I've been reading through some of the discussions about errors in loading AutoCad 2011 and cannot seem to find a solution to my issue. I'm attempting to load AutoCad 2011 on a WIndows Pro. XP platform and I'm getting these errors:
Install Direct x 9.0 Runtime Succeeded
Install FARO LS 1.1.406.58 Succeeded
INstall Autodesk Material Library 2011 Succeeded
INstall Autodesk Material Library 2011 Base Image Library Succeeded
Install AutoCad 2011 Failed Installation aborted, Result=1603
Install Direct x 9.0 Runtime Failed Failure is ignored, Result = 1619
Any help would be appreciated.
1603 is a generic error which could related to the permissions (registry/folder/file). If you can find the detailed log in the %temp% folder, it should have more details. If you can post the parts which mentions about the errors, we could help you find the cause.
Directx seems to install Successfully, so we can ignore that for the timebeing.
All,
I am having the same issue. Below is what I believe is the full installation log that Autocad 2011 created during my several attempts to install. My errors always appear to be 1603 and 1619. I have manually installed DirectX9.0 Runtime in hopes that would reslove my issue but it did not. Any help would be amazing. Thanks!
2010/11/22:11:40:11 nmaynard LENOVO-C3D51556 === Setup started on LENOVO-C3D51556 by nmaynard ===
2010/11/22:11:41:54 nmaynard LENOVO-C3D51556 === Setup ended ===
2010/11/22:11:41:46 nmaynard LENOVO-C3D51556 === Setup started on LENOVO-C3D51556 by nmaynard ===
2010/11/22:11:45:50 nmaynard LENOVO-C3D51556 Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded
2010/11/22:11:46:09 nmaynard LENOVO-C3D51556 Install DirectX 9.0 Runtime Succeeded
2010/11/22:11:46:18 nmaynard LENOVO-C3D51556 Install FARO LS 1.1.406.58 Succeeded
2010/11/22:11:47:04 nmaynard LENOVO-C3D51556 Install Autodesk Material Library 2011 Succeeded
2010/11/22:11:48:03 nmaynard LENOVO-C3D51556 Install Autodesk Material Library 2011 Base Image library Succeeded
2010/11/22:11:51:40 nmaynard LENOVO-C3D51556 Install AutoCAD 2011 Failed Installation aborted, Result=1603
2010/11/22:11:52:52 nmaynard LENOVO-C3D51556 Rollback Autodesk Material Library 2011 Base Image library Succeeded
2010/11/22:11:54:04 nmaynard LENOVO-C3D51556 Rollback Autodesk Material Library 2011 Succeeded
2010/11/22:11:54:05 nmaynard LENOVO-C3D51556 Rollback FARO LS 1.1.406.58 Succeeded
2010/11/22:11:54:05 nmaynard LENOVO-C3D51556 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2010/11/22:11:54:05 nmaynard LENOVO-C3D51556 Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1619
2010/11/22:11:54:33 nmaynard LENOVO-C3D51556 === Setup ended ===
2010/11/22:11:55:50 nmaynard LENOVO-C3D51556 === Setup started on LENOVO-C3D51556 by nmaynard ===
2010/11/22:11:56:54 nmaynard LENOVO-C3D51556 === Setup ended ===
2010/11/22:11:56:46 nmaynard LENOVO-C3D51556 === Setup started on LENOVO-C3D51556 by nmaynard ===
2010/11/22:12:05:15 nmaynard LENOVO-C3D51556 Install DirectX 9.0 Runtime Succeeded
2010/11/22:12:05:23 nmaynard LENOVO-C3D51556 Install FARO LS 1.1.406.58 Succeeded
2010/11/22:12:06:13 nmaynard LENOVO-C3D51556 Install Autodesk Material Library 2011 Succeeded
2010/11/22:12:07:08 nmaynard LENOVO-C3D51556 Install Autodesk Material Library 2011 Base Image library Succeeded
2010/11/22:12:10:28 nmaynard LENOVO-C3D51556 Install AutoCAD 2011 Failed Installation aborted, Result=1603
2010/11/22:12:11:59 nmaynard LENOVO-C3D51556 Rollback Autodesk Material Library 2011 Base Image library Succeeded
2010/11/22:12:13:29 nmaynard LENOVO-C3D51556 Rollback Autodesk Material Library 2011 Succeeded
2010/11/22:12:13:31 nmaynard LENOVO-C3D51556 Rollback FARO LS 1.1.406.58 Succeeded
2010/11/22:12:13:31 nmaynard LENOVO-C3D51556 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2010/11/22:12:21:11 nmaynard LENOVO-C3D51556 === Setup ended ===
2010/11/22:12:26:20 nmaynard LENOVO-C3D51556 === Setup started on LENOVO-C3D51556 by nmaynard ===
2010/11/22:12:26:50 nmaynard LENOVO-C3D51556 === Setup ended ===
2010/11/22:12:26:44 nmaynard LENOVO-C3D51556 === Setup started on LENOVO-C3D51556 by nmaynard ===
2010/11/22:12:28:27 nmaynard LENOVO-C3D51556 Install DirectX 9.0 Runtime Succeeded
2010/11/22:12:28:35 nmaynard LENOVO-C3D51556 Install FARO LS 1.1.406.58 Succeeded
2010/11/22:12:29:30 nmaynard LENOVO-C3D51556 Install Autodesk Material Library 2011 Succeeded
2010/11/22:12:30:22 nmaynard LENOVO-C3D51556 Install Autodesk Material Library 2011 Base Image library Succeeded
2010/11/22:12:33:50 nmaynard LENOVO-C3D51556 Install AutoCAD 2011 Failed Installation aborted, Result=1603
2010/11/22:12:35:05 nmaynard LENOVO-C3D51556 Rollback Autodesk Material Library 2011 Base Image library Succeeded
2010/11/22:12:36:37 nmaynard LENOVO-C3D51556 Rollback Autodesk Material Library 2011 Succeeded
2010/11/22:12:36:37 nmaynard LENOVO-C3D51556 Rollback FARO LS 1.1.406.58 Succeeded
2010/11/22:12:36:37 nmaynard LENOVO-C3D51556 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2010/11/22:12:44:25 nmaynard LENOVO-C3D51556 === Setup ended ===
2010/11/22:12:54:07 nmaynard LENOVO-C3D51556 === Setup started on LENOVO-C3D51556 by nmaynard ===
2010/11/22:12:54:47 nmaynard LENOVO-C3D51556 === Setup ended ===
2010/11/22:12:54:40 nmaynard LENOVO-C3D51556 === Setup started on LENOVO-C3D51556 by nmaynard ===
2010/11/22:12:57:12 nmaynard LENOVO-C3D51556 Install DirectX 9.0 Runtime Succeeded
2010/11/22:12:57:21 nmaynard LENOVO-C3D51556 Install FARO LS 1.1.406.58 Succeeded
2010/11/22:12:58:17 nmaynard LENOVO-C3D51556 Install Autodesk Material Library 2011 Succeeded
2010/11/22:12:59:13 nmaynard LENOVO-C3D51556 Install Autodesk Material Library 2011 Base Image library Succeeded
2010/11/22:13:02:37 nmaynard LENOVO-C3D51556 Install AutoCAD 2011 Failed Installation aborted, Result=1603
2010/11/22:13:04:15 nmaynard LENOVO-C3D51556 Rollback Autodesk Material Library 2011 Base Image library Succeeded
2010/11/22:13:05:44 nmaynard LENOVO-C3D51556 Rollback Autodesk Material Library 2011 Succeeded
2010/11/22:13:05:44 nmaynard LENOVO-C3D51556 Rollback FARO LS 1.1.406.58 Succeeded
2010/11/22:13:05:45 nmaynard LENOVO-C3D51556 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2010/11/22:14:04:31 nmaynard LENOVO-C3D51556 === Setup ended ===
Like the user before me, I, too, am getting the same error when installing 2012 on my XP machine. It gets to a point where AutoCAD's main content has started to install and fails saying that the DirectX needs to be installed/updated. Problem is, not only did the DirectX install at the beginning of the process, but I also installed it separately before launching the AutoCAD 2012 setup program.
What else can be done to fix the problem?
Thanks, Vincent
My solution to the issue was to install autocad LT instead...Seems to work fine now as long as your willing to sacrifice sheet set, purge etc...
Please post the compressed log file from temp folder (normally the verbose log files should be bigger than 100K, upto few Mbs)
I have EXCACTLY the same Problem.
AutoCad 2012
XP SP3 / with Admin Rights
Installation error 1603 at the Moment when the setup routine used to install AutoCad
Installation error 1619 at the Moment where the Rollback of Direct X should happen
So please where is the answer ?
Everything that was in the log file posted in this topic is the same with the exception of the AutoCAD version being 2012 instead of 2011 and obviously the username.
this is only summary log, we need the detailed log.
please delete all files from temp folder, start the installation.when it fails, please compress all the files from the temp folder and post it here.
Also please try to copy the installation source to the local disk and try to install from there
Here is the installation log.
About the copy source and install from local, I've already done that as well as create a deployment and neither worked.
Has there been any kind of resolution for this error "1603" problem. If it helps, I have tried installing straight from DVD, from deployment, and from DVD copy to local drive and still receive the error each time. Each time a window pops up saying that DirectX needs to be installed. I have installed/updated DirectX before attempting to install and still get the same error.
Please try the installation in diagnostics mode
http://usa.autodesk.com/getdoc/id=TS75218
if it fails, please post the verbose log from temp folder
http://support.microsoft.com/kb/223300
I changed the system to diagnostics startup and enabled the logging key. Here are the files from the failed install that I attempted. Hopefully you or somebody will be able to figure it out.
This is the actual error in the log
Error :: Please install DirectX before installing AutoCAD 2012 - English.
Please try to run the directx setup manually from the DVD/the downloaded content.
Eg:-
Media\3rdParty\DirectX\DXSETUP.exe
I have installed/updated DirectX for the three different installs I have attempted. (DVD, Copy DVD to HDD, and Deployment)
I still get the same error each time.
If the manual directx setup was successfull you could try to disable this in the setup.ini (you will need the local disk copy of DVD)
Find the following line in setup.ini (root of Media)
PREREQUISITE=IE;SSE2;DOTNET20;DOTNET4;DOTNET4LANG;VCREDIST2008SP1X86;VCREDIST2008SP1X64;DIRECTX;FaroSDK;MSXML6;WMF95X64;CM2012;CMILB2012;SNAP_PRE
replace it with
PREREQUISITE=IE;SSE2;DOTNET20;DOTNET4;DOTNET4LANG;VCREDIST2008SP1X86;VCREDIST2008SP1X64;FaroSDK;MSXML6;WMF95X64;CM2012;CMILB2012;SNAP_PRE
When I removed DirectX from the PREREQUISITE line in the setup.ini file, it still gave me the same error. When I had said before that I updated DirectX, I was only using the update included in the 3rd party folder on the install disc itself. I have since went to Microsoft to download an updated version of DirectX End-User runtime redistributable, installed it and updated it. AutoCAD 2012 has now finished its portion of the install and moving onto the other components to be installed.
My conclusion is that the DirectX files on the AutoCAD 2012 install disc are incomplete and do not contain all necessary files.
Thanks for your help.
thanks for sharing the result. basically they are not the same files(we have some additional dlls with our directx), so I assume your original directx installation with the OS was corrupt, so MS version fixed it. once it was fixed Autocad installation went through.. (just a theory, i will investigate further)
If you get similar errors with Directx installation in the log, please try the following
Install the directx from the Autocad 2011 Media
setup file would be in
2011 Media\Support\Directx\DXsetup.exe
