Installation & Licensing
Active Member
sanoop
Message 1 of 9 (1,952 Views)
AutoCAD 2011 installation error
1952 Views, 8 Replies
02-10-2011 11:02 PM
I can't install AutoCAD 2011 in my laptop. It shows already installed
Solidworks Certified Professional
AutoCAD 2010 Certified Professional
AutoCAD 2010 Certified Associate
Product Support
hashim.mundol
Message 2 of 9 (1,944 Views)
Re: AutoCAD 2011 installation error
02-11-2011 01:39 AM in reply to: sanoop
Please try the uninstaller script
http://usa.autodesk.com/getdoc/id=TS16077500
If this doesnt help, we will need to clean up the registry entry from the installer hive or use a 3rd party clean up utility.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
TravisNave
Message 3 of 9 (1,913 Views)
02-11-2011 12:47 PM in reply to: sanoop
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
sanoop
Message 4 of 9 (1,862 Views)
02-13-2011 10:31 PM in reply to: sanoop
I have cheched it, but it shows errot- 2147467259- configure product and also AcadLP.msi cannot be uninstalled unless Acad.msi has been uninstalled.
Sanoop
Active Member
sanoop
Message 5 of 9 (1,808 Views)
02-16-2011 12:39 AM in reply to: TravisNave
Thank you for your greate support.
Regards
Sanoop Ezhokaran
New Member
svelez
Message 6 of 9 (1,762 Views)
02-16-2011 02:11 PM in reply to: sanoop
I CAN'T INSTALL AUTOCAD INTO MY LAPTOP. HOW COULD I DO IT I HAVE WINDOWS 7
DarrenP
Message 7 of 9 (1,758 Views)
02-16-2011 02:23 PM in reply to: svelez
is there an error message?
New Member
takketan6
Message 8 of 9 (925 Views)
03-03-2013 04:28 AM in reply to: sanoop
Delete all temporary Files from laptop. Then Run CCleaner or any other software which can fixed your registry error. turn off your PC & then try to install cad. If this is not work then go to this link http://support.microsoft.com/mats/Program_Install_and_Uninstall & run the program installer & Uniinstaller troubleshooter. It will scan errors in your computer & Fixed it automatically or you can try it manually from the option. for any query mail me Takketan6@gmail.com
TravisNave
Message 9 of 9 (875 Views)
03-04-2013 09:13 AM in reply to: takketan6
takketan6 wrote:
Delete all temporary Files from laptop. Then Run CCleaner or any other software which can fixed your registry error. turn off your PC & then try to install cad. If this is not work then go to this link http://support.microsoft.com/mats/Program_Install_and_Uninstall & run the program installer & Uniinstaller troubleshooter. It will scan errors in your computer & Fixed it automatically or you can try it manually from the option. for any query mail me.
Is there a reason you responded to a solved post that is more than 2 years old here in this forum?  We appreciate all sorts of help here, but please try to help users with current issues if you wish to participate and add value to the forum.  Thanks!  :smileyhappy:
