Installation & Licensing
AutoCAD 2011 for Mac Crashes on Start
48 REPLIES 48
Message 1 of 49
ottoman42
10505 Views, 48 Replies
I downloaded and installed AutoCAD2011 twice and both times everything worked fine, but it always Crashes on the loading screen. No error message or anything.  Can anyone help with this?
48 REPLIES 48
Message 41 of 49
ottoman42
How did you fix it?
Message 42 of 49
in reply to: ottoman42
Was a solution to this problem ever found? I have been using AutoCAD on may MAC for several months now and yesterday it refused to open. Tried to uninstall and reinstall several times but it still crashes before it opens.
Any ideas?
Message 43 of 49
I finally got mine to work today after about an hour and a half with a few people from AutoCAD support on a GoToMeeting conference call. My particular issue was traced to a Flexnet folder. But they have said other issues have caused similar problems but completely different causes. Sorry I can't be much more help, but there seems to be bugs they are trying to work out and actively fixing it.
Message 44 of 49
Installation failure on new mac pro w/fully updated system software, no further indications as to what is the problem, simply "Contact the software manufacturer for assistance."
AAAGGH!
Message 45 of 49
I eventually found a solution to the problem here. It appears to be an issue related to having adobe products while installing autoCAD, particulary the FLEXnet publisher folder.
Message 46 of 49
david.lau
This solution is also under the AutoCAD for Mac discussion group:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/Autocad-2011-MAc-doesn-t-start-up/m-p/2839093/highligh...
David Lau
Message 47 of 49
pideja
I'm glad it worked...but what, exactly did the trick?
pideja
Message 48 of 49
in reply to: pideja
That works for me, too the flexnet file.
Message 49 of 49
Mine crashes few minutes after launching.
It crashes after opening and letting it sit 1 or 2 minutes without any activity.(Untouched)
It crashes after few seconds of drafting lines picking the command from the tool bar.
If I pick a task from the menu bar, the pointer disappear but the tool tip will remain. Even though no action can be performed when the pointer is not present. Few seconds later AutoCRASHED!
I have tried everything around to no avail.
And wait!
Lion is out in summer (2011) and I gave it a try in there. Result: there is not even a possibility to install. It appears grey out: http://cl.ly/0E0O0y1u1e1O3P3I042Z
Please give me some good news!
OS X 10.6.7 (10J869) - iMac 27" 2.93 GHz Intel Core, Quad Core  i7, 4G RAM, ATI Radeon HD 5750
Administrator Productivity
