When I run AutoCAD 2011 setup, it fails while initializing telling that setup cannot open the file specified
OS Windows vista SP2
3 GB RAM
with regards
ganekann
Solved by TravisNave. Go to Solution.
You might try cleaning your %temp% folder location. Make sure you are installing with local admin rights. You can also try exploring the disc and right-click setup.exe and choose Run as Administrator.
The error should be slightly different when run as administrator.
you are right. there seems to slight difference in error
Is this a downloaded version or from disc?
