I've been reading through some of the discussions about errors in loading AutoCad 2011 and cannot seem to find a solution to my issue. I'm attempting to load AutoCad 2011 on a WIndows Pro. XP platform and I'm getting these errors:
Install Direct x 9.0 Runtime Succeeded
Install FARO LS 1.1.406.58 Succeeded
INstall Autodesk Material Library 2011 Succeeded
INstall Autodesk Material Library 2011 Base Image Library Succeeded
Install AutoCad 2011 Failed Installation aborted, Result=1603
Install Direct x 9.0 Runtime Failed Failure is ignored, Result = 1619
Any help would be appreciated.
the solution is simple and very easy.
simply copy the whole disk contents to your hard disk and then run setup from the hard disk.
you have done it...
autocad 2010 installed...
on both xp and windows 7..
satinder paul singh
ram nagar dalhousie road
pathankot 145001
punjab - india
9855567891
2012/5/17:12:33:45 user USER-PC === Setup started on USER-PC by user ===
2012/5/17:12:33:45 user USER-PC Launch
2012/5/17:12:34:27 user USER-PC PageOpen LaunchDialog
2012/5/17:12:34:56 user USER-PC PageOpen LicenseDialog
2012/5/17:12:35:36 user USER-PC PageOpen ProductInfoDialog
2012/5/17:12:35:52 user USER-PC PageOpen ProductSelectionDialog2
2012/5/17:12:35:54 user USER-PC PageOpen FullProgressDialog
2012/5/17:12:35:54 user USER-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/5/17:12:36:28 user USER-PC Install DirectX Runtime Succeeded
2012/5/17:12:36:29 user USER-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/17:12:36:36 user USER-PC Install Autodesk Material Library 2012 Succeeded
2012/5/17:12:36:36 user USER-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/17:12:37:07 user USER-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/5/17:12:37:07 user USER-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/17:12:37:11 user USER-PC Install Autodesk Content Service Succeeded
2012/5/17:12:37:11 user USER-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\user\AppData\Local\Temp\_AIC381.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/17:12:39:30 user USER-PC Install AutoCAD® 2012 Succeeded
2012/5/17:12:39:30 user USER-PC Installing AutoCAD® 2012 Language Pack: TRANSFORMS="C:\Users\user\AppData\Local\Temp\_AIC381.tmp\_la1021.tmp.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/17:12:39:31 user USER-PC Install AutoCAD® 2012 Language Pack Failed Installation aborted, Result=1624
2012/5/17:12:40:28 user USER-PC Rollback AutoCAD® 2012 Failed Installation aborted, Result=1603
2012/5/17:12:40:38 user USER-PC Rollback Autodesk Content Service Succeeded
2012/5/17:12:41:01 user USER-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/5/17:12:41:17 user USER-PC Rollback Autodesk Material Library 2012 Succeeded
2012/5/17:12:41:17 user USER-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
I had this error I tried to copy the installation source to my local disk but it still displayed this error
Please help!
I am having the same error as above, i am installing from the downloaded install files for AutoCAD 2012 using an educational license. My computer meets all of the requirements for running the program and i am using XP sp3. I have tried removing DirectX from the install.ini as suggested, before and after that i have tried manually installing DirectX from both the link given in this post http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17391481&linkID=9240617 as well as downloading the latest DirectX version from the Microsoft website and installing that. I would appreciate some help.
Andrew
p.s. I tried uploading a compressed .zip file with the temp files in it, however it won't let me attach it to this post because it is too big, I have tried compressing with .rar but it comes up with an unsupported file type when trying to upload to this post. Is there an email address that I can send the file to instead? .zip file approximately 2.21 MB. Or is there some files that i could remove that you do not require?
File listing for temp folder
{A49BDCBE-590E-43A6-AB77-7C40E499B7C1} (folder) -> contents DWFViewerApp.ini
files
AcDeltree.exe
adEC.tmp
AutoCAD 2012 Install.log
AutoCAD 2012 Setup.log
Autodesk Content Service.log
etilqs_GGy5qtfzNcAkL6z
etilqs_h6Vg2DTRXc5ceY9
etilqs_Na7bdNvnenguyXa
FaroSDK.log
FNP_ACT_InstallerCA.dll
MaterialLibrary2012CM.log
MaterialLibrary2012CMILB.log
setupverifier_errors_06-12-12_12.06.39.txt
setupverifier_errors_06-12-12_12.06.43.txt
setupverifier_main_06-12-12_12.06.39.txt
setupverifier_main_06-12-12_12.06.43.txt
