Installation & Licensing
Active Member
sanoop
Message 1 of 9 (2,018 Views)
AutoCAD 2011 installation error
2018 Views, 8 Replies
02-10-2011 11:02 PM
I can't install AutoCAD 2011 in my laptop. It shows already installed
Solidworks Certified Professional
AutoCAD 2010 Certified Professional
AutoCAD 2010 Certified Associate
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Remove-Programs/td-p/2865314
Product Support
hashim.mundol
Message 2 of 9 (2,010 Views)
Re: AutoCAD 2011 installation error
02-11-2011 01:39 AM in reply to: sanoop
Please try the uninstaller script
http://usa.autodesk.com/getdoc/id=TS16077500
If this doesnt help, we will need to clean up the registry entry from the installer hive or use a 3rd party clean up utility.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
TravisNave
Message 3 of 9 (1,979 Views)
02-11-2011 12:47 PM in reply to: sanoop
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Active Member
sanoop
Message 4 of 9 (1,928 Views)
02-13-2011 10:31 PM in reply to: sanoop
I have cheched it, but it shows errot- 2147467259- configure product and also AcadLP.msi cannot be uninstalled unless Acad.msi has been uninstalled.
Sanoop
Active Member
sanoop
Message 5 of 9 (1,874 Views)
02-16-2011 12:39 AM in reply to: TravisNave
Thank you for your greate support.
Regards
Sanoop Ezhokaran
New Member
svelez
Message 6 of 9 (1,828 Views)
02-16-2011 02:11 PM in reply to: sanoop
I CAN'T INSTALL AUTOCAD INTO MY LAPTOP. HOW COULD I DO IT I HAVE WINDOWS 7
DarrenP
Message 7 of 9 (1,824 Views)
02-16-2011 02:23 PM in reply to: svelez
is there an error message?
New Member
takketan6
Message 8 of 9 (991 Views)
03-03-2013 04:28 AM in reply to: sanoop
Delete all temporary Files from laptop. Then Run CCleaner or any other software which can fixed your registry error. turn off your PC & then try to install cad. If this is not work then go to this link http://support.microsoft.com/mats/Program_Install_and_Uninstall & run the program installer & Uniinstaller troubleshooter. It will scan errors in your computer & Fixed it automatically or you can try it manually from the option. for any query mail me Takketan6@gmail.com
TravisNave
Message 9 of 9 (941 Views)
03-04-2013 09:13 AM in reply to: takketan6
takketan6 wrote:
Delete all temporary Files from laptop. Then Run CCleaner or any other software which can fixed your registry error. turn off your PC & then try to install cad. If this is not work then go to this link http://support.microsoft.com/mats/Program_Install_and_Uninstall & run the program installer & Uniinstaller troubleshooter. It will scan errors in your computer & Fixed it automatically or you can try it manually from the option. for any query mail me.
Is there a reason you responded to a solved post that is more than 2 years old here in this forum?  We appreciate all sorts of help here, but please try to help users with current issues if you wish to participate and add value to the forum.  Thanks!  :smileyhappy:
