When you try to install AutoCAD 2010, you may get the following errors:
1. Autodesk component has encountered a problem and needs to closed. We are sorry for the inconvenience.
2. Error Signature. AppName: setup.exe AppVer: 3.0.40.100 ModName: litehtml.dll
This error message will occur if the computer doesn't have SSE2 Support. For more information, you can check out this blog:
http://autodesk.blogs.com/between_the_lines/2009/03/sse2-cpu-support-requirement-for-autocad-2010.ht...
You can download a free utility to check to check if your CPU has SSE2 technology.
http://www.cpuid.com/cpuz.php
David Lau
