTOP PageOpen FullProgressDialog
2011/10/11:00:47:56 user KHLAPTOP Installing DirectX Runtime: F:\acad2012\3rdParty\DirectX\DXSETUP.exe /silent
2011/10/11:00:48:26 user KHLAPTOP Install DirectX Runtime Succeeded
2011/10/11:00:48:27 user KHLAPTOP Installing AutoCAD® 2012: TRANSFORMS="F:\acad2012\x86\en-us\acad\acad.mst;C:\DOCUME~1\user\LOCALS~1\Temp\_AI76.tmp\x86\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\acad2012\" INSTALLDIR="d:\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/10/11:00:50:26 user KHLAPTOP Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2011/10/11:00:50:27 user KHLAPTOP Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Seriously, thank you! This fixed my problem too. I also have ArcGIS installed, same version. I had no idea it was the root of my problems. After the registry change, I was able to install Windows 2005 C++ redistribution. My installation of AutoDesk completed without errors. I have been working on this for days. Again, thank you! I was dubious of this suggestion, but I was at my wits end and it worked.
I solved this problem in case anyone is still having trouble. I just uninstalled all Visual C++ Redistributable packages in the Add/Remove Programs. All Autodesk programs installed fine after. Then Windows Update wanted to update all Visual packages with several restarts.
