Installation & Licensing
AutoCad 2010 x64 instaling problem
2 REPLIES 2
558 Views, 2 Replies
Hi , when i try installing AutoCad 2010 it fails to install , and this is the message from the temp text file "Install    AutoCAD 2010    Failed    Installation aborted, Result=1639"
any thoughts ?
2 REPLIES 2
pendean
TravisNave
Also make sure that there are no special characters, quotes, or blanks in the name / company name section of the installer.
I recommend installing with local admin rights, UAC off, and anti-virus temporarily disabled.  Additionally, do not add any service packs during installation and if you can copy the installation to your hard drive and install locally rather than from physical media. then do so.
Good Luck!
Autodesk Forums:
Administrator Productivity
